  • Total: 73,770,641
  • Today: 20,314
  • May 05, 2024
  • 12:01 pm PDT
PostPosted: Wed May 03, 2017 2:35 pm Reply with quote Back to top
headless wrote:
nlovie wrote:
if you have a frame / swingarm that is prone to flexing then Ti may not be the best choice - but if you have a stiff structure then the need for the bolt to support flexing diminishes. Take this further (stiffer) and there is no need for a through bolt at all - can't get lighter than fresh air Smile - old style VF / around 200yr fireblade etc.. - horses for courses
That was my thinking as well. I'm not an engineer, but I don't think the pivot bolt substantially affects this swingarm's rigidity.
Your JMC is better then say an arm without a brace but it really need's side struts and then you would have something. The struts are what ties them altogether and makes it rigid.
We can cure that though. I know a guy with a welder. Very Happy
PostPosted: Fri May 05, 2017 4:31 am Reply with quote Back to top
Not the swinger at all. I was wondering how the bolt being that long and Ti would carry torque.
If you look at springs of the same value, but one of Ti and one of steel, comparatively, you can see the difference from across the room. I also remember the BSA debacle of the all Ti chassis and swinger and almost everything else (They built a 500 Single that only weighed 194 pounds in 1966).
But if it works, I guess it works! Very Happy
nlovie
PostPosted: Fri May 05, 2017 6:24 am Reply with quote Back to top
it is a good point Shawn and why you need to be careful when replicating what someone else has done - are you replicating the whole "system" or just one bit - this goes for anything
Take Brent's chassis - don't know the detail but its got a lower brace tube running parallel with the swing arm pivot, amongst other strengthening bits - I would imagine the swing arm is shimmed or accurately spaced to establish the right preload on the taper bearing - i.e. its possibly not reliant on the bolt torque to "squeeze" the frame against the swing arm to take up any lateral movement - so its not reliant on high bolt torque
take away the added chassis stiffness - add in some frame flex and the more ductile bolt will give (elastically) before a stiffer one - i.e. you may establish the initial clamping torque but what happens next when the flexing force tries to add to this ? - it may give and enable flex where a stiffer bolt may help to prevent it
ok - this is a thought game only - in the real world you probably wouldn't notice anything - carry on Laughing
PostPosted: Fri May 05, 2017 5:35 pm Reply with quote Back to top
Laughing Laughing
Exactly!
Can you imagine trying to ride one of these over cooked spaghetti chassis's with a 200hp bullet stuffed in it? Shocked
nlovie
PostPosted: Sat May 06, 2017 7:59 am Reply with quote Back to top
Shawn_Mc wrote:
Exactly!
Laughing days of old - when my pip higgin tuned GS1000 liked to weave above 100mph progressing into a full blown lockstop shearing tank slapper that pitched me over the bars just so I could experience what a lump of cheese must feel like as its put through the grater - oh and also learned that a denim cut off and a pair of jeans have the abrasion resistance of a piece of damp bog roll - and the perverse pleasure middle aged over weight spinster nurses have in separating bits of denim cloth from minced up fleshy bits - oh the misty memories of a miss spent youth Laughing
PostPosted: Wed Jun 14, 2017 4:10 am Reply with quote Back to top
Some new bling.
metu71
PostPosted: Thu Jun 15, 2017 12:59 am Reply with quote Back to top
Shocked
Wow!
-Pasi-
PostPosted: Tue Aug 01, 2017 8:33 am Reply with quote Back to top
I know this is headless's thread but as its about Titanium I thought I might add to it.
Some of you have already received the improved shift detent and read that it was copied directly from our own and as developed in our Superbike.
Well this is it, the original. It is identical in shape and form but is made from Titanium and further lightened which explains the holes. Further to all this as that I am about to undertake the same for everything else in the picture.
The answer is always "more power" always was, always is and always will be.
PostPosted: Tue Aug 01, 2017 9:52 pm Reply with quote Back to top
Nice work!
PostPosted: Thu Aug 31, 2017 4:43 am Reply with quote Back to top
Why?
A. Because I could and why not
B. it was steel and rusty
C. it's lighter
D. Bling factor
E. It's my obsession
F. All of the above
Simon_CB900
PostPosted: Sat Sep 02, 2017 7:41 pm Reply with quote Back to top
Rear brake master cylinder adjustable push rod whatsit? Shocked
Simon.
\'81 CB 750/900 mongrel Smile
PostPosted: Mon Sep 04, 2017 7:52 pm Reply with quote Back to top
You got it!.
Simon_CB900
PostPosted: Thu Sep 28, 2017 7:17 pm Reply with quote Back to top
Loverly Smile
Simon.
PostPosted: Fri Sep 29, 2017 1:56 am Reply with quote Back to top
Thanks. It will look a lot better after Tom does his magic.
PostPosted: Mon Dec 10, 2018 5:21 pm Reply with quote Back to top
I have been way overdue on updating this thread. My latest upgrades are a titanium Jay Gui exhaust with an aluminum muffler by JESBuilt, rearsets, my fender eliminator for a lidded tailpanel and a battery box with a Antigravity AG801 Li-ion battery
I mod'ed the taillight using an LED taillight from PGSmick.
PostPosted: Mon Dec 10, 2018 6:54 pm Reply with quote Back to top
Thumbs up!!
PostPosted: Mon Dec 10, 2018 8:42 pm Reply with quote Back to top
Looks great!!
zealous
PostPosted: Tue Dec 11, 2018 12:55 am Reply with quote Back to top
Beauty full
PostPosted: Tue Dec 11, 2018 3:38 pm Reply with quote Back to top
Love that oil cooler mount! Nice work!
PostPosted: Tue Dec 11, 2018 5:27 pm Reply with quote Back to top
Thanks, but I don't deserve all the credit. The frame mounts were made by charliemarley and I made the mount for the cooler.
BTW, the stock shocks are temporarily mounted while the Fox shocks are being rebuilt.
PostPosted: Tue Jan 21, 2020 2:19 am Reply with quote Back to top
"titaniumized" Nitro rearsets
PostPosted: Wed Jan 22, 2020 4:24 pm Reply with quote Back to top
When are you making a titanium frame? That's what we're all holding our breath for.
PostPosted: Wed Jan 22, 2020 5:55 pm Reply with quote Back to top
I realise that you maybe are not expecting an answer like this......
But a Titanium frame is being built but not in the US but here in NZ
Special tubing has been purchased and all the brackets and pressings are being resized and 3D printed and once completed will be welded together.
This is not easy as it must done inside a habitat to be oxygen free.
PostPosted: Wed Jan 22, 2020 6:18 pm Reply with quote Back to top
Interesting on the shift detent looks like the neutral position has been filled in and ony a small V for the neutral location, obviously helps with quicker 1-2 and 2-1 gearchanges?
Also a small ball bearing on the selector locater
1979 Honda CBX1000
PostPosted: Thu Jan 23, 2020 12:28 am Reply with quote Back to top
The Titanium frame moves things up several notches. Probably 20lbs lighter at least. That is huge!
PostPosted: Mon Jun 08, 2020 8:06 pm Reply with quote Back to top
I finished the gun drill setup for my lathe so I'm now able to drill deep holes.
first hole
PostPosted: Mon Jun 08, 2020 9:09 pm Reply with quote Back to top
Great!
PostPosted: Tue Jun 09, 2020 1:02 am Reply with quote Back to top
Nice Cary, I really need to do that. I already have a pump on my lathe. Just need the other setup. I'll be in touch.
PostPosted: Wed Jul 22, 2020 6:09 pm Reply with quote Back to top
The gun drill setup works great. I was able to drill a 17mm hole 300mm deep in about 15 minutes.
