  • Total: 123,212,325
  • Today: 208,741
  • 10:09 pm PST
mat30mat
PostPosted: Tue Apr 28, 2026 8:17 pm Reply with quote Back to top
Hey everyone, I'm working on the starter clutch for my '83 CB1100F. I've already got the David Silver rebuild kit in hand, but now I need to pull the rotor to get to the clutch housing.
​Can someone confirm the exact tool and thread size needed to pull the rotor?
​From what I've found, it looks like I need an M20 x 1.5 Right-Hand Thread puller (like the Motion Pro 08-0085). Is that the correct one for the 1100F?
​Thanks for the help!
PostPosted: Wed Apr 29, 2026 4:17 pm Reply with quote Back to top
The starter clutch is not behind the rotor on a CB1100F
its on the opposite side of the engine
just make sure you hold the 24mm hex on the ATU unit with a spanner before loosening the 12mm hex bolt
PostPosted: Wed Apr 29, 2026 5:09 pm Reply with quote Back to top
That package information is not for a 79-83 Honda DOHC motorcycle.
You don't pull a rotor to get at the starter clutch on a DOHC Honda, it's under the left engine cover. It's fastened with 3 bolts,
and doesn't look anything like the pictures you posted.
The Honda Shop Manual for the 1100F is in the Technical Documents section of the forum.
