  • Total: 123,280,306
  • Today: 31,102
  • Nov 24, 2026
  • 02:13 am PST
hondacliff
PostPosted: Fri Oct 25, 2024 8:29 pm Reply with quote Back to top
I am a new CB1100F owner trying to bring back a bike that's been sitting in a garage for over 20 years. The headers are rusty and there was a good sized hole in #2 pipe which a local magician has repaired. He said the inner pipe came loose and rattled enough against the outer one to wear a hole about the size of a thumb in the outer. The mufflers are showing their age but no rot. I have experimented with VHT Caliper paint in gloss black and it looks pretty good.
Any other recommendations to refinish the headers?
Cliff.
PostPosted: Sat Oct 26, 2024 12:22 am Reply with quote Back to top
I would be surprised if the caliper paint would hold up to the heat of even the mufflers. Hope it works.
The header refresh has been discussed a few times. A bit of info in this thread.
https://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=89782&highlight=mufflers
hondacliff
PostPosted: Sat Oct 26, 2024 3:07 am Reply with quote Back to top
The caliper paint is rated to 900f, that should cover it for the headers.Cliff.
PostPosted: Sat Oct 26, 2024 11:35 pm Reply with quote Back to top
Ya, those pipes will easly burn off 900 degree paint. Even the 2000 degree paint doesn't hold up that well.
langys
PostPosted: Sat Oct 26, 2024 11:40 pm Reply with quote Back to top
beerchug
hondacliff
PostPosted: Sun Oct 27, 2024 5:02 pm Reply with quote Back to top
I guess I'll find out. At least it will be baked on. Cliff.
