Mon Jul 22, 2024 7:09 pm |
Just printed this for Greg (Hondo57) with high temp PA12 carbon fiber. This will shave 2lb 2 oz off on what is probably the lightest streetable F on the planet
_________________ Cary |
langys
Mon Jul 22, 2024 9:02 pm |
Welleslyan
Mon Jul 22, 2024 11:03 pm |
Very nice. Is the lightest streetable F" now on the street?" |
Tue Jul 23, 2024 12:56 am |
Greg had a weird corrosion problem with the FCR spigots. New spigots are on the way to him. After which, he'll put it on the dyno and it will be ready. |
Tue Jul 23, 2024 11:22 am |
Great job Cary, you are the best!
This will bring the bike down to 372 lbs dry weight. That is over 200 lbs lighter than my 900F fully loaded. |
_________________ Greg |
JSGAuto1
Guest
Thu Aug 01, 2024 1:22 pm |
That's slick.
How was threading that? Did you use inserts? |
Thu Aug 01, 2024 11:21 pm |
I used inserts for the brush plate and tapped threads for the stator retaining screws |
Fri Aug 02, 2024 1:00 am |
| JSGAuto1 wrote: |
That's slick.
Now there's a blast from the past.
Nice to see you're still kicking, Jim. |
jkotsi
Fri Aug 02, 2024 4:06 am |
Just curious how carbon fibre deals with dispursing heat.
Cheers Jim |
JSGAuto1
Guest
Fri Aug 02, 2024 11:18 am |
| smurdoch wrote: |
| JSGAuto1 wrote: |
That's slick.
Thanks, been a few years, but I missed this community! |
Tdem
Thu Aug 29, 2024 7:05 pm |
Are you going to be making these for sale? I know my real wombat would love to be wall mounted so i don't eventually scratch it. |
Fri Aug 30, 2024 2:43 am |
I will be mount the CF wombat. Take it for a ride, Then do some temperature checking with a temp sensor gun. Inside readings to the best of my ability pulling it off fast as well as outside readings. The CF is good to 450 and the temp around that area is around 220. |
ctluba
Fri Aug 30, 2024 2:27 pm |
372lbs!!!!!!!!!
Wow man. That is unreal. Congrats on the bike. Beautiful  |
Fri Aug 30, 2024 5:47 pm |
| Tdem wrote: |
I'm waiting to see how Greg's temperature testing works out. |
