  • Total: 118,130,727
  • Today: 121,746
  • 12:43 am PDT
spammy
PostPosted: Mon May 30, 2022 9:17 am Reply with quote Back to top
Hi guys I think the bore size on my CB900f is 16mm or 5/8 I can’t actually see the stamp with the BMC on the bike but it needs replacing at some stage and I seen a good second hand BMC at a wreckers that is off a Honda ST1100. It looks pretty much identical as mine but the bore size is 14 mm. Do you think I’ll run into problems if I bought it. Thanks.
swiftnick
PostPosted: Mon May 30, 2022 12:24 pm Reply with quote Back to top
You would get way to much lever travel to the point that it likely comes back to bar. The ST master cylinder works a single front disc as the second is slaved to the rear master cylinder.
1975 CB400 four
2012 ST1300
1982 CX500 Turbo
1976 CB750 Super Sport
1987 VFR700F
1985 VF1000R
1984 GPZ900R
1978 BMW R100RS
1991 FJ1200
spammy
PostPosted: Mon May 30, 2022 1:06 pm Reply with quote Back to top
Thanks for your advice. I might just have to buy a rebuild kit for my existing BMC and clean it up a little.
PostPosted: Mon May 30, 2022 4:41 pm Reply with quote Back to top
There are plenty of these available on eBay. I actually used a CBR600 BMC on my bike. It works great and has adjustable lever. Here is a 16mm replacement that will work:
eBay Link
Here is a picture of the BMC on my bike (make sure anything you buy says it is compatible for dual caliper brakes).
1981 CB900F = Sold 2024
spammy
PostPosted: Mon May 30, 2022 9:23 pm Reply with quote Back to top
Thanks for the info. After I get home from work I’m going to have a good look at them. Cheers.
