  • Total: 107,432,261
  • Today: 1,744
  • May 26, 2026
  • 01:07 am PDT
Pontus
PostPosted: Thu Apr 08, 2021 5:33 am Reply with quote Back to top
Are these the correct version for a European CB1100F?
Does anyone have a link to a company that does refinishing of mirrors? Or a link to some DIY material? I've been thinking about learning to powder coat. What about cutting and fitting new mirror glass?
2x 1983 Honda CB1100F Super Bol D'or
1973 BMW R90S
2x 1977 BMW R100RS
1x 1991 BMW R100GS PD (custom)
metalganz
PostPosted: Thu Apr 08, 2021 8:40 am Reply with quote Back to top
Yes these are the correct ones for the European 1100F, maybe there is someone on the forum who has done it before (cutting the glasses)
Pontus
PostPosted: Thu Apr 08, 2021 10:28 am Reply with quote Back to top
I wonder if there arms and the mirror frame can be separated if the glass is removed. Maybe there is a screw underneath? I'm not sure how the mirrors could be powdercoated otherwise.
1973 BMW R90S
2x 1977 BMW R100RS
PostPosted: Thu Apr 08, 2021 10:39 am Reply with quote Back to top
Tom K has re-finnished these mirrors to look like new. He is able to disassemble and powder coat them to a gloss black that looks very close to the original "black chrome"
Cheers!
PostPosted: Thu Apr 08, 2021 11:35 am Reply with quote Back to top
+1 on TomK.
He's done several sets for me and they all look perfect.
The glass was also used on several other Honda models, I just don't recall which ones. I'll find them at the local breakers and snap them up for $5 or less.
PostPosted: Thu Apr 08, 2021 11:57 am Reply with quote Back to top
I believe the mirrors on the Nighthawk 750S are almost identical, except that they're chrome plated. Over the years I've bought several pairs on eBay, then disassembled, blasted, and powder coated to look just like 1100F mirrors. So yes, they can be disassembled, but, it takes a little time and patience to separate the rubber/mirror from the mirror body. If you rush or are too rough, the glass will break. Once the glass is out, they can be totally disassembled with at least 5 pieces per mirror that can be refinished. I've done a couple dozen of these with good results. I use a 90% high gloss black that looks close to the original finish.
