spammy
Tue Aug 25, 2020 11:29 am |
So I received a Forseti complete engine gasket set today, first time I had ever ordered one and it came with 16 valve stem seals which I didn't expect and I think is a huge bonus as they can be expensive by themselves. I paid AU $130. What do you guys think or what is your experience. Thanks. |
Tue Aug 25, 2020 12:49 pm |
Get a set of Viton Valve Stem seals from Genesound, as well has the hardened cam cap bolts, and use them in your build. |
_________________ 1982 CB 985F
Tue Aug 25, 2020 3:19 pm |
Every complete gasket kit I have ever had. Came with the valve guide seals. I through all of them away and buy Viton seals from Genesound. |
1337
Tue Aug 25, 2020 3:29 pm |
The viton seals that Genesound sells are superior. |
_________________ 1983 Honda CB1100F
1980 Suzuki GS1000E
2009 Yamaha FZ1
2006 H-D Fatboy |
DirtyT
Tue Aug 25, 2020 5:17 pm |
| cliffiec wrote: |
+1 A lot of the valve seals out there are crap - they don't last. The viton seals sold by Genesound are first rate, everyone should use them. I highly recommend the hardened cam cap bolts as well, the OEM bolts are too easy to snap - and when that happens you're in deep poo. Ed |
Tue Aug 25, 2020 9:04 pm |
Thanks guys.
Just click on the blue links in my sig for more info.
Shipping to Oz for the bolts is a bit spendy due to weight, but they still come out cheaper than the stock OEM bolts, and they're far superior. |
spammy
Tue Aug 25, 2020 11:18 pm |
Thanks for the advice, do the bolts still snap if torqued correctly. |
Wed Aug 26, 2020 1:21 am |
They're much stronger than the stock bolts, which I believe were over spec'd at 9-12 ft lbs.
I broke stock bolts torqued to 10.5 ft lbs with a high dollar SnapOn inch pound torque wrench many years
ago. 12 ft lbs is really too much for the stock ones, and unnecessary. I think Brent said he sets his at 8 ft lbs.
| In the 12.9 Cam Holder Bolts ad linked below, I wrote: |
Grade 12.9 6 mm socket head bolt kits with washers for the cam holders (cam tower caps) are much stronger
than the stock bolts. The stock Honda bolts like to break. The guys that have tried these on the DOHC I-4s and
CBXs really like them. I did a rudimentary stress test, and they held over 14.5 ft lbs without any problem, and
felt very firm. I recommend about 9 ft lbs on them, so as not to overburden the threads in the aluminum head.
These require a 5mm Allen Head driver. |
spammy
Wed Aug 26, 2020 9:41 am |
Good to know all this, I hate snapping bolt heads. |
Wed Aug 26, 2020 10:49 am |
| spammy wrote: |
Yup, BTDT... |
sixdog
Wed Aug 26, 2020 2:39 pm |
plus one on the bolts!!!!! |
_________________ 82 CB1100R
79 CBX Red
84 VF1000F Interceptor
79 CB650
82 GS1000 Katana
80 Suzuki GS1000s Wes Cooley
83 Kawasaki KZ1000 ELR
82 Kawasaki GPZ1100B2
72 Kawasaki H2 750
02 Honda CBR1100XX
86 VFR750
86 Yamaha FZ750 |
