  • Total: 105,205,053
  • Today: 116,273
  • Apr 28, 2026
  • 11:30 pm PDT
spammy
PostPosted: Sat Jul 04, 2020 2:28 pm Reply with quote Back to top
Hi Guys, I removed my clutch cover and found a thin layer of a white milky substance on the inside of my clutch cover. I'm sure it's not good. I cleaned the cover and changed my oil.
PostPosted: Sat Jul 04, 2020 3:09 pm Reply with quote Back to top
Do you start your bike up for just a few minutes at a time often? This will cause that.
cntrhub
PostPosted: Sat Jul 04, 2020 6:52 pm Reply with quote Back to top
Condensation build. Like running short errands. Water mixed with oil. Say a water cooled engine, the oil mixes with a blown head gasket leak and turns the oil a tan milky color. Heat the bike up longer. And no, can't let an air cooled engine sit idling for 15 minutes. And yes, a short run and letting it idle in the driveway for 5 minutes or less, sure. But that's hours off the engine not ridden, you make that the habit.
PostPosted: Sat Jul 04, 2020 8:30 pm Reply with quote Back to top
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&p=696637&highlight=mayonnaise#696637
spammy
PostPosted: Sun Jul 05, 2020 6:28 am Reply with quote Back to top
Yes I do have a tendency to warm up the bike and turn it off, thanks for the comments. I'll change my habits. Cheers.
