  • Total: 123,280,344
  • Today: 31,140
  • Nov 24, 2026
  • 02:13 am PST
thegeneral000
PostPosted: Mon Jun 15, 2020 12:49 am Reply with quote Back to top
Hi I know its probably a silly question, but do ya'll know if its safe to use simple green on these engines? I''m trying to get the cases and blocks ready for paint and was thinking about cleaning everything with simple green. All the engine blocks, cases and covers have been stripped of paint so it will be simple green (diluted probably) directly on the aluminum parts.
If simple green is no good, what should I use?
Thanks in advance.
PostPosted: Mon Jun 15, 2020 1:37 am Reply with quote Back to top
If repainting, yes.
Frankly, I use Superclean for what you're doing.
cbx1956
PostPosted: Mon Jun 15, 2020 3:36 am Reply with quote Back to top
POR-15 cleaner/degreaser. Without a doubt the best- I've used it many times when engine prepping & painting.
TCRacing
PostPosted: Mon Jun 15, 2020 4:28 am Reply with quote Back to top
Here’s an option from the makers of Simple Green.
Simple Green 13405 Extreme Aircraft and Precision Cleaner
Back into the 80's
1981 CB750F
AFM # 919
AMA # 454
Current TCR Projects:
1982 CB750F
1983 CB1100F X SOLD
Lindy
PostPosted: Mon Jun 15, 2020 9:38 am Reply with quote Back to top
Ive also used mag wheel cleaner, its a mild acid and will slightly etch aluminum
thegeneral000
PostPosted: Mon Jun 15, 2020 12:05 pm Reply with quote Back to top
Thanks for all the help!
thegeneral000
PostPosted: Mon Jun 15, 2020 12:11 pm Reply with quote Back to top
Do you use the POR metal prep afterwards?
PostPosted: Mon Jun 15, 2020 12:42 pm Reply with quote Back to top
The basic truth is to use whatever will clean the metal, but the mandatory last step (for best results...) prior to applying paint is a thorough wipedown with lacquer thinner, to prepare the metal to bond with the paint.
cbx1956
PostPosted: Mon Jun 15, 2020 9:15 pm Reply with quote Back to top
I first use paint stripper to get the worst of the muck & any old flaking paint off then it's a question of several applications of the POR 15 together with a stiff paint brush to get a clean finish. As someone else pointed out you do need a final wash down with thinners to get rid of any residue; I use a spray bottle with thinners & another stiff brush- it helps to have the engine mounted on a stand so that I can swing the engine around at all angles allowing a decent run off to a catchment tray on the ground. I do not use any form of media blasting on the motor- just liquids, & elbow grease. It's a tedious job but rewarding
thegeneral000
PostPosted: Tue Jun 16, 2020 12:02 pm Reply with quote Back to top
Thank you this helps a bunch, nice to have some direction to go towards.
PostPosted: Tue Jun 16, 2020 5:04 pm Reply with quote Back to top
In addition to what others have said, keep in mind that Simple Green will strip metal finish, i.e. zinc and cad plating, off if left on long enough. Probably not an issue for cleaning an engine but be sure to rinse well.
Nunzio
PostPosted: Fri Jun 19, 2020 1:57 am Reply with quote Back to top
Lindy wrote:
I've also used mag wheel cleaner, its a mild acid and will slightly etch aluminum
I have done that too as well. Its a good idea, I've followed up with an etch primer for engines prior to painting the engine.
CB750F Super Sport
GL1000
CX500TC
