  • Total: 118,264,930
  • Today: 38,846
  • Oct 25, 2026
  • 09:05 am PDT
PostPosted: Thu Jun 11, 2020 6:38 pm Reply with quote Back to top
How does one remove the light and socket from the rear of the speedometer and/or tachometer without destroying them.
PostPosted: Thu Jun 11, 2020 9:08 pm Reply with quote Back to top
Thought I read WD 40
PostPosted: Wed Jun 17, 2020 1:47 pm Reply with quote Back to top
WD 40 worked with a little technique. Spray WD40 while applying slight lift to the edge of the rubber. Some WD wo accumulate around the rubber, DON"T try to pry light socket out at this point. Work a small slat screwdriver around the rubber allowing Wd to sink into the meter socket. Do That several times the take TWO screwdrivers and gently work the rubber bulb holder out of the meter.
Thanks for the help Hondo.m
PostPosted: Wed Jun 17, 2020 1:50 pm Reply with quote Back to top
Patience and persistence, good on you, Mike!
Wulph
PostPosted: Thu Jun 18, 2020 1:47 am Reply with quote Back to top
Coat the rubber with a light layer of silicone grease before you re-install them into the instruments. Should prevent future problems removing them.
PostPosted: Fri Jun 19, 2020 1:10 am Reply with quote Back to top
My fingers hurt for a month after I pulled mine out - very frustrating job. I used lots of silicone on them when they went back in but hopefully I'll never have to pull them again.
PostPosted: Fri Jun 19, 2020 1:28 am Reply with quote Back to top
Thinking it through probably most anything will work. Even Dove dish soap?
1980CB750F
PostPosted: Fri Jun 19, 2020 12:53 pm Reply with quote Back to top
Try Palmolive, softens your hands while you pull the bulbs.
PostPosted: Fri Jun 19, 2020 6:28 pm Reply with quote Back to top
I see what you did there. ... Laughing
PostPosted: Fri Jun 19, 2020 9:50 pm Reply with quote Back to top
Such a great site. first helpful advise and then sublime rhetoric to follow. What's not to love?
PostPosted: Sat Jun 20, 2020 12:54 am Reply with quote Back to top
Ha, Madge said "You're soaking in it."
