  • Total: 122,917,446
  • Today: 50,475
  • 09:28 am PST
Pistonbroke
PostPosted: Fri Sep 27, 2019 4:18 pm Reply with quote Back to top
Hi all, new to this Super Sport Website but already found loads of interesting stuff here. I'm not really authorized to join in, since my Super Sport is actually a 1979 CBX BUT... it has been outfitted (by the prior owner) with 1983 CB1100F Suspension, Wheels and Brakes, so maybe i get a reprieve ?
The forks are pitted and have gotten the fork seals to start leaking, so i'm going to remove them, get 'em re-chromed and re-valved & sprung by Race Tech Suspension.
I have one question - the Air collars on these forks are located just above the lower steering yoke / Triple Tree (a new term for this Brit that i keep seeing) but in all the 1100F photos i have seen here, the collars are up at the top of the forks, underneath the Top Yoke ...... Anyone know what version of CB1100 that these forks might have actually came from ?
Not a big deal either way, they're likely going to be a pain to remove regardless Rolling Eyes
Regards, Kev
PostPosted: Fri Sep 27, 2019 4:45 pm Reply with quote Back to top
Nice Bike......I'd love to own that.....
PostPosted: Fri Sep 27, 2019 5:01 pm Reply with quote Back to top
Welcome to the site, and you are MORE than welcome to ask question, offer advice and take full advantage of this site.
Nice cross breed you have there!!
Take Care,
PostPosted: Fri Sep 27, 2019 5:58 pm Reply with quote Back to top
Nice bike. That was a popular mod some years ago.
Alt1
PostPosted: Fri Sep 27, 2019 7:19 pm Reply with quote Back to top
Welcom to the site. Very sharp looking cbx!
1979 CB750K
1980 CB750F - Sold
1982 Cb900f - Build thread http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=87893&highlight=
chico
PostPosted: Sat Sep 28, 2019 12:21 am Reply with quote Back to top
Kev, you might want to join/post on the CBX forum:
http://www.cbxworld.com/index.php
Chico
´79 CBX sold
"83 CB 1100 Red
´99 Valkyrie Interstate sold
2000 Harley Fatboy
2005 Softail Deluxe
´07 Yamaha FZ traded
'17Triumph Tiger 800
'17 Triumph Bobber
cbxsix
PostPosted: Sat Sep 28, 2019 12:35 am Reply with quote Back to top
You're correct in your assumption that the air bridge/collar should be at the top, below the top triple tree. My guess but you would know if you have pressurized the system, is that your collar isn't even functional, just slid down the forks to get them out of the way.
Many guys thought the air system was a pain in the ass and pretty insignificant as far as functionality, so they would remove the bridge altogether and either epoxy or use an allen head screw to seal the orifices in the fork tubes.
Racetech will do that for you, I think they still use the epoxy method.
PostPosted: Sat Sep 28, 2019 1:21 pm Reply with quote Back to top
If your tubes are pitted AND you may want to eliminate the air system, you might be further ahead to just have new tubes made.
Forking by Frank makes stock tubes or modified to your needs. I've used them many times and definately a quality product. (Better than re-chroming).
Additionally, replace the upper and lower internal bushings (still available from Honda). In that way everything will be new and tight.
cbxsix
PostPosted: Sat Sep 28, 2019 1:54 pm Reply with quote Back to top
Just to answer your original question, that should be the Canadian CB1100F version, the tubes are a few inches longer to accommodate the clipons, the US version has a handlebar setup that mounts to the top of the triple tree, hence the tubes are shorter.
PostPosted: Sat Sep 28, 2019 3:45 pm Reply with quote Back to top
Beautiful bike, Kev.
I see the nice chrome chain guard, is the 1100F swingarm on there as well?
Pistonbroke
PostPosted: Fri Oct 25, 2019 3:25 pm Reply with quote Back to top
Thanks for all the input guys - sorry for delayed response, was out of town. So when i took the fork tubes off, previous owner who did the transfusion has jb-welded the top original air holes and re-drilled the tubes where the air collars currently sit (floating !). I think because with the CBX clocks. ignition etc. there's no room for the collars and link pipe up top. Race tech guys are going to block off those lower holes also now and set the system up for no air-assist. Smurdoch - yes the swingarm is 1100F also.. Thanks guys..
