  • Total: 118,152,463
  • Today: 24,479
  • 05:56 am PDT
PostPosted: Sun Aug 19, 2018 8:04 pm Reply with quote Back to top
Where are you guys sourcing the bearings (2) that are inside the gear in the back side of the clutch? Part number 91010-300-008.
Here's a link for the part. Would like to have a known high quality bearing.
https://www.partzilla.com/product/honda/91010-300-008
PostPosted: Sun Aug 19, 2018 9:02 pm Reply with quote Back to top
Hi Nathan
I think you need a HK2520 as your link shows 25 x 32 x 20
http://www.skf.com/group/products/bearings-units-housings/roller-bearings/needle-roller-bearings/drawn-cup-needle-roller-bearings/drawn-cup-pt/index.html?designation=HK%202520
I changed some in one of my baskets which were HK2516 25 X 32 X 16 as some baskets have narrower bearings fitted
Testr
PostPosted: Sun Aug 19, 2018 9:24 pm Reply with quote Back to top
I started out to do this same job as well. Is there anything between the two bearings that would prevent them from being pressed out/in from one side? Like a spacer or a ridge? beerchug
PostPosted: Mon Aug 20, 2018 4:42 am Reply with quote Back to top
They should just slide in/out with very very little effort...they literally should fall out if you turned the basket on it's side.
PostPosted: Mon Aug 20, 2018 5:18 am Reply with quote Back to top
The one I did with narrow bearings had a wire circlip holding the bearings in
houredout401
PostPosted: Mon Aug 20, 2018 4:15 pm Reply with quote Back to top
Believe it or not, I ordered them from Amazon.
PostPosted: Wed Aug 22, 2018 12:20 am Reply with quote Back to top
Ordered a couple NTN bearings for this off Amazon today. We'll see how they are.
PostPosted: Wed Aug 22, 2018 12:56 am Reply with quote Back to top
Let me know would you please.
PostPosted: Wed Aug 22, 2018 2:45 am Reply with quote Back to top
I told Nich for you already Laughing
F-crazy
PostPosted: Wed Aug 22, 2018 3:27 am Reply with quote Back to top
Haha except I don’t order parts for Greg. He orders his own and they show up at my door!
I’ll glady pass it on though Smile
79 CB750F
72 CB500F
75 CB360T cafe racer
65 Triumph T100SC
66 Triumph T120 bobber
PostPosted: Wed Aug 22, 2018 11:01 am Reply with quote Back to top
I am still tryng to decide on the best clutch disc and plate setup. Everything else is ready to go
Testr
PostPosted: Wed Aug 22, 2018 9:51 pm Reply with quote Back to top
Thanks. I checked out mine which has the wider bearings so there was no circlip. They're in there pretty tight - certainly not 'fall out' loose. No problem, a little heat and a press will do it.
PostPosted: Thu Aug 23, 2018 12:32 am Reply with quote Back to top
Came right out with a press and the proper sized tool to push. I didn't use heat.
PostPosted: Sat Aug 25, 2018 4:05 pm Reply with quote Back to top
Sorry guys, I was thinking about the 900 clutch Embarassed
PostPosted: Sun Aug 26, 2018 10:07 am Reply with quote Back to top
Mine is a 900 clutch. There is a ball bearing which I have but then there are two needle bearings on the ID of the spur gear. Those two needle bearings are the ones I'm talking about.
