  • Total: 123,006,897
  • Today: 3,313
  • 12:24 am PST
ChrisLeeDesign
PostPosted: Mon Jun 18, 2018 7:48 pm Reply with quote Back to top
Hey everyone, now that the exhaust stuff has died down, I have access to a HAAS VF-2 CNC at school, as well as 2x Tormach 770PCNC's. I'm looking for something to make for our CB-F bikes that can be machined on a 3-Axis machine. I think I have time to do one run of a product so if everyone on here can come to an agreement as to what part they would like, I can do a run for anyone that is interested.
Things off the top of my head:
1) Alt. Cover or the Left crankcase point cover.
2) 11F Key cover (to replace that plastic part that no one can find) https://www.partzilla.com/catalog/honda/motorcycle/1983/cb1100f-a-super-sport/handlebar-top-bridge #13
3) triple tree
4) fork brace
5) foot pegs
6) brackets for daytona steering damper
I can design and model everything in CAD and setup tool paths for the machine in mastercam or fusion 360. I'll just need some time to design/draw/and do a quick prototyping run on my personal cnc machine to make sure all the holes lineup and what not. I'll only do a run for how many ppl are actually interested, not going to make extra to have stock of and no idea if I'll have time for this again. I have the whole summer to mess with the machines.
If this is something everyone here is interested in, I'd be willing to do it to further my skills in manufacturing, more specifically in CNC machining.
Let me know if I can help!
Edit: Also can make parts on a HAAS CNC Lathe.
CB Something in the works.
djf18374
PostPosted: Mon Jun 18, 2018 8:08 pm Reply with quote Back to top
Machining a set of dropped triples, so we can use modern sportbike (shorter) forks. That would be fantastic!
Do you think it'd be possible to make just brackets that could be epoxied to the fuse cover? Something to attach on the normal mount point and glue to a larger area on the underside of the cover.
79 CBX (silver)
81 CB900F (silver)
83 CB1100F (red)
PostPosted: Mon Jun 18, 2018 8:13 pm Reply with quote Back to top
My vote would be for something not on your list - some nice headlight mounting brackets for adapting a stock 750F/900F headlight bucket onto 1100F triples. I presently use a modified 900F bracket with spacers to take up the slack, but something custom would be sweet.
ChrisLeeDesign
PostPosted: Mon Jun 18, 2018 8:38 pm Reply with quote Back to top
Both are doable.
If enough people are interested in the dropped triples, I can work on that.
For the fuse cover, I can actually plastic injection mold a piece that everyone can epoxy underneath. Currently I have ABS and Delrin as plastic materials to feed the plastic injection machine.
ChrisLeeDesign
PostPosted: Mon Jun 18, 2018 8:39 pm Reply with quote Back to top
I can definitely do this as well!
Keep the good ideas coming! If we can get like 5-10 ppl to agree on a part than I will start. Majority rules.
Guess I should add that I can do tooling and mold making for the plastic injection molder.
Bone
PostPosted: Mon Jun 18, 2018 8:59 pm Reply with quote Back to top
I have already had a set of triples machined by Ricci Engineering for a set of Yamaha FZ1 forks, so that is not on my list. New points covers are still available, in fact I had one delivered just last week, so no need there. What appears to be very hard to get hold of is an alternator cover (right side engine) in good condition. Also mounts for steering damper hard to get hold of. So my vote is for:
Right side alternator cover
Steering damper mounts
Regards,
1982 CB900FC
1981 CB900F2B
PostPosted: Mon Jun 18, 2018 9:34 pm Reply with quote Back to top
Regards,
If you are making alternator covers make them for The R's. I'm sure you will get a few takers if the price is reasonable .
swiftnick
PostPosted: Mon Jun 18, 2018 10:54 pm Reply with quote Back to top
Regards,
Yeah, my first thought was wombats.
1975 CB400 four
2012 ST1300
1982 CX500 Turbo
1976 CB750 Super Sport
1987 VFR700F
1985 VF1000R
1984 GPZ900R
1978 BMW R100RS
1991 FJ1200
PostPosted: Mon Jun 18, 2018 11:42 pm Reply with quote Back to top
Luckysox wrote:
If you are making alternator covers make them for The R's. I'm sure you will get a few takers if the price is reasonable.
Only if you can use the 900f/1100f of rotor and stator, otherwise only 1100R people could use them and it would be low demand part. If you can use the part on any bike perhaps demand would be better.
PostPosted: Mon Jun 18, 2018 11:54 pm Reply with quote Back to top
How's the build going Chris?
PostPosted: Tue Jun 19, 2018 12:56 am Reply with quote Back to top
Pretty simple part, and plastic rather than metal, but they are a lot of 1100's (and several 900's with 1100 forks) that are missing the adjustment caps.
PostPosted: Tue Jun 19, 2018 1:04 am Reply with quote Back to top
Use the yami rotor and stator
PostPosted: Tue Jun 19, 2018 1:13 am Reply with quote Back to top
I did not know that fit, that is great to know. Go ahead and reproduce the wombat cover.
And I have the Ohlins steering damper mount hardware if you want to reproduce it, then you can use the Ohlins SD003 damper in builds.
PostPosted: Tue Jun 19, 2018 2:00 am Reply with quote Back to top
I would like to know where that damper mounts. Underneath the triple or on the side?
PostPosted: Tue Jun 19, 2018 2:22 am Reply with quote Back to top
Mine mounts right side, probably better to remove the harness clamp that is there. I think the left side would be better since the frame has less stuff going on there.
This is a 90mm stroke Ohlins damper, it appears it could work but leaves little margin if the steering stops are slightly different. The SD003 is a 120mm stroke.
PostPosted: Tue Jun 19, 2018 2:54 am Reply with quote Back to top
These are the two parts needing fabricating
Bone
PostPosted: Tue Jun 19, 2018 4:00 am Reply with quote Back to top
Will that steering damper fit with the F2 fairing?
Hello Don, I have been very busy with work. On the negotiating team for our new contract and also started training to be a training captain. 'Rebuild' is still just 'parts collecting' at the moment!
1982 CB900FC
1981 CB900F2B
PostPosted: Tue Jun 19, 2018 1:40 pm Reply with quote Back to top
Damper fork mount for mounting on left side.
huck731
PostPosted: Tue Jun 19, 2018 2:39 pm Reply with quote Back to top
The opposite would be nice to. a simple bolt in bracket for 1100f to 750/900f
1981 cb750f
1969 cb77 superhawk
1984 vf700f
PostPosted: Tue Jun 19, 2018 2:49 pm Reply with quote Back to top
Don't know for sure but I doubt it. At the left side steering stop the damper swings out.
I already have the damper brackets modeled for both left and right side mount and I'll supply the model for a set of left side mounts.
Cary
TCRacing
PostPosted: Tue Jun 19, 2018 4:24 pm Reply with quote Back to top
PM sent for my request.
Back into the 80's
1981 CB750F
AFM # 919
AMA # 454
Current TCR Projects:
1982 CB750F
1983 CB1100F X SOLD
Lee12871
PostPosted: Tue Jun 19, 2018 4:26 pm Reply with quote Back to top
I would be in for a set of the damper mounts. Its seems they are a hard to find parts. Ive seen a few threads on here about them.
Leroy Jenkins
1980 cb750f (rebuild in progress)
PostPosted: Tue Jun 19, 2018 5:04 pm Reply with quote Back to top
Steering damper brackets. A component just about everyone could use.
I'd be "IN" for a couple sets, initially.
metu71
PostPosted: Tue Jun 19, 2018 6:15 pm Reply with quote Back to top
How about having some of those oil lock pieces #51432-MG5-671 inside CB1100F fork. Those are usually broken or abused.
-Pasi-
swieland
PostPosted: Tue Jun 19, 2018 9:34 pm Reply with quote Back to top
A lot of good ideas so far. If it comes down to steering damper brackets I will be in for a couple sets also. Your awesome Chris!
ChrisLeeDesign
PostPosted: Tue Jun 19, 2018 11:25 pm Reply with quote Back to top
Looks like steering damper bracket is winning.
for those interested, are the ohlins steering damper the one that everyone wants? If so, I can ask my buddy to see what kind of a discount he gets on those. I'll have to double check but I remember he has an account with ohlins and daytona.
If I end up making the steering damper brackets, the other ideas are still valid so time willing, I will get to those after. I really love these damn bikes so making things for them gives me a lot of joy.
PostPosted: Tue Jun 19, 2018 11:30 pm Reply with quote Back to top
Does he have a Time Machine ? They stopped making those brackets many years ago .
ChrisLeeDesign
PostPosted: Tue Jun 19, 2018 11:33 pm Reply with quote Back to top
Sorry, I meant the dampers. He gets discounts on ohlins and daytona dampers.
Nunzio
PostPosted: Wed Jun 20, 2018 9:09 pm Reply with quote Back to top
It took me almost 8 years to score the damper brackets and damper. I'd like a LH SET, easier to adjust on the fly.
CB750F Super Sport
GL1000
CX500TC
Page Generation: 0.27 Seconds
