  • Total: 104,234,913
  • Today: 49,177
  • Apr 16, 2026
  • 02:21 pm PDT
MyCBF
PostPosted: Thu Mar 01, 2018 12:46 am Reply with quote Back to top
Death wobble, intense crash and sliding between the tires of a semi.
Check the video
https://www.youtube.com/watch?v=ezf5oeP3eRE&feature=youtu.be
basmn
PostPosted: Thu Mar 01, 2018 2:34 am Reply with quote Back to top
WOW!!!!! I would buy a loto ticket if i were him 😉
81 750F stock
83 1100F stock
08 FZ1
03 YZF R6 track only
XR100 pit special
CRF 230F
2018 Polaris 570..for me..
1981CB
PostPosted: Thu Mar 01, 2018 10:32 am Reply with quote Back to top
Shocked that is insane. How the hell he managed to walk away from that beggars belief.
vince83
PostPosted: Thu Mar 01, 2018 7:52 pm Reply with quote Back to top
I have had that wobble on a Jeep before, caused by front end issue, what causes it in a motorcycle... Stem Bearing???
mwe
PostPosted: Thu Mar 01, 2018 8:27 pm Reply with quote Back to top
In this case likely a wheelie
n8n8n8
PostPosted: Fri Mar 02, 2018 1:55 am Reply with quote Back to top
I like that he says he's glad he wore his gear while looking at his bloody knee and sneakers. Not that boots and real pants would stop a semi truck tire. I can't recall the last time I left it in 1st all the way 80mph either. Sheesh, what a lucky mother fucker! Now he'll probably go home and die in his sleep.
1981 900f
PostPosted: Fri Mar 02, 2018 2:49 am Reply with quote Back to top
Or get a hangnail and die of an infection...
PostPosted: Fri Mar 02, 2018 3:08 am Reply with quote Back to top
That and a combination of a myriad of other factors.
vince83
PostPosted: Fri Mar 02, 2018 3:19 am Reply with quote Back to top
DonR can you explain some other factors...
PostPosted: Fri Mar 02, 2018 6:54 am Reply with quote Back to top
Tyre pressure, condition and settings of your suspension, load distribution if carrying gear etc.
PostPosted: Fri Mar 02, 2018 7:35 am Reply with quote Back to top
... frame damage, tire damage, incorrect tire sizes or tire wear issues, swing arm axle and bearings, wheel axles and bearings, bike modifications ...
1981CB
PostPosted: Fri Mar 02, 2018 12:34 pm Reply with quote Back to top
Also the video didn't show the lead up to the head shake. Its possible he was coming down from a wheelie or something and that just may be enough in combination with with another factor to cause it.
PostPosted: Fri Mar 02, 2018 12:49 pm Reply with quote Back to top
What is the best, immediate action to respond to such a wobble? Accelerate? Brake? Loose grip on bars and steady throttle? Death grip on bars?
Although it goes against natural instinct, I would accelerate (lighten front end)(while sphincter initiates suction hold on seat).
Steve
‘79 CB750(810)F, \'81 CB900(985)F, \'82 CB900(Going to be 1100)F, \'82 CBX, \'06 WeeStrom, ’18 Kawa Z900RS \'22 CanAm Ryker Rally
LightsOut
PostPosted: Fri Mar 02, 2018 1:07 pm Reply with quote Back to top
Steve
What's being taught at driving school where I live is to let go of the throttle and move your bodyweight a bit forward and squeeze the tank with your knees. Never had it happen personally though.
PostPosted: Fri Mar 02, 2018 1:17 pm Reply with quote Back to top
A friend/co-worker had that happen while cycling on his road bike one afternoon. He was going down a fairly steep hill at over 50mph. Front wheel starting wobbling uncontrollably and he finally lost it and went down. Except for some bad scrapes and cuts, he was ok. No broken bones or sprains. They suggest the same course of action when it starts - squeeze the center bar with the knees and let it slow down.
After what happened to my friend, I no longer feel the need to hit top speed while pedaling downhill.
Simon_CB900
PostPosted: Sat Mar 03, 2018 9:12 pm Reply with quote Back to top
Steve
Kiss yer arse goodbye, I expect Laughing
Simon.
\'81 CB 750/900 mongrel Smile
