  • Total: 118,472,648
  • Today: 13,922
  • Oct 27, 2026
  • 01:42 am PDT
jt
PostPosted: Mon Feb 05, 2018 4:18 am Reply with quote Back to top
Does anyone have a source for a 6mm Right hand thread Heim joint to replace on a shifter? Want it with a stud mount. Would like it to be sized similar to OEM. I've searched but most are bigger and or clunky looking.
Jt
jcooper
PostPosted: Mon Feb 05, 2018 4:48 am Reply with quote Back to top
Hi JT,
Here is where I got mine when I rebuilt my linkage.
https://www.mcmaster.com/#end-links/=n4jyvw
PostPosted: Mon Feb 05, 2018 6:22 am Reply with quote Back to top
This might help: http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=71569&highlight=shifter+linkage
PostPosted: Mon Feb 05, 2018 6:47 am Reply with quote Back to top
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&p=537920&highlight=heim#537920
PostPosted: Mon Feb 05, 2018 3:41 pm Reply with quote Back to top
This is the way I did mine using the part # info provided by Genesound:
Sport Kit Shifter Rebuild
Steve
PostPosted: Mon Feb 05, 2018 4:08 pm Reply with quote Back to top
I buy used shift linkages from Yamaha’s R-1’s and use the knuckle as it fits our shift splines. It is also made from aluminum so it is lighter than the Honda ones. Then I get the helm joint from he likes of where others have shown.
Hope that helps. Peace, Jim
jt
PostPosted: Mon Feb 05, 2018 8:24 pm Reply with quote Back to top
Thanks to all for the info. I completely forgot about these write-ups, geesh getting old Embarassed
JT in Texas
