  • Total: 118,334,935
  • Today: 9,311
  • Oct 26, 2026
  • 02:12 am PDT
techie66
PostPosted: Wed Dec 06, 2017 6:23 am Reply with quote Back to top
So this isn't 'F related at all, but we're all gear heads to a point. I recently got an old, broken industrial walk behind lawn mower. It's got many of the little bits needed to make a go-kart. The engine is a kawasaki fh451v. That has OHV 494cc, aluminum block, cast iron sleeves and full pressure lube. Rated power is only 15hp @ 3600rpm.
I'm making off the cuff assumptions here, but it seems the engine could easily do 30hp if not more. Where would you guys start looking to beef up an engine like this. Just looking for ideas since I got this for free'99 and would like to do something with it.
Jacob
1983 CB1100F Blue
2010 HD XL1200X 48
My Mods Page
PostPosted: Wed Dec 06, 2017 5:14 pm Reply with quote Back to top
Its all in the intake, compression and exhaust. I'm not being flippant but factual as these areas are where your answer resides.
techie66
PostPosted: Wed Dec 06, 2017 5:28 pm Reply with quote Back to top
Thanks Captain. Honestly I'm quite new to those areas. I would think tuning the exhaust to maximize cylinder evacuation at particular rpm ranges, and also maximize flow on both sides. My rudimentary understanding on increasing compression would look towards raising piston crown, and lowering combustion chamber perhaps just by skimming down the squish area. Am I on the right track here?
I have a real concern about this as I don't know if the rods, Pistons, bearings, etc can handle higher rpms or even the added stress of more compression and power.
Jacob
1983 CB1100F Blue
2010 HD XL1200X 48
My Mods Page
dannewman
PostPosted: Wed Dec 06, 2017 5:47 pm Reply with quote Back to top
15 HP is quite a bit for a regular go-cart. Open up the exhaust ,,,
900F 82'
techie66
PostPosted: Wed Dec 06, 2017 6:34 pm Reply with quote Back to top
You might be a wise voice of reason. I probably don't "need" more power, but I want it.
Jacob
1983 CB1100F Blue
2010 HD XL1200X 48
My Mods Page
djhurayt
PostPosted: Wed Dec 06, 2017 9:27 pm Reply with quote Back to top
If some power is good,
Then more is better,
And to much is just right!
dannewman
PostPosted: Thu Dec 07, 2017 12:21 am Reply with quote Back to top
We've had em' here with snowmobile motors. Scary with the wrong driver. One rolled five times,,,
900F 82'
PostPosted: Thu Dec 07, 2017 7:02 am Reply with quote Back to top
is it a single carb to twin branch manifold with the carb governor controlled ? - recon swapping this lot out for a twin carb direct lift - TBH just manually op versus governor will add some vavavavoom
check if its got steel or alloy rods - if its like a briggs n stratton - alloy rod then rpm is limited before they snap - recon you'll still manage another 1000rpm
probably find a wee bit via ignition timing
techie66
PostPosted: Thu Dec 07, 2017 2:50 pm Reply with quote Back to top
That's exactly the setup. I had the thought to try some rs36's, but I don't have that kind of cash.
Question What if I put Mikuni's on my F, then put two of those CV's on the kart? I'm sure that'd be a joy to tune. Razz
Idea Thanks for that advice!
Jacob
1983 CB1100F Blue
2010 HD XL1200X 48
My Mods Page
PostPosted: Thu Dec 07, 2017 5:26 pm Reply with quote Back to top
couple of small direct lift carbs from yir local bike breaker from something old and forgotten
but 1st off see if you can tweak the governor - i.e. bend it
djf18374
PostPosted: Thu Dec 07, 2017 7:48 pm Reply with quote Back to top
Techie66, I have a set of carbs from an old SOHC bike. No idea what bike or anything like that and they are all apart in pieces and filty...but they're yours if you want them!
Set of 4, maybe complete, maybe not. PM me if you want them.
79 CBX (silver)
81 CB900F (silver)
83 CB1100F (red)
n8n8n8
PostPosted: Fri Dec 08, 2017 12:33 am Reply with quote Back to top
Put a turbo on it! I just read a book on turbocharging and have had it on my mind lately. You could probably leave the motor stock and put up to 7 psi on it, which would boost power a good 20-30%. Beyond 10 psi and you'll have to start changing the engine. Turbos for small engines are not priced too high.
https://www.dhgate.com/product/hot-selling-diy-turbo-500-turbo-kit-motorcycle/214174143.html?u
http://www.ecotrons.com/products/small_engine_rhb31_vz21_turbocharger/
1981 900f
dannewman
PostPosted: Fri Dec 08, 2017 12:57 am Reply with quote Back to top
The small dragsters running a 5 hp Briggs & Statton base block have produced around 19hp. some good ideas right there,,,
900F 82'
PostPosted: Mon Dec 11, 2017 1:58 am Reply with quote Back to top
A 50 shot of Nitrous would be fun as hell for a solid 10-15 seconds...
hwyman
PostPosted: Wed Dec 13, 2017 12:39 pm Reply with quote Back to top
you can also check your gearing many years ago when I rode gokarts around the neighborhood I played with the gear ratio to get more top end vs a quicker take off.
