  • Total: 114,919,010
  • Today: 50,341
  • Sep 20, 2026
  • 10:35 pm PDT
scottx
PostPosted: Thu Oct 12, 2017 8:30 pm Reply with quote Back to top
I pulled the sump off my new 1100 engine for it's 200km oil change and found this hair looking snot on rhe oil pick up.
You can see where I have cleaned it a bit.
scottx
PostPosted: Thu Oct 12, 2017 8:31 pm Reply with quote Back to top
This is what it looks like removed. Don't know what it is.
PostPosted: Thu Oct 12, 2017 8:42 pm Reply with quote Back to top
Was the previous owner a werewolf? Razz
basmn
PostPosted: Thu Oct 12, 2017 9:18 pm Reply with quote Back to top
You need a manicure Very Happy
81 750F stock
83 1100F stock
08 FZ1
03 YZF R6 track only
XR100 pit special
CRF 230F
2018 Polaris 570..for me..
PostPosted: Thu Oct 12, 2017 11:54 pm Reply with quote Back to top
Andylarkin would love this ..... Laughing
PostPosted: Fri Oct 13, 2017 5:36 pm Reply with quote Back to top
Did the engine builder have a shop cat? When I had one (I miss that cat badly) there was cat hair everywhere. I had to be very careful when building engines.
PostPosted: Fri Oct 13, 2017 6:35 pm Reply with quote Back to top
I hope that's not fibers out of an oil filter.
herdygerdy
PostPosted: Fri Oct 13, 2017 6:54 pm Reply with quote Back to top
G'day Scotty,
Given you had the engine built by another fellow, it would be worth asking him what type of shop rags he used, or comparing your gluggy hair balls to the type of rag he used.
When I did mine back in 2008/9, I thought I was scrupulously clean during my engine build. But on the first oil change when, like you, I also dropped the pan, I was amazed to see how much 'fluff' and detritus had turned up down there. And yes, we had a cat helping in the build too and his signature fur was in there too.
I think just clean it up, and then ride it like you stole it (and be happy you had the nouse to pull the pan and catch it before it caused any problems and that the screen was clearly doing its job)
God knows you well truly deserve it after all your trials and tribulations with this ride. BTW, how's yer starter motor blues?
Cheers...Tony
scottx
PostPosted: Fri Oct 13, 2017 7:16 pm Reply with quote Back to top
Yeah mate. 2 cats and he feeds them in the garage where he built my engine. I'll quiz him on it next time I see him.
scottx
PostPosted: Fri Oct 13, 2017 7:20 pm Reply with quote Back to top
I changed the oil filter and it looked to be OK. I put the oil filter in the engine only 200km ago and I used K&N which I have always bought from the same bike shop.
Maybe I'll pull the sump off in say 1000km from now to check again.
scottx
PostPosted: Fri Oct 13, 2017 7:41 pm Reply with quote Back to top
herdygerdy wrote:
G'day Scotty,
Cheers...Tony
Starter motor blues I will get to the bottom of sooner or later.
Have a good one dude
Scott
scottx
PostPosted: Fri Oct 13, 2017 9:22 pm Reply with quote Back to top
No idea what I'm doing.
I want to check the advace curve. Especially in cranking.
Hope I learn soon before ........
scottx
PostPosted: Sat Oct 14, 2017 11:55 pm Reply with quote Back to top
I'll probably sort this shit out while I'm at it.
scottx
PostPosted: Sat Oct 14, 2017 11:58 pm Reply with quote Back to top
May of come from here
PostPosted: Mon Oct 16, 2017 3:52 pm Reply with quote Back to top
Dude, you have the worst luck of anyone that I know.
You might want to take up Golfing.
PostPosted: Mon Oct 16, 2017 5:44 pm Reply with quote Back to top
Who did the R6 starter clutch, and was an authentic Yamaha unit used or a Taiwan replacement?
PostPosted: Mon Oct 16, 2017 6:43 pm Reply with quote Back to top
FWIW, it's not one of mine.
Cary
scottx
PostPosted: Mon Oct 16, 2017 8:06 pm Reply with quote Back to top
Don't know where it came from.
PostPosted: Mon Oct 16, 2017 10:08 pm Reply with quote Back to top
Rexe bought the cheaper version from eBay, read his comment on page 3.
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=71638&postdays=0&postorder=asc&highlight=starter&start=60
For what it's worth mine has 15,000 kms on it now and still starting fine. It was a second hand unit with unknown kilometres but it was an oem part which makes all the difference it seems.
PostPosted: Mon Oct 16, 2017 11:07 pm Reply with quote Back to top
I'm guessing that the centering is very critical to longevity, as well as part quality.
PostPosted: Mon Oct 16, 2017 11:18 pm Reply with quote Back to top
I have absolutely no experience with these but have followed closely in case I ever needed one............ But It looks to me very much like the old saying..............You get what you pay for.
PostPosted: Mon Oct 16, 2017 11:26 pm Reply with quote Back to top
Turning the hub like Cary does undoubtedly helps too.
PostPosted: Tue Oct 17, 2017 12:00 am Reply with quote Back to top
The failures that I have seen seem to be related to ones from Taiwan ....none that are genuine Yamaha pieces.
PostPosted: Tue Oct 17, 2017 2:34 am Reply with quote Back to top
Absolutely, I've sold about 250 units using the Taiwanese part and have only 3 failures. If the proper diameter is too large and the surface is already worn out then you'll have more failures. Also, having a bevel on the hub allows for an easy installation that could otherwise damage the sprag.
Cary
PostPosted: Tue Oct 17, 2017 2:40 am Reply with quote Back to top
Scott, make sure find all 20 dogs and it looks like the ring sheared and there are another 20 rectangular fragments to locate.
Cary
scottx
PostPosted: Tue Oct 17, 2017 4:59 am Reply with quote Back to top
I've not counted all the parts yet, but I also haven't thrown anything out.
I will get the pieces together and count them for piece of mind.
Cheers
Scott
