  • Total: 118,335,158
  • Today: 9,534
  • Oct 26, 2026
  • 02:15 am PDT
PostPosted: Wed Aug 02, 2017 6:41 pm Reply with quote Back to top
Any one know where to get rod bearings? Partzilla says not available from honda.......CMS still shows them in stock but so does Partzilla........
PostPosted: Wed Aug 02, 2017 7:59 pm Reply with quote Back to top
David Silver spares in the USA are showing some sizes
Link to CB900F Yellow rod bearings, a few other colours available
https://www.davidsilverspares.com/CB900F2C-1982/part_95258/
PostPosted: Wed Aug 02, 2017 8:16 pm Reply with quote Back to top
Do they have their own stock Keith or do they get them from Honda?
PostPosted: Wed Aug 02, 2017 8:23 pm Reply with quote Back to top
Assuming you are looking for 1100F bearings, Honda still has them if you call up the 900F ones which are the same. I just bought a set of yellows a couple weeks ago from Honda. That would be Honda Canada but regardless should be the same deal in the US.
Edit, same deal at Partzilla >>>
http://www.partzilla.com/parts/detail/honda/HP-13218-413-015.html
PostPosted: Wed Aug 02, 2017 8:36 pm Reply with quote Back to top
DSS about $6 a shell more than Partzilla Shocked
PostPosted: Wed Aug 02, 2017 8:46 pm Reply with quote Back to top
In the UK they have their own stock Russ as they sell them far cheaper than i can get them through my local Honda dealer, and their site always shows what stock levels they have
PostPosted: Wed Aug 02, 2017 8:52 pm Reply with quote Back to top
Just tried to order from p zilla and they refunded my money saying not available from honda.
PostPosted: Wed Aug 02, 2017 8:57 pm Reply with quote Back to top
http://www.partspitstop.com/oemparts/a/hon/506f8309f8700229747b8ca2/crankshaft-piston
PostPosted: Wed Aug 02, 2017 9:27 pm Reply with quote Back to top
Tried to order 1100 bearings. 900/750/cbx/sohc bearings still available. Thanks guys.
PostPosted: Thu Aug 03, 2017 12:09 am Reply with quote Back to top
Aren't the 900f bearings interchangeable with the 1100 rod bearings?
PostPosted: Thu Aug 03, 2017 12:36 am Reply with quote Back to top
Yes and are preferred
PostPosted: Thu Aug 03, 2017 5:28 am Reply with quote Back to top
Yes, but they aren't the same p/n.
On Partzilla, you can right click on the p/n and see what it interchanges with. But it's reference by the P/N. So even if the thing actually, physically fits, you still cant tell from the Parts list.
PostPosted: Thu Aug 03, 2017 10:46 am Reply with quote Back to top
I know they interchange (along with the sohc and cbx) and I also figured the part numbers were all the same. Bad assumption on my part.
PostPosted: Thu Aug 03, 2017 1:23 pm Reply with quote Back to top
That's why I said order the 900 ones ...
I paid $9 each half shell with my dealer discount at Honda.
PostPosted: Thu Aug 03, 2017 1:52 pm Reply with quote Back to top
Are the 1100F/900F crank bearings also interchangeable? My dealer pricing is pretty decent on the U.S. ones and better than Partzilla for sure.
PostPosted: Thu Aug 03, 2017 1:56 pm Reply with quote Back to top
Yes
PostPosted: Fri Aug 04, 2017 2:47 am Reply with quote Back to top
I just got some from my Honda dealer. They were 10.00 each half shell so 100.00 for a full set. They also told me those bearings are used in quite a few models so they won't be discontinued any time soon.
PostPosted: Fri Aug 04, 2017 5:00 pm Reply with quote Back to top
The call out for the 13318-MA3-003 is the 1100F only NLA
11318-425-003 fits the 1100F and
1976 CB750A A CRANKSHAFT + PISTON
1976 CB750F A CRANKSHAFT
1976 CB750K A CRANKSHAFT + PISTON
1977 CB750A A CRANKSHAFT + PISTON
1977 CB750F A CRANKSHAFT + PISTON
1977 CB750K A CRANKSHAFT + PISTON
1978 CB750A A CRANKSHAFT + PISTON
1978 CB750F A CRANKSHAFT + PISTON
1978 CB750K A CRANKSHAFT + PISTON
1979 CB750F A CRANKSHAFT + PISTON
1979 CB750K A CRANKSHAFT + PISTON
1979 CB750L A CRANKSHAFT + PISTON
1979 CBX A CRANKSHAFT + PISTON
1980 CB750C A CRANKSHAFT + PISTON
1980 CB750F A CRANKSHAFT + PISTON
1980 CB750K A CRANKSHAFT + PISTON
1980 CB900C A CRANKSHAFT + PISTON
1980 CBX A CRANKSHAFT + PISTON
1981 CB750C A CRANKSHAFT + PISTON
1981 CB750F A CRANKSHAFT + PISTON
1981 CB750K A CRANKSHAFT + PISTON
1981 CB900C A CRANKSHAFT + PISTON
1981 CB900F A CRANKSHAFT + PISTON
1981 CBX A CRANKSHAFT + PISTON
1982 CB750C A CRANKSHAFT + PISTON
1982 CB750F A CRANKSHAFT + PISTON
1982 CB750K A CRANKSHAFT + PISTON
1982 CB750SC A CRANKSHAFT + PISTON
1982 CB900C A CRANKSHAFT + PISTON
1982 CB900F A CRANKSHAFT + PISTON
1982 CBX A CRANKSHAFT + PISTON
1983 CB1000C A CRANKSHAFT + PISTON
1983 CB750SC A CRANKSHAFT + PISTON
Models with no year CB750F A CRANKSHAFT
Models with no year CB750K A CRANKSHAFT
Models with no year CB750K1 A CRANKSHAFT
Models with no year CB750K2 A CRANKSHAFT
Models with no year CB750K3 A CRANKSHAFT
Models with no year CB750K4 A CRANKSHAFT
Models with no year CB750K5 A CRANKSHAFT
PostPosted: Fri Aug 04, 2017 5:46 pm Reply with quote Back to top
1100R Part numbers from my CB1100R manual (i expect the CB1100F are the same)
13215 ma3 003 Rod Blue
13216 ma3 003 rod Black
13217 ma3 003 Rod Brown
13218 ma3 003Rod Green
13219 ma3 003 Rod Yellow
13315 ma3 003 Main Black
13316 ma3 003 Main Brown
13317 ma3 003 Main Green
13318 ma3 003 Main Yellow
13319 ma3 003 Main Blue
PostPosted: Fri Aug 04, 2017 7:02 pm Reply with quote Back to top
Simple, MA3 is the 1100R designation. Some parts got exclusive numbers, some parts didn't, probably depending on the design team, locations and other factors. All series of DOHC main and rod bearing shells with whatever middle 3 numbers are interchangeable without any functional difference.
PostPosted: Fri Aug 04, 2017 8:56 pm Reply with quote Back to top
Partzilla web site has the 1100 13218 bearing as green and the 13219 bearing as yellow Rolling Eyes That doesn't seem right Doesn't matter as the are NLA
PostPosted: Fri Aug 04, 2017 11:28 pm Reply with quote Back to top
Look up the 1982 CB900F bearings. They're still available in all the colors. The 425 designation is up to date because it's still in some level of production.
PostPosted: Sat Aug 05, 2017 1:06 am Reply with quote Back to top
I and others have said this before and will do so again.. All you need is 750-900 bearings, ignore the 1100 part numbers.
