  • Total: 122,894,489
  • Today: 27,518
  • 05:16 am PST
adk_finn
PostPosted: Tue Jun 13, 2017 3:32 pm Reply with quote Back to top
http://www.ebay.com/itm/Front-Rear-Foot-Pegs-for-Honda-CB600F-Hornet-CB500-CB750-CB1000-F-NT-400-650-700-/151836260307?fits=Model%3ACB1100F&var=&hash=item235a2577d3:m:mXLP1ah_D7ZPELGZHv2tL0w&vxp=mtr
Looking at replacement foot pegs and I like the look of the set above. Has anyone tried these with the stock CB1100F lattice plates (non rearset)? I realize 'you can make anything fit with enough work' but wanted to see if anyone had any luck using these or a comparable set without significant modification, they are in great supply on fleabay.
Conversely, does anyone have a left front foot peg in decent shape they would offer at a reasonable price? Mine is slightly broken and the peg sits at a little bit of an angle.
Thanks in advance.
adk_finn
PostPosted: Wed Jun 14, 2017 2:46 pm Reply with quote Back to top
No one? Not even Sonicrete to call me stupid and tell me to put the airbox back on and check my valve clearances? You guys are slipping. Wink
PostPosted: Wed Jun 14, 2017 3:39 pm Reply with quote Back to top
LOL. just so you get one answer. I don't know but as I recall, and my mem is failing, the mount looks different from my recollection. Did you go look at your perches?
adk_finn
PostPosted: Wed Jun 14, 2017 4:13 pm Reply with quote Back to top
Thanks Grump!
I looked, yes. The front mounts on my pegs have the rounded edge (where the peg meets the bracket) at the bottom, not the top as these appear to be designed. The rears look quite different since they use a spring and not the compression of the rubbers to facilitate the resistance to hold them in position. I am not sure if either of these issues would prevent them from working. I guess for $32 for the set I could just pull the trigger and try it, but I was hoping, given their prevalence, someone on the board had first hand experience they could relate.
I searched the board and got some mixed results. I think Headless mentioned he had no luck with them, but it seemed someone else had? It was unclear. I will also try again using some additional terms.
PostPosted: Thu Jun 15, 2017 12:37 pm Reply with quote Back to top
Well,let me know how it works out wouldya? I gave up on 11s some years back and have nothing left to compare. m
adk_finn
PostPosted: Thu Jun 15, 2017 2:35 pm Reply with quote Back to top
Will do
_______________
1998 VFR800
1981 CB750F
1988 VT600
