  • Total: 107,671,065
  • Today: 56,792
  • May 30, 2026
  • 11:55 pm PDT
doubled
PostPosted: Thu Mar 30, 2017 1:39 pm Reply with quote Back to top
Are they the same length?
---David
1982 900F, 2000 VFR, 2013 FJR
PostPosted: Thu Mar 30, 2017 3:16 pm Reply with quote Back to top
Good thread here:
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&p=331655#331655
Going by the info there, the CDN speedo cable should be 40" in length. It impart # 44830-MG5-610 which was superseded by 44830-MJ1-000 and both are available in the US for about $20 (at Partzilla).
I'll check and see if I have an old US 1100f speedo cable to measure.
doubled
PostPosted: Thu Mar 30, 2017 9:23 pm Reply with quote Back to top
sillygoose wrote:
Good thread here:
Thanks. Based on the info Tony provided, it looks like I need the CDN 1100F speedo cable even though my bike will be a bit shorter due to the 900 frame. Better to have one a little longer than shorter, or at least that's what she said last night Wink
---David
PostPosted: Fri Mar 31, 2017 12:39 pm Reply with quote Back to top
doubled wrote:
sillygoose wrote:
Good thread here:
So did you sleep on the couch? Razz Laughing
PostPosted: Fri Mar 31, 2017 5:28 pm Reply with quote Back to top
Went and measured some actual Honda speedo cables (all had Honda part numbers on them and everything in mm):
44830-MG5-670      988          US 1100f, superseded by 44830-MB9-780 (still available from Honda)
44830-MC9-770     1015         supersedes 44830-MG5-610 (CDN 1100f), superseded by 44830-MJ1-000
44830-MJ1-000      1015         still available from Honda
44830-MG1-000     1132         CB1000C, NLA
basmn
PostPosted: Fri Mar 31, 2017 8:10 pm Reply with quote Back to top
doubled wrote:
sillygoose wrote:
Good thread here:
What do you need a Speedo for....when we ride with Joe........well we r in hot water anyway 🚰🚰🚰🚰😈😈😈😈
81 750F stock
83 1100F stock
08 FZ1
03 YZF R6 track only
XR100 pit special
CRF 230F
2018 Polaris 570..for me..
doubled
PostPosted: Fri Mar 31, 2017 9:57 pm Reply with quote Back to top
Rick - I sent you an email re: cable length. My 900 cable seems to work for length and I measured it to be 965 mm, but I wasn't able to lift the front end to measure the bike with forks fully extended. The Euro 1100F cable is 2 inches longer so is probably the safe bet in the long term.
Like she said....
---David
