  • Total: 118,081,303
  • Today: 75,065
  • Oct 23, 2026
  • 12:33 pm PDT
zealous
PostPosted: Sun May 22, 2016 11:43 pm Reply with quote Back to top
Darren I installed the HO 140 OHLINS
Went for a test ride 80 miles across al type of roads smooth and confident feel
Why did I wait so long
PostPosted: Mon May 23, 2016 12:03 am Reply with quote Back to top
Are they on backwards?????
zealous
PostPosted: Mon May 23, 2016 12:20 am Reply with quote Back to top
No
OHLINS Monting Instructions
NOTE !
"The shock absorber should be mounted with the cylinder head upwards. On the right side the gas reservoir should be pointing forwards. The left reservoir can be mounted forwards if the helment lock is removed. "
I like the fit looks and best of all the performance
PostPosted: Mon May 23, 2016 12:53 am Reply with quote Back to top
Have to agree with Russ. In spite of what Öhlins says. It looks like they would fit better on the right side with the reservoir mounted towards the back.
zealous
PostPosted: Mon May 23, 2016 1:49 am Reply with quote Back to top
Open for debate
Nunzio
PostPosted: Mon May 23, 2016 1:57 am Reply with quote Back to top
They are on backwards. Smile
CB750F Super Sport
GL1000
CX500TC
Bone
PostPosted: Mon May 23, 2016 2:11 am Reply with quote Back to top
I guess it depends on how you interpret 'pointing to the front'. Does 'pointing to the front' equate to the reservoir on the front or the reservoir at the back with the connector to the shock pointing forward? Ultimately, I did not think it affected the functionality either way and mounted mine with the reservoir at the back.
Dons highly modified CB900 has the reservoir at the back:
http://www.bikeme.tv/wordpress/wp-content/uploads/2014/02/30ur5sh.jpg
They are probably not he HO140, but they are Ohlins, and the reservoir is at the back on the Captains bike:
I woud be concerned that with the reservoir at the front they may interfere with the side panels and damage them.
1982 CB900FC
1981 CB900F2B
PostPosted: Mon May 23, 2016 2:29 am Reply with quote Back to top
Mine, when you get your own set you can mount them any way you like. Smile When I am tired of this way I can flip them around for a while.
My new ones have no choice because of the adjusters.
pn27416
PostPosted: Mon May 23, 2016 1:45 pm Reply with quote Back to top
Mine are back. I'm thinking may not matter?
ZGrand
PostPosted: Thu May 26, 2016 1:20 am Reply with quote Back to top
Mine are towards the rear as well. As I recall, the orientation of the lower shock mounts necessitated it. (??) They may have changed it now.
82 CB900F
79 CBX
90 Honda Hawk GT
00 Kawasaki W650
04 Yamaha FZ1
06 Suzuki DR650
hogwild113
PostPosted: Thu May 26, 2016 3:48 am Reply with quote Back to top
I agree. I've always felt that the resivoir was intended to go to the outside whether on top or bottom...
chico
PostPosted: Thu May 26, 2016 4:05 am Reply with quote Back to top
Nunzio, you are absolutely right yours are backward...facing.
Chico roflmao
´79 CBX sold
"83 CB 1100 Red
´99 Valkyrie Interstate sold
2000 Harley Fatboy
2005 Softail Deluxe
´07 Yamaha FZ traded
'17Triumph Tiger 800
'17 Triumph Bobber
PostPosted: Thu May 26, 2016 11:03 am Reply with quote Back to top
Mine are also fitted with the reservoir facing rearwards, as they are pressurised i would not think it changes the operation of them, I also fitted softer springs to mine, the springs were far too hard for solo use on the R
It had the Ohlins 480 -03 Springs fitted, 18-27 nm (159 lbs - 238lbs), I replaced them with the softest set available 480- 01 springs 15-24 nm (132 lbs -212lbs)
[img]Image[/img]
ZGrand
PostPosted: Thu May 26, 2016 3:25 pm Reply with quote Back to top
This is what I meant by the configuration of the lower shock mount. It can only go one way, which oriented the shock reservoir toward the rear of the bike. Do the newer Ohlins shocks have a different lower mount?
82 CB900F
79 CBX
90 Honda Hawk GT
00 Kawasaki W650
04 Yamaha FZ1
06 Suzuki DR650
zealous
PostPosted: Thu May 26, 2016 6:39 pm Reply with quote Back to top
Same mount
PostPosted: Thu May 26, 2016 9:50 pm Reply with quote Back to top
Can't the bottom or top rotate 180 degrees?
Oldtech
PostPosted: Thu May 26, 2016 11:06 pm Reply with quote Back to top
Mounted them on my CBX according to the instructions that came with them. Now drop a set of Race Tech cartridge emulators into your front forks and the upgrade will be complete. These mods transformed the ride of my X .
The bottom clevis can be rotated to accommodate mounting with the reservoir facing front or back.
Nunzio
PostPosted: Fri May 27, 2016 1:54 am Reply with quote Back to top
It looks goofy..............reservoir forward. IMHO.
CB750F Super Sport
GL1000
CX500TC
Bone
PostPosted: Fri May 27, 2016 2:06 am Reply with quote Back to top
They are not marked 'left' or 'right'. If you want to mount them with the reservoir facing the opposite direction, you also have to swap them to the other side of the bike.
PostPosted: Fri May 27, 2016 2:12 pm Reply with quote Back to top
You guys are all just silly Razz Razz Laughing
PostPosted: Fri May 27, 2016 7:18 pm Reply with quote Back to top
Gotta say, Petrat wins! Very Happy beerchug
SEBSPEED
PostPosted: Sat May 28, 2016 12:30 am Reply with quote Back to top
I dare to be different in the name of performance...
ZGrand
PostPosted: Sun May 29, 2016 1:30 am Reply with quote Back to top
I never even thought about trying to rotate the bottom mount. I still think they look better facing the rear. Smile
82 CB900F
79 CBX
90 Honda Hawk GT
00 Kawasaki W650
04 Yamaha FZ1
06 Suzuki DR650
PostPosted: Sun May 29, 2016 1:47 am Reply with quote Back to top
Evo is just gorgeous........I need a tissue. Mr. Green
PostPosted: Sun May 29, 2016 1:51 am Reply with quote Back to top
You guys that mount your shocks backwards are crazy. director If the shock police see that, you're dead meat. They don't even write a ticket. They shoot you in the face, bluevred take the shocks and bury you and the bike in a mass grave. And there'll you'll be...dead...with no shocks.
And all because you wanted to be different...you bastards...
chico
PostPosted: Sun May 29, 2016 4:52 am Reply with quote Back to top
Shocking![b]
Chico
´79 CBX sold
"83 CB 1100 Red
2000 Harley Fatboy
2005 Softail Deluxe
'17 Triumph Bobber
toddk
PostPosted: Sun May 29, 2016 9:53 pm Reply with quote Back to top
Shocks don't care which way they face. (at least these don't)
This is my idea of performance Very Happy
By the way "The Original Evolution"
Razz Toddk
PostPosted: Mon May 30, 2016 1:23 pm Reply with quote Back to top
I think the directions with the shocks say to mount them backwards...
After carefully checking that there was no reason to mount them that way (physical clearance, etc), I disregarded those instructions and mounted them the way I have seen bike racers mount those type shocks since well before I could afford a set.....Reservoir facing the rear.......
PostPosted: Mon May 30, 2016 2:26 pm Reply with quote Back to top
Finally - some real shocks instead of this Ohlins nonsense Razz
...and don't get me started on naming a bike, or those weird looking monoshock conversions...
toddk
PostPosted: Mon May 30, 2016 2:36 pm Reply with quote Back to top
Thank god there's somebody here to cause trouble besides me Very Happy , Hope to see you soon, Come riding with us when you are free and we'll take only the roads for pretty bikes. Wink
Toddk
