  • Total: 115,018,178
  • Today: 22,268
  • Sep 23, 2026
  • 03:25 pm PDT
smoojee
PostPosted: Tue Apr 19, 2016 2:16 pm Reply with quote Back to top
Hey, anyone out there have a cycle x high performance charging system for the dohc? And/or what's the general concensus about them?
smoojee
PostPosted: Thu Apr 21, 2016 9:16 pm Reply with quote Back to top
Anyone? Bueller? No one has any info or experience with these? http://www.cyclexchange.net/DOHC%20PARTS%20pAGE.htm
80 Honda CB750F Supersport
93 Honda Nighthawk 750
82 Honda CB450SC Nighthawk
youn6372
PostPosted: Mon Apr 25, 2016 2:49 am Reply with quote Back to top
When I decided to build my SOHC I used plenty of parts from Cycle X and I was pleased with all of them. The owner Ken is a stand up guy who is more than willing to get on the phone and talk tech with you if you have any problems. I don't have any experience with the DOHC products but I would expect the same level of quality I got from the SOHC stuff.
smoojee
PostPosted: Mon Apr 25, 2016 1:52 pm Reply with quote Back to top
Thanks youn6372
thenewguy
PostPosted: Fri Jun 16, 2017 3:01 pm Reply with quote Back to top
Smoojee - I saw you comment in another thread that you ended up trying the charging system and like it. That still the case?
Looks like it's a permanent magnet rotor? How are the street manners with the lighter rotating mass?
Any idea what the max output is? I've found a few old threads discussing the original version (current version seems to be the 2nd revision), and a common concern seemed to be that output was actually less than that of the stock system.
1979 CB750K
smoojee
PostPosted: Sun Jun 18, 2017 4:10 pm Reply with quote Back to top
So far it’s great, I haven’t had any issues with it. I have a digital speedo with a built in voltmeter and it seems to keep the battery at about 13.5-14 volts.
goofnrox
PostPosted: Mon May 07, 2018 1:39 pm Reply with quote Back to top
How/where did you mount the regulator for this system? I'm concerned that it's going to bake in the stock regulator location with very little airflow in that area.
Jeff
80' CB750F
