  • Total: 110,536,943
  • Today: 15,405
  • Jun 27, 2026
  • 03:59 am PDT
alecellis
PostPosted: Mon Feb 01, 2016 3:30 am Reply with quote Back to top
Can anyone suggest what would be causing the gap between the brake light and the plastic surround? (See photos) It doesn't look like anything is fowling and I can't think of what would be causing it...
http://imgur.com/a/xAAmq
Wayne750F
PostPosted: Mon Feb 01, 2016 3:52 am Reply with quote Back to top
My guess from the picture is that the tail light bracket is bolted directly to the fender without the rubber spacers which are about the same length as your gap in the pictures. Close to 1"
1983 Red CB1100F
1991 Suzuki GSXR1100
1993 Yamaha FZR1000
alecellis
PostPosted: Mon Feb 01, 2016 3:59 am Reply with quote Back to top
Thanks Wayne! Didn't even know there was meant to be spacers, I'll have a look
Wayne750F
PostPosted: Mon Feb 01, 2016 4:03 am Reply with quote Back to top
Sure Mate there are 4 and they have a hex on both ends incorporating the mounting studs that fits into a hex molded in the outer fender. With the cowl off and bracket removed you'll see what I'm talking about. But I'll bet that's your problem mate.....
1983 Red CB1100F
1993 Yamaha FZR1000
Wayne750F
PostPosted: Mon Feb 01, 2016 4:08 am Reply with quote Back to top
If that is indeed the problem, those rubbers are still available from Honda......or maybe one of your mates down there has some as they are kind of pricey for what they are.
1983 Red CB1100F
1993 Yamaha FZR1000
AMC49
PostPosted: Mon Feb 01, 2016 5:47 am Reply with quote Back to top
Mine from the day bike was new was lopsided at that gap. It bothered me enough that I simply jacked up one side of the seat by gluing a thick washer right under one of the rear sucker feet that seat sits on at back. It was then perfectly even at least.
PostPosted: Mon Feb 01, 2016 8:37 am Reply with quote Back to top
The increase in the gap can also be caused by using an aftermarket seat like a Corbin Gunfighter. The seat pan is different for the Corbin and the rubber pads are different. The OEM seat attachment hardware bolts to the Corbin no problem, but the design of the seat and pan make many of them sit higher above the tail ight assembly, at least in my experiance with them. You maybe can see the gap in the attached picture?
Tony
Bone
PostPosted: Mon Feb 01, 2016 9:08 am Reply with quote Back to top
If your bike is a 900, the spacers are the same as the two rubber mounts for the oil cooler. There are plenty of vendors on eBay etc that sell similar rubber isolation mounts for much less than the original part.
1982 CB900FC
1981 CB900F2B
PostPosted: Mon Feb 01, 2016 11:19 am Reply with quote Back to top
Honda part is 85201-438-000
alecellis
PostPosted: Mon Feb 01, 2016 11:48 am Reply with quote Back to top
thanks a lot everyone, it was indeed the rubber spacers! Ill have a look online to try and find some for a reasonable price Laughing
Wayne750F
PostPosted: Mon Feb 01, 2016 3:27 pm Reply with quote Back to top
Glad you got sorted mate....
1983 Red CB1100F
1993 Yamaha FZR1000
PostPosted: Mon Feb 01, 2016 4:06 pm Reply with quote Back to top
And you can look for your missing tail cowl stoppers while you are at it to it won't bang on your newly raised tail light:
http://www.powerplantmotorcycles.com.au/find/part/M.240728
Maybe someone has a used pair laying around since I believe they are NLA.
PostPosted: Sat Feb 06, 2016 6:02 pm Reply with quote Back to top
McMaster-Carr sell similar, but not identical, spacers which will work. Much better price than OEM.
PostPosted: Sat Feb 06, 2016 6:05 pm Reply with quote Back to top
Have same problem on my 1100. I figure it's due to a slightly bent seat pan (OEM) or maybe the taillight mounting is crooked?
PostPosted: Sat Feb 06, 2016 6:49 pm Reply with quote Back to top
Mine were MIA when I got the bike. Tail light went out. Pulled tail light lens....Well whaddya know...there they were. Bizarre.
