  • Total: 122,969,708
  • Today: 102,737
  • 07:17 pm PST
Macman
PostPosted: Fri Dec 24, 2004 1:55 am Reply with quote Back to top
Looking at you guys pics in the gallery, it looks like it is about even on the Vance & Hines bellhorn exhaust vs. Vance & Hines or Kerker canister exhausts. I have the VH Bellhorn exhaust on my 82' 900F because I like the sound of it. My mechanic, who races on weekends in addition to having his shop, says that the cannister exhaust adds about 2 hp to output, and that my money would be better spent elsewhere for improved horsepower. What are you guys experiencing with your various exhausts as far as performance?
fasterspider
PostPosted: Fri Dec 24, 2004 2:34 am Reply with quote Back to top
I have the V&H megaphone on my other 1100F, listen to it.
http://fasterspider.com/pirellimelt.mov
It is short but sweet.
I have both kinds NIB {megaphone & cannister) of V&H exhausts here at the house waiting to go on bikes.
The cannister is for sound and looks and the megaphone is a performance pipe.
To utilize the advantage the megaphone has to offer you will need to do some things a little bit more involved than just jetting and exhaust.
Unless you are going to sink a couple of thousand dollars into your motor, just go with the sound and looks exhaust system.
PostPosted: Fri Dec 24, 2004 2:39 am Reply with quote Back to top
You need a new mechanic.
These Honda models have "faults" that hold the power back,like the crappy CV carbs and the ignition system,but a good megaphone system has the possibility of making the most power.
A cannister is in effect a very long piece of straight pipe. The megaphone gives an "increasing area" that makes a "suction" on the intake during overlap. This is the source of the power increase. With a baffle in place the effect is probably even between both designs. An open megaphone is extremely loud,so for most road races that have "noise limits",the power gained with the least noise is the effect. Drag racing with no sound limits,it will be the megaphone,hands down.
The primary effect with either system compared to the stock system is the lighter weight. Any time you can shed weight the bike will be faster.
Larry
PostPosted: Fri Dec 24, 2004 10:48 am Reply with quote Back to top
Another trick tomake the V&H Megaphone better is to install a Kirker Competition baffle into it. It will quiet it somewhat nad still retain the power gains you are looking for. It definitely makes more power than a canister type.
jons
PostPosted: Fri Dec 24, 2004 5:40 pm Reply with quote Back to top
With all due respect, I disagree. I'm not saying that I know the engineering aspect, but there is no MotoGP or superbike team that uses a megaphone exhaust. I think it is strickly a drag racing thing.
If there was an advantage to a megaphone these guys would have them.
Da_Hose
PostPosted: Fri Dec 24, 2004 10:29 pm Reply with quote Back to top
I completely understand your reasoning, but perhaps the issue is that with modern ignitions and valve trains, the advantages of the megaphone disappear. So with our old style engines perhaps megaphones are better but with newer engine designs, the straight pipes are the ticket.
Jose
Mike414
PostPosted: Fri Dec 24, 2004 10:57 pm Reply with quote Back to top
Have you looked at the unmuffled Honda MotoGP RC211V? The exhaust is a very slight MEGAPHONE. Most of the riders found it to be far to loud and it hurt their concentration so they went back to the muffled versions. As Sonicrete said, noise restrictions at the roadraces (AMA and World Superbike) is what keeps the pipe design to muffled straight pipes.
Mike
Nanuq
PostPosted: Fri Dec 24, 2004 11:15 pm Reply with quote Back to top
For a little more information look into the designs of 2-stroke engines and their exhaust systems. They use very pronounced "megaphone" style flares with a large belly between the opening and closing cones. The cone tapers, the distances between them, the belly and tubing diameters all come into play to give the tuner the performance profile he's looking for.
You should see the inside of the collector on the pipe Kaz built for me. All 4 tubes come together but then he's got this cool inverted cone welded in there and when you think about it, he's using the collector volume itself as part of a pseudo-megaphone. It's a very very smart design.
Merry Christmas to all!
jons
PostPosted: Fri Dec 24, 2004 11:30 pm Reply with quote Back to top
Its very slightly possible I am wrong. Embarassed Smile
Nanuq
PostPosted: Sat Dec 25, 2004 12:05 am Reply with quote Back to top
Hey John, If you look closely at your picture you'll see they really ARE using megaphones... they're simply disguised as back protectors.
Wink
PostPosted: Sat Dec 25, 2004 3:42 am Reply with quote Back to top
For the same reason Rude Valley would "sing" into a megaphone to amplify his voice,the megaphone amplifys the power.
The rules of today require you to meet a certain sound limit. The cannister does that and becomes as low a restriction as possible. This is a muffler reduced to the simplist terms. A very long straight pipe will have very little noise at the end,say 20 ft of pipe. The wall friction reduces the velocity to a small area in the middle of moving air.
The increasing area of the megaphone does strange things to the air flow and you can hear and feel this occur. At a certain speed,say 3500 RPM,the sound will stay internal to the pipe,the tuned length. Above this speed there is pressure built up in the collector and causes the megaphone to become a supersonic nozzel to draw on the pipe. Interesting design of supersonics. From slow speed to mach 1 the reduction of area causes the speed to increase. At low pressure when the area expands the flow slows down,but if there is enough pressure to get mach 1 at the throat the flow speeds up and drags behind it. The effect of a new type "safety" air nozzel with the injection holes around the OD,or a Berzomatic propane torch.
The expanding nozzel then,"dwell distance,followed by the converging nozzel is why modern 2 strokes make power.It is to control the port timing by making extraction and blocking waves that arrive at the correct time depending on the intended RPM.
SuperSport
SuperSport
PostPosted: Sat Dec 25, 2004 3:59 am Reply with quote Back to top
Concept good, analogy bad. An unpowered megaphone in the case of Rudy Vallee doesn't amplify it directs the sound.
You can't get something for nothing, it's one of those silly laws of physics. To amplify, you need to provide energy to do just that.
Glenn
´83 CB1100F,´94 Wife
Catchy phrase not included.
PostPosted: Sat Dec 25, 2004 4:28 am Reply with quote Back to top
OK lets try another example to prove the first example. An old time Victrola with a needle running in the grooves on a record. You can do the same job with a modern record player. Yes,I know everything is CD's now. Make a "cone" from paper,fold over the end and put a sewing needle through it. You can make different tapers and lengths to see the effect,but the sound of the vibrations of the music does see an amplification.
SuperSport
SuperSport
PostPosted: Sat Dec 25, 2004 5:05 am Reply with quote Back to top
Ok, I'll listen. How does a paper cone increase the energy?
My stance is the amount of energy is finite in the system. With or without the cone it's exactly the same, adding the cone in the case of a Victrola, allows that energy to be put into a usable (hearable) format...
A voice cone in the other example makes the voice "seem" louder in front of the come, but almost inaudible to the sides or behind. Again, the same energy, only directed or focused into a tighter field.
Glenn
toobalicious
PostPosted: Sat Dec 25, 2004 3:14 pm Reply with quote Back to top
well, it sort of does... while the actual energy of the wave obviously remains the same, the efficiency with which that wave is produced (at the end of the horn) is increased, sometimes by a pretty large factor, hence the increase in SPL (sound pressure level)... speakers... some compression drivers (high frequency) have SPL rating upwards of 130-140dB where as paper-type drivers are more typically 80-90dB (usually measured by inputting a 1kHZ wave at 1 watt, with the decibal level measured at a distance of 1 meter)... however, there are a lot more factors at play here than simple wave energy and perceived volume... one important variable is resonance... a horn (or megaphone) will be "tuned" (whether purposefully or not) to specific harmonic (frequencies)... this is the reason that a bugle is limited in the notes it can produce; no matter how hard you try, especially in the low range where the soundwaves are longer, there are some notes which cannot be sounded... when the horn (or enclosure) is tuned to specific frequencies, those frequencies will be accentuated by resonance/standing waves and sympathetic vibration... think about a ported subwoofer... if you cover the port, the overall SPL drops significantly, but the response will typically be much more linear (not always, though)... when you relese the port, the cabinet and port, which are (hopefully) tuned to useful 2nd order harmonics (constructive harmonics), resonates and thus "increases" the SPL in those frequencies... poorly ported enclosures may resonate at 3rd order or higher harmonics (destructive, due to phase cancellation and partial artificial re-enforcement) , which sound harsh even though the SPL is increased... math will prove this... blah blah blah...
now think about exhaust... it is common opinion, for example, that MAC megaphones arent anything special... they are evidentally not tuned for performance... it would seem that the design was asthetic, without use of key measurements or formulae for optimum performance... it is still loud, but folks do not seem to realize any increase in performance (and in fact may encounter reductions in performance, such as flat spots)... this is due significantly to turbulence (analogy: destructive harmonics)--- unequalized pressure... the V&H pipe, however, seems to be engineered for increased flow that is proportionate to the flow requirements of the engine (anaolgy: constuctive harmonics)... it is also loud... sonic is on the right path with the difference of pressure... it seems that sheer volume is as much a by-product as a result in this application... i have never seen drag vehicles with mufflers, but the resoning has little to do with volume...
interesting read, this post...
a
SuperSport
SuperSport
PostPosted: Sat Dec 25, 2004 3:56 pm Reply with quote Back to top
Thanks toob for that post. It was Christmas Eve, and I didn't feel like typing that much. The point being, the megaphone does NOT amplify the power. It's tunes the power that is there and latent in the engine. That's why you can see an increase with a tuned exhaust. It's "tuned". The exhaust itself brings no additional power into the system.
Glenn
jons
PostPosted: Sat Dec 25, 2004 6:43 pm Reply with quote Back to top
In car racing , I have also heard the term"tuned exhaust" with no megaphone involved. I know it starts with equal length headers and ends within a certain length and diameter pipe.
I am not saying that I don't think a megaphone with increase power. I am saying that non megaphone pipes will too if made properly. In the past I have mentioned that my 2nd 750F had a kerker K2, I believe, exhaust. There was a very noticable increase in power from the midrange on with that pipe. No the modification required. It woulde reach redline in 5th gear with stock sprockets and still have more available. That wasn't the case with the stock exhaust.
PostPosted: Sat Dec 25, 2004 10:44 pm Reply with quote Back to top
OK I will try this from a different direction.
I have a special,one off,short primary,full pyramid,Denco header. It has a "normal" single taper megaphone and I also have a special "tricone" megaphone. The tricone is a single taper up to a point then a "steeper" taper,say 7 degrees then 10 degrees,then a reverse cone at the same 10 degrees. By only changing the megaphone you get a power increase,in fact it feels like another cylinder came in,it is dramatic.
Dennis Dean's original job was an accoustical engineer(Dr of Accoustical Engineering),worked in Japan for Matsushita. The "Omni" speaker design from several years ago was one of his designs. According to Dennis,he calls all exhaust systems an "accoustic transducer" and again according to Dennis comes straight out of accoustical engineering textbooks.
The "tricone" that Dennis designed would "pull" on the cylinder and the returning wave caused by the second cone would arrive right as the exhaust valve closed. This would give a big "yank" on the incoming charge. It was so dramatic the reverse cone needed to be there or you could not take off as it killed the bottom end power. The total combination amplified power EVERYWHERE in the range. You could go from "traction problems" on a slick track to driveable by putting the normal megaphone back on the bike. The noise level by the way approaches the "pain" threshold and I can give several people to report this in case you still doubt the effect.
The best "muffler" is a certain amount of resistance to flow. A megaphone is NO resistance to flow and becomes a "suction generator" above a certain speed. The megaphone in effect becomes mulitiple "tuned lengths" depending on the pressure at the engine end. A parallel straight pipe has ONE tuned length and only works at that RPM. Top fuel or Funny car has short pipes since the motor immediatly jumps to say 8000 RPM and stays there with clutch control. Also the pressure can be used to push the car down against the track. A Pro stock car has some type of extension onto the collector to again get into the operating range of the engine. You still get the "suction effect" as the small primary pipe empties into the larger collector.
I will guarantee that a megaphone makes some type difference compared to a straight pipe no matter how you explain it. This effect was discovered many years ago when rules required a certain total length pipe. Someone had cut the pipe to gain power and did not want the longer pipe but needed it because of the rules. So he added a megahone(tapered pipe) to what he already had(to make length)and then saw a further gain in power.
jons
PostPosted: Sat Feb 26, 2005 4:04 am Reply with quote Back to top
Tyhis is an old topic where I disagreed with the view on megaphones.
Sadly, I have conclusive evidance that I was wrong. New Honda MotoGP bike:
Actually, I just wanted to post a picture of this cool bike. Wink
Think that swingarm is beefy enough?
fasterspider
PostPosted: Sat Feb 26, 2005 4:39 am Reply with quote Back to top
That is a very cool bike John.
I have a Konica-Minolta Dimage Z-3. All I need now is a nice RC211V and I will {Probably blow up} be complete.
831100F
Location: Adjacent to and within walking distance of: Beautiful downtown Winterpock, VA
PostPosted: Sat Feb 26, 2005 10:46 am Reply with quote Back to top
I've never owned a V&H Megaphone style exhaust but I'll say this, I found an ad for a V&H SS pipe for my CBR1000, 'Free to a Good Home'. A guy in Hawaii was cleaning out his garage and just wanted to get rid of it. Cost me about $30 shipping. It had roadrash on the can and some surface rust. I replaced the skin on the can, sandblasted and painted it. Bolted it up and went for a ride having great expectations. With no other changes, the bike lost tons of midrange and hesitated just off idle. Seat of the pants said it made more power on top but it wasn't worth the loss of 'real world' power just to get a few top end ponies. The V&H literature said no jetting was needed if using stock airbox/filter.
I probably could have jetted back some performance but I thought the thing sounded like sh_t! I hated it. It's my wife's bike and she rode it one time and asked me politely to remove it. Back on with the stock pipes. Midrange restored.
When I got my 1100F back from my best friend, he had replaced the Bassani with, you guessed it, a V&H Supersport exhaust system. I started it up and was immediately unhappy with the sound. But, it ran pretty damn good. The Bassani has the ballsiest, badass sound in all of exhaust land IMHO. But when I put it back on, it developed a pretty severe off idle stumble that no amount of jetting could remove. (Stock airbox, K&N filter) Stock air filter didn't help either.
Overall, the Bassani didn't seem to make near the mid-range or top-end power of the SS system but god did it sound like heaven. I wanted to know why. Below is a sketch of Darryl Bassani's faux collector system. Basically the 'true' collector is about the same size of the V&H collector, hidden inside a bigger 'faux' collector that just looks big and beefy. Unfortunately, the tailpipe is the same size as the 'faux' collector so reversion waves heading for the ex valves get dammed up in 'no mans land' where the two collectors dead end. Darryl chose style and sound over function.
I just sold my Bassani pretty cheap to a forum member, currently on duty in Iraq. Frankly, due to some header pipe flattening and some previously repaired collector cracks, it wasn't worth much and needs to be completely rebuilt, (which I told the buyer). I kept that pipe for many years, hanging on the wall because I thought that some day, I'd get her rebuilt and put her back on and damn the lack of power, my monster built 1123cc engine had more power than I could use anyhow and besides, I'd be living in aural wonderland. Then I slapped myself silly for thinking such impure thoughts and instead, I grafted a SS2R cannister on to the old Supersport collector and tailpipe. Sounds great, pretty close to the Bassani's bassy growl and power output is just fine with no hiccups.
Now if you can find a hand bent Kaz Yoshima pipe.......................
Mike
Page Generation: 0.09 Seconds
