  • Total: 110,536,570
  • Today: 15,032
  • Jun 27, 2026
  • 03:56 am PDT
super
PostPosted: Mon Oct 26, 2015 5:08 pm Reply with quote Back to top
when measuring compression i'm told i have to ground the sparkplugwires
how do i do that ?
super
PostPosted: Mon Oct 26, 2015 5:14 pm Reply with quote Back to top
so i found out how to ground sparkplugwires.
Link
new question.
is it necessary to ground sparkplugwires when compression testing ?
PostPosted: Mon Oct 26, 2015 5:17 pm Reply with quote Back to top
I think you pull all the plugs and cover up the cylinders not being tested (I stick a shop vac wand over the spark plugs before pulling them to make sure no foreign objects are lurking). You want to be able to turn the engine quickly and easily, no very easy with the plugs all in.
No idea where the grounding the spark plugs come from, only useful if you want to observe you are getting a spark.
sfhess
PostPosted: Mon Oct 26, 2015 6:02 pm Reply with quote Back to top
Turn the kill switch to "off" then you can spin away without worrying about any stray sparks.
super
PostPosted: Mon Oct 26, 2015 6:03 pm Reply with quote Back to top
the manual that came with the compressiontester i bought says ground the sparkplugwires before testing compression.
so my question is, is not grounding the sparkplugwires like driving without a seatbelt and if so .. at what speed am i driving without a seatbelt ..
PostPosted: Mon Oct 26, 2015 6:14 pm Reply with quote Back to top
If you have your ignition "On" and coils providing spark, you will do damage to coils and/or igniters if the plug is not grounded. Like sfhess says, turn kill switch to off.
super
PostPosted: Mon Oct 26, 2015 8:01 pm Reply with quote Back to top
this thread should probably be in the technical section
PostPosted: Mon Oct 26, 2015 10:10 pm Reply with quote Back to top
When you turn the kill switch to off, you don't need to worry about grounding spark plugs, as the ignition is turned off. In fact don't even put them on the spark plug wires, just pull the wires off the plugs, and leave them off. Remove all the plugs from the motor and run your compression tests with the throttle wide open.
PostPosted: Mon Oct 26, 2015 10:54 pm Reply with quote Back to top
I'm not sure you'd damage anything by not grounding the plug wires, I've never bothered grounding them when I've done compression tests. I think grounding is recommended so that a) you don't get zapped by accidentally touching a high voltage wire while cranking and b) if there happens to be left over fuel mixture in the cylinders it could get blown out of a spark plug hole and ignite from a loose wire spark (but highly unlikely). In any case, the kill switch is the way to go if you're really worried about it.
super
PostPosted: Tue Oct 27, 2015 9:10 am Reply with quote Back to top
i fail to see how the engine will turn over with the killswitch in the off position
PostPosted: Tue Oct 27, 2015 9:19 am Reply with quote Back to top
By pushing the start button which routes electricity from the battery to the starter motor via the starter relay.
The starter motor will then rotate and in turn cause the crankshaft to rotate.
It will not work if you have a flat battery or fail to press the starter button.
PostPosted: Tue Oct 27, 2015 1:25 pm Reply with quote Back to top
or if the bike is not in neutral or the clutch lever pulled.
sfhess
PostPosted: Tue Oct 27, 2015 4:25 pm Reply with quote Back to top
Killswitch shuts off the ignition circuit. No power to coils or ignitor boxes. It does not affect the starter circuit. Try it.......
PostPosted: Tue Oct 27, 2015 4:34 pm Reply with quote Back to top
I have actually drained a battery by cranking and cranking and cranking without realizing the kill switch was off... Embarassed
PostPosted: Tue Oct 27, 2015 10:26 pm Reply with quote Back to top
Laughing Laughing
PostPosted: Wed Oct 28, 2015 12:06 am Reply with quote Back to top
That's so funny.
I've never been dumb enough to do something like that.
Oh, well, except a couple of weeks ago when I spent a good 5 minutes increasingly angrily and violently trying to kick start one of my CT110 postie bikes. Then discovered the kill switch in the off position. Sadly there was a witness. My groin and hip were sore for a few days after that little effort.
PostPosted: Wed Oct 28, 2015 11:58 am Reply with quote Back to top
Very Happy Very Happy I rarely use the kill switch, so it should not have been a problem, but....the 4-year old kid next door had come over to visit while I was working on a bike. He was "helping" me by picking up and moving around tools and twisting the throttle. He obviously also moved the kill switch - without me noticing. That's when it happened. I had a good laugh after that...
Hondamax
PostPosted: Wed Oct 28, 2015 12:59 pm Reply with quote Back to top
+1 ... and called roadside assistance, and then spotted it ...!
Regards,
Max
1984 VF1000R - Started
1979 900Fz - Stored
AMC49
PostPosted: Thu Oct 29, 2015 4:20 am Reply with quote Back to top
The idea is that grounding the plug wires removes load off the spark units, some brands and cars say can pop the electronic boxes if the spark is trying to jump through infinity. I've had a crap rider mower do it before when not paying attention.
Old first gen Mopar electronic ignition of the mid '70s could do it if you did the leads just right.
Not wise on any electronic ignition, use the kill switch.
super
PostPosted: Thu Oct 29, 2015 7:11 pm Reply with quote Back to top
you've convinced me on the killswitch.
unfortunately the compression tool i bougt did not fit.
so is there a compression tool with 4 gauges that measures compression without removing sparkplugs or is this another tool ? like the tool one would use to synchronize carburetors ?
PostPosted: Thu Oct 29, 2015 7:24 pm Reply with quote Back to top
You have to remove the spark plugs to do a compression check , whether it be all at once or one at a time , all removed is the best . A lot less drain on the battery when all are removed . I have never seen a 4 gauge compression tester . Why would you need it ? Do you need a 8 gauge tester to do a V8 engine ?
sfhess
PostPosted: Thu Oct 29, 2015 8:05 pm Reply with quote Back to top
I accidentally bumped mine to the off position while waiting to make a left turn on a busy street one time. What the......
super
PostPosted: Thu Oct 29, 2015 8:24 pm Reply with quote Back to top
i was going for the killing two birds with one stone type of thing
is the tool used in this video also usefull for measuring compression ?
Link
PostPosted: Thu Oct 29, 2015 8:28 pm Reply with quote Back to top
NO
super
PostPosted: Thu Oct 29, 2015 8:29 pm Reply with quote Back to top
ok then
PostPosted: Thu Oct 29, 2015 9:12 pm Reply with quote Back to top
You only want to do one at a time. You don't want compression in all the cylinders slowing the spin the starter can muster. Just pull all the plugs, leave the kill switch in the off position and measure one cylinder at a time with the throttles wide open. You obviously need a compression tester or adapter for 12mm plug hole.
