  • Total: 123,502,578
  • Today: 253,374
  • Nov 24, 2026
  • 09:12 pm PST
scottx
PostPosted: Thu Mar 26, 2015 12:47 am Reply with quote Back to top
Hi there
I'm trying to decide which pistons to buy for a CB900 rebuid.
Crusin Image is $230 cheaper than Forseti pistons and about $450 cheaper than Wiseco. I would love to hear a good report on using the Crusin pistons and then I can settle on them. If no one has a good report I will go for Wiscoe I think.
I'm putting new crank and con rod bearings.
New primary chain.
New timing chains and tensioners.
Reco cylinder head.
Maybe CR carbs.
Thanks for your thoughts
Scott
PostPosted: Thu Mar 26, 2015 1:18 am Reply with quote Back to top
I have heard nothing but good things about them but for my rebuild I went with Wiseco. Here in the U.S. I was able to purchase the Wiseco K985 kit for US$420 and the Cruzinimsge were US$160.
I figured the price difference was marginal given the other costs.
7fiddy
PostPosted: Thu Mar 26, 2015 2:15 am Reply with quote Back to top
I purchased some, still waiting on my jugs to be bored out though.
Man they don't play when it comes to shipping, I think a Japanese dude was airdropped over my house and he set the package at my door and darted off Laughing
All giddy on my 7fiddy
1980 CB750F Super Sport
1966 Ford Fairlane (Project)
2004 GMC Sierra
“Don't cry because it's over, smile because it happened.”
PostPosted: Thu Mar 26, 2015 2:27 am Reply with quote Back to top
I have two sets, one in my 985, and just bought another set for another 985 build. Best deal going, man.
PostPosted: Thu Mar 26, 2015 12:09 pm Reply with quote Back to top
I've installed several sets of Cruzin's..............
They are ~standard compression, cast pistons, most other brands are forged, high compression requiring higher octane fuel.
For high-end serious engine builders I offer custom made BILLET pistons by Diamond. The benefit with Diamond allows you to design every aspect of the piston including compression ratio, dome shape, ring width, wrist pin diameter, length and thickness, skirt symmetry, etc.
Cruzin's good for normal everyday use, quality on par with Honda OEM parts.
scottx
PostPosted: Thu Mar 26, 2015 6:55 pm Reply with quote Back to top
Cruzin is looking like it may be the way to go.
Only remaining question would be. Do you think the Wiscoe pistons with their higher compression would give a noticeable increase in power over the lower compression Cruzin
The reason I ask is that I got used to how my sidecar used to ride. The engine broke so quickest solution was to get another bike with a running engine and put it in. The engine I put in had good compression (140, 140, 130, 140) set the valve clearances and balanced the carbs. I'm only guessing but I think this is a standard bore on this engine now in the sidecar
The bike now has quite noticeably less power.
The broken engine once pulled down had domed shaped pistons which I guess are high compression.
I wonder if just the extra 85cc or so will be enough to "feel" the difference from the power of this standard engine currently in the sidecar.
I will never race or thrash the chair for long periods but if the Wiseco make a noticeable gain in power maybe they are still worth considering.
Thanks heaps for those who took the time to reply
Have a good one
Scott
PostPosted: Thu Mar 26, 2015 7:58 pm Reply with quote Back to top
High compression motors require premium or racing fuels.
The 3mm overbore is about a 6% increase in displacement and will run on weasel piss for fuel. Sort of a apples to oranges comparison.
If you're just using the bike for normal driving, go with Cruzin.
nugget
PostPosted: Thu Mar 26, 2015 11:56 pm Reply with quote Back to top
I love the weasel piss comment. It put a smile on my face😃
PostPosted: Fri Mar 27, 2015 12:59 am Reply with quote Back to top
sillygoose wrote:
I have heard nothing but good things about them....
There is this thread...
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=65842&postdays=0&postorder=asc&highlight=piston&start=0
He did get replacement parts quickly though. I think it amounts to what we already know about Chinese built mass production sold real cheap, there is no QC. But if you get replacement support from the seller, you just have to do your own QC, or have your machinist do it. That's why I say to always measure and go over every part of these piston kits with a fine tooth comb, even boring each hole specifically for each piston, and also obviously from that thread, even whether the supplied wrist pins fit properly.
PostPosted: Fri Mar 27, 2015 6:36 am Reply with quote Back to top
Seller emailed me that they were Taiwanese made pistons.
rexe
PostPosted: Fri Mar 27, 2015 7:25 am Reply with quote Back to top
I've done most of the mods you are talking about. Why go cheap? on the Pistons go Wiseco, proven power and reliability once you have all the other stuff sorted. Go cheap with a knew motor and it will cost you more real soon! Just my 2 cents worth
PostPosted: Fri Mar 27, 2015 12:12 pm Reply with quote Back to top
I think the real difference is that Wisecos are a high Compression forged piston, and can exacerbate some of the less desirable characteristics of the DOHC engine, including starter clutch and slow cranking problems, and can be an issue if only 91 octane fuel is available in hot weather.
The Crusin Image pistons are oversized cast pistons that are closer to the stock compression ratio....So the bike retains more of the stock characteristics.
I agree about spending a little extra to get the quality, but I'm not sure I want a super-high Compression DOHC motor on the street either.
PostPosted: Fri Mar 27, 2015 12:29 pm Reply with quote Back to top
Taiwan, the good Chinese. (republic of China, in case folks forgot).
brett_s
PostPosted: Fri Mar 27, 2015 2:40 pm Reply with quote Back to top
Has any one measured what compression ratio actually is with these on a 1100 vs stock Pistons? The extra cc's have to add some compression unless it's been designed into the piston.
Looks like it could be a great setup for a slightly above stock rebuild.
Brett
golfman
PostPosted: Sat Mar 28, 2015 6:05 pm Reply with quote Back to top
I only put a couple hundred km on mine so far but all is good.
FalldownPhil
PostPosted: Sun Mar 29, 2015 3:53 am Reply with quote Back to top
We have been using cruzinimage pistons with our CBX's with great success.
I know of a true race bike in Australia that is running a set and a few people that
I know personally that have hammered them for several years with no failures.
I would recommend them.
Just my own opinion.
Phil
Phil
Many CBX's
PostPosted: Sun Mar 29, 2015 2:26 pm Reply with quote Back to top
brett_s wrote:
Has any one measured what compression ratio actually is with these on a 1100 vs stock Pistons? Brett
The compression ratio is a calculated number. If the volume in the combustion chamber at TDC remains unchanged, the compression ratio goes up by the same percentage as the displacement.
brett_s
PostPosted: Sun Mar 29, 2015 4:02 pm Reply with quote Back to top
I assumed it went up linearly with the increase in volume, I just was curious if they had reduced the volume of the piston to keep it the same. Related question, what's the stock actual cr on a 1100? Is it the same as Honda advertised?
PostPosted: Mon Mar 30, 2015 4:27 pm Reply with quote Back to top
I as well, am not a great fan of Wiseco pistons. Specially their 985 pistons due to two different sets of ring sizes being available. there are other pistons available but under any other than racing conditions there are not many who can ride a stock 900 to it's fullest let alone an enhanced version. To me it seems counter productive to use race intended equipment on a street bike when simply increasing CCs would ad some degree of power and torque and I would look for less stress on engine parts and rider.lol
PostPosted: Tue Mar 31, 2015 5:59 pm Reply with quote Back to top
I think the CruzinImage piston sets are fine, as long as you do your own QC and due diligence so you insure that everything fits and you make any adjustments necessary.
As far as the Wiseco pistons go, I had a set of 985s in a 900C that I couldn't stop from pinging... It had all new cam chains and tensioners/guides, stock Honda of course, this was 30 years ago. I probably could have helped it with cam timing, but I didn't go there, as I was hot on the trail of converting it to 1100 parts with Megacycle cams. I attributed the pinging issue to it being a heavier bike, that ran hotter with all the fairing and stuff, and the new cam chains did keep it timed up full. Maybe the cams were a wee bit off too, no two sets seem to be exactly the same. I tried all manner of ignition retarding scenarios with the MSD I was running, the only thing that stopped it was about 93 octane or more.
We put those Wiseco 985 pistons in a 900F with somewhat used cam chains and it ran great, with no pinging. And my 1100 motor ran great too. I'll bet if I'd had the Cruzinimage 985 pistons with lower compression instead of the Wisecos, it would have been a whole different deal though.
surftalks
PostPosted: Tue Mar 31, 2015 8:32 pm Reply with quote Back to top
Anyone is the USA stocking the Cruzin Image piston kit for the CB1100F? I'm going to order a kit and I'd like to give the business to someone in the USA.
The only place I've seen them is on eBay.
Craig
PostPosted: Wed Apr 01, 2015 12:28 pm Reply with quote Back to top
Haven't heard anyone offer an opinion on these??
Anyone use them yet?
http://www.ebay.com/itm/231395464814?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
They appear to be the Cruzin Image pistons with pre-applied coatings on the piston dome and skirts
Quote:
This kit has 4 pistons for 72mm (2.835") bore and includes full floating wrist pins, clips, piston rings, matching head gasket and Ultra Slick assembly lube. These are quality cast high silicon aluminum pistons and rings imported from Japan and process coated in Canada. Composite head gasket is .065" thick. This kit will give you a 10.5:1 compression ratio. Wrist pin oil holes have a special chamfer for improved pin lubrication. The only machining required is to bore and hone your existing cylinders to accept the 72mm pistons.
This kit will add lots of power to your CB1100, the coating really works. More cc's, less friction and better combustion. Each set is inspected and weight matched during our process. Quality is guaranteed. Piston domes are coated with CBC1* thermal barrier and skirts with DFL1* high pressure dry film lubricant. Coatings are heat cured. Pins are coated with PKSX* high pressure dry film.
PostPosted: Wed Apr 01, 2015 5:44 pm Reply with quote Back to top
Personally, I think this should be done anyway.
Regarding the coatings that F4Fast has referred, they work. They can make you chase your tail a bit if you dont understand whats happening though. When you get the up to temp jetting correct, the engines will be cold blooded as hell. Theyll take forever to warm up, but its worth the extra couple minutes.
One thing Im curious, the company thats enhancing these piston, i wonder why they dont add a lateral gas port to the top ring land. That aids sealing of the top ring considerably and its pretty easy.
Bone
PostPosted: Thu Apr 02, 2015 7:45 am Reply with quote Back to top
G'Day Scott.
I am thinking that since my engine is out, I may do a rebuild and try the cruzinimage 985 pistons. Who are you going to use in Sydney to bore the cylinders?
Cheers,
1982 CB900FC
1981 CB900F2B
damage
PostPosted: Thu Apr 02, 2015 11:17 am Reply with quote Back to top
G'day all,
One of the guys I race with has been using a set of C.I. pistons in his race bike for the last 18 months with no problems so far.It is fairly stock apart from 1100F cams but it gets the tits revved off it.I figure if they will last in a race bike they should last in a road bike.
Chris.
1999 Triumph Sprint St 955
1979 CB900f
1992 Suzuki GSX1100G sidecar
1996 Suzuki 1200 Bandit
1970 Honda CB350 P4 race bike
1985 Kawasaki GPZ900 P6 race bike
2012 MV Brutale 1090RR
If you're not living on the edge,you're taking up too much space
herdygerdy
PostPosted: Thu Apr 02, 2015 7:31 pm Reply with quote Back to top
Bone wrote:
G'Day Scott.
Cheers,
Hi Chris,
I am thinking about a set of CI pistons for my CBX and have spoken to Greg Ball at Greg Ball Motorcycle Engineering, at 4 Ethel Road Kirrawee, Ph 9521-8470. Been a while since I spoke to him (I don't yet have the pistons), but he was talking around $60 per hole to bore. And it was obvious from our discussion he knew precisely what he was doing.
Hope this helps and good luck with your build.
Cheers...Tony
Bone
PostPosted: Thu Apr 02, 2015 7:54 pm Reply with quote Back to top
Thanks Tony, that is very helpful. Some googling on motorcycle engine work in Sydney had his name come up a few times also, so I think he may be the go-to guy.
I assume that you purchase pistons and rings and take them with the cylinders to be matched with the re-bore?
What about head-work? Is porting something you can DIY with dremel, or best left to someone like Greg? (sorry for thread drift)
Regards,
1982 CB900FC
1981 CB900F2B
herdygerdy
PostPosted: Thu Apr 02, 2015 8:48 pm Reply with quote Back to top
Regards,
You are correct Chris in purchasing your pistons and rings and take them, along with the barrels to Greg for boring. You will need to label the pistons with their destination cylinder no. (use a permanent marking pen and label both the piston crown and underneath the piston crown as well, just to be sure. Probably worth taking the wrist pins as well.
Re the head work, unless you REALLY know what you are doing and/or have access to a flow bench, I would resist doing the porting thing, esp. on a street bike. Add to that the stock compression ratio of the CI pistions, not really sure what you may achieve. IMHO, better off getting Greg to ensure a good 3 angle valve seat cut is done correctly and ensuring the valves and guides are all perfect and consider 1100 cams if not done already. And of course, replace the valve stem seals with a set from Genesound here. And a set of CBR coils and ign. coil relay and finally the Captain's guides and tensioner. All of this would be the best money to spend on your bike in my book and give you a strong running uber reliable streeter to be enjoyed for many years to come.
Now back to original transmission of this thread. Have an ab fab and very choccy Easter all.
Bone
PostPosted: Thu Apr 02, 2015 9:56 pm Reply with quote Back to top
Thanks Tony,
I think I will order the Cruzin Image pistons. Already have the viton valve seals and cam bolts. Will get Captain's guides and new cam chains.
Cheers,
1982 CB900FC
1981 CB900F2B
Dobbo
PostPosted: Fri Apr 03, 2015 11:36 pm Reply with quote Back to top
I've used Greg Ball to do the heads and re bore the barrels on both my 750 rebuilds. Charged me $65.00 per hole on the barrels and $500. 00 on the first head and $590.00 on the second as it needed at bit more work.
Greg has been around a long time and the boys know their stuff.
Dobbo.
Page Generation: 0.09 Seconds
