  • Total: 105,390,754
  • Today: 61,783
  • May 01, 2026
  • 09:37 pm PDT
scottx
PostPosted: Tue Mar 10, 2015 5:43 am Reply with quote Back to top
Hi
I ordered a gasket kit for a CB900 on Saturday and it arrived here to Sydney Tuesday. Fast delivery for sure.
A question about the head gasket for you.
Is the gasket meant to be round where it seals around the top of each cylinder.
The one on the engine I just pulled apart is round, while the one from Crusin image is not circular.
smoked21
PostPosted: Tue Mar 10, 2015 2:01 pm Reply with quote Back to top
That is not the right gasket,It should be round
PostPosted: Tue Mar 10, 2015 2:18 pm Reply with quote Back to top
I think it is right. Just took my 1000c motor apart and the head gasket is just like that. I can post a pic when I get home......
Edit: Also if you look at the parts fiche (I use service honda) the gasket has that kind of shape.....
PostPosted: Tue Mar 10, 2015 4:34 pm Reply with quote Back to top
Real OEM CB900 gaskets are not round, they are shaped like that. His gaskets are a copy of the real ones.
7fiddy
PostPosted: Fri Mar 20, 2015 12:49 am Reply with quote Back to top
Just got my cruzin image kit and the gasket is round...
All giddy on my 7fiddy
1980 CB750F Super Sport
1966 Ford Fairlane (Project)
2004 GMC Sierra
“Don't cry because it's over, smile because it happened.”
DennisTheMenace
PostPosted: Fri Mar 20, 2015 1:59 am Reply with quote Back to top
The CB-F composite head gaskets come both ways depending on who made them - round and 'ovoid' near the valves. Both work fine.
PostPosted: Fri Mar 20, 2015 11:14 am Reply with quote Back to top
My stock 900 had a non-round gasket.
surftalks
PostPosted: Mon Mar 30, 2015 9:31 pm Reply with quote Back to top
Anyone is the USA stocking the Cruzin Image piston kit for the CB1100F? I'm going to order a kit and I'd like to give the business to someone in the USA.
The only place I've seen them is on eBay.
Craig
