  • Total: 105,390,730
  • Today: 61,759
  • May 01, 2026
  • 09:36 pm PDT
PostPosted: Thu Nov 13, 2014 11:09 am Reply with quote Back to top
Junior eats a transmission bearing.... On the last ride of the year Junior (my F2 suspended 1100 motor equipped project bike) started making a weird humming / vibrating type noise. At first I thought it was a cam chain noise but it changed when the clutch lever was held in. SteveG came over last night and we found the bearing on the inner end of transmission output / countershaft had disintegrated then spun the outer race taking both the upper and lower case halves out. Steve has the images so I will post them soon.
Marcus Aurelius
PostPosted: Thu Nov 13, 2014 11:12 am Reply with quote Back to top
Ouch!
PostPosted: Thu Nov 13, 2014 2:15 pm Reply with quote Back to top
The noise was a growl / vibration in the clutch area. We had no idea it would be this. Our thoughts were running towards clutch bearing(s). Ugh.
Some disgusting pictures (both content and quality (Used smartphone, forgot good camera)).
Steve
And in about an hour the motor was out and waiting for new cases:
‘79 CB750(810)F, \'81 CB900(985)F, \'82 CB900(Going to be 1100)F, \'82 CBX, \'06 WeeStrom, ’18 Kawa Z900RS \'22 CanAm Ryker Rally
WileCyot
PostPosted: Thu Nov 13, 2014 2:59 pm Reply with quote Back to top
Could you overbore the hole and run a larger OD bearing?
PostPosted: Thu Nov 13, 2014 4:09 pm Reply with quote Back to top
Ouch..... not seen that before, especially as the bearing outer has a locating dowel to locate it and stop it spinning
Still lucky it happened now at the end of the riding season and not in the spring
PostPosted: Thu Nov 13, 2014 8:02 pm Reply with quote Back to top
Wow! Bummer, that's a new one.
PostPosted: Thu Nov 13, 2014 8:52 pm Reply with quote Back to top
That sucks Doc, at least you (and Steve) have all winter to sort that mess out.
Keep us posted.
PostPosted: Fri Nov 14, 2014 7:21 am Reply with quote Back to top
WOW I also have not seen this. How did you get bearing cap come out with the pin in????
I left one out and after putting the whole motor together I found it laying on the bench. Had to split the cases and clean all the 3 bond out and start over. Sometimes it aint no fun.
Have fun with it.
PostPosted: Fri Nov 14, 2014 3:17 pm Reply with quote Back to top
OH man Doc!! I'm sorry to hear Junior is ailing but he's in good hand. m
PostPosted: Fri Nov 14, 2014 6:52 pm Reply with quote Back to top
When SteveG and I were taking it out / apart he offered the opinion I left the pin out....Now I not saying 100% that didn't happen but after doing about 10 of these motors in the last few years I sincerely doubt it.....I always look for the engagement of the pin in the hole on the bearing cup. A little background on this particular motor here is warranted. This 1100 motor is a combination of several different bit's laying around. The cases came from one source the crank / rods from another and the cylinders, head, transmission ect...came from a motor that ate a rod bearing badly. I have the cases from the motor that ate the rod bearing and they are usable and a fully assembled 750 motor with trans in it (I know the 1100 gears are different but I hope to use the countershaft and bearings.) Partszilla says the countershaft is different between the 750 & 1100 but is it really?
Marcus Aurelius
PostPosted: Fri Nov 14, 2014 7:19 pm Reply with quote Back to top
Hi
I always use this to cross ref. part #'s
http://www.ronnies.com/micro.htm
PostPosted: Sat Mar 07, 2015 7:31 pm Reply with quote Back to top
The motor is back together and in the bike...Start up will be an evening next week....Hooray.
Thanks to SteveG for the teardown and reassembly help, Grump for the transmission and primary shaft and Phil for the oil pump gasket. The rest was laying around.
The old cases were destroyed...The consensus is I left the locator pin out of the case on the blind end of the transmission countershaft......
The replacement cases had crack over the top of the clutch which I had welded (professionally.)
Part of the damage was the back of the clutch basket and the primary gear dampener....
One of Grumps part...
The motor was painted with Urethane paint and the power coated covers were installed..
A little effort and Voila!
Marcus Aurelius
PostPosted: Sun Mar 08, 2015 2:24 pm Reply with quote Back to top
That looks like a clever application of using ratcheting straps and a beam to allow you to slide that engine into place....Did that allow you to do the job by yourself?
DennisTheMenace
PostPosted: Sun Mar 08, 2015 4:19 pm Reply with quote Back to top
Made me go look - in a billion years, I would have never thought of installing an engine that way. I just stuff 'em in there with DennisPower and scratch the living beejeezus out of everything and curse a lot.
PostPosted: Mon Mar 09, 2015 1:35 am Reply with quote Back to top
I've heard of that beam and strap, read about it here on the forum before, maybe it was you. How does it work out?
PostPosted: Mon Mar 09, 2015 2:30 am Reply with quote Back to top
It never ceases to amaze me how you guys go at it and bum rush the repairs that you do!
Big fat Hell Yeah to your drive and perseverance....!!!!!
Way to be!
PostPosted: Mon Mar 09, 2015 10:36 am Reply with quote Back to top
I have previously used the strap a 2 x 4 across the back of the motor and call a buddy (SteveG and buddy Dave both volunteered to help) method. This time I was being stubborn and wanted to do it myself. This was slightly trickier since Junior has a welded in right frame section. The key was the "curb shopped" section of steel tube that was part of a home gum system before being repurposed. The powder coated white tube slid easily down the big straps and having the bike on the lift allowed infinite up and down / fore and aft adjustments. This should be the last hurrah for one of these removal / install since I am in the process of building an adjustable motor lift for removing these bike motors. I will post images when that is done!
Marcus Aurelius
