Wed Oct 29, 2014 3:23 pm |
Has anyone tried an R tank with F bodywork? R's are cool but the tail section doesn't do much for me. Love the tank and it looks like if positioned correctly it would match up to the F side covers. Did a few searches and could not find anything. Might look like the Spencer replica that was made from a new CB1100. |
Wed Oct 29, 2014 3:26 pm |
I know Soy is talking about something like this too. I have read his posts and it gets kinda jumbled in the brain......... |
Wed Oct 29, 2014 3:32 pm |
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&p=165780&highlight=#165780
Now goes under the username CB1100RR .... |
_________________ PETRAT
Wed Oct 29, 2014 3:42 pm |
Thanks Darren. I knew someone would have done it and that it would look awesome! Keep the F lines with kinda of an updated look with the contoured tank. Hmmmmm.....now I need a tank! |
Wed Oct 29, 2014 3:45 pm |
| petrat wrote: |
I forgot about that one Darren. I liked everything EXCEPT the dirt bike bars. Why do people do that?? |
Wed Oct 29, 2014 3:57 pm |
| JJam wrote: |
| petrat wrote: |
Probably the same reason I did it .... however I do have a set of proper superbike bars to go on mine. |
metalganz
Wed Oct 29, 2014 4:40 pm |
Hello Russ,the R tank works shorter than the Original. So you can pull back the tank to fit the reartankbolt,but than there is to much space at the front between the tank and the frame.
Also you have to watch out with the fuell tap,meaning that they are short on the carbs,so positioning the tank is important.
I have done some work for a member on brackets to fit the R tank on an F frame,and also have build a special fuell tap that fit`s without contact to the carbs.
The guy with the name CB1100RR is a dutch fella ,how he has rebuild the frame to fit the tank I don`t know.But can ask him about this.
Don`t think he is often on the forum so if you want I can give a message to him and he can responde in this tread.
Wim |
Wed Oct 29, 2014 5:16 pm |
| 1100russ wrote: |
Are you willing to spend at least $500.-  |
Wed Oct 29, 2014 5:26 pm |
The bike has been transformed since that time. I believe he adopted a CB919 (900 Hornet) tank and a different tail cowl from an R6 since the thread posted above >>>> http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=44944&postdays=0&postorder=asc&start=0
Wed Oct 29, 2014 5:40 pm |
Wim thank you VERY MUCH I would love to hear from Rene!
Yes Rob I am very willing to spend 500 dollars if I can find one that cheap. Is there still a company (in Germany I think?) that makes replica body work?
And Darren it looks like a VFR 750 (maybe Ducati?) swing arm. With the under tail exhaust! I must have seen this bike before and don't remember because that is all stuff I'm thinking about for my track bike! But I want the F tail and side covers. If I want an R6 or a CBR I will buy one. |
Wed Oct 29, 2014 5:44 pm |
| petrat wrote: |
| JJam wrote: |
| petrat wrote: |
He talks about it in his thread. More control during "spirited" riding.  |
metalganz
Wed Oct 29, 2014 9:19 pm |
Have send a message to Rene thrue a dutch forum,so I hope he will respond! |
CB1100RR
Wed Oct 29, 2014 9:58 pm |
Got ur message Wim
Before i turned my F into a Streetfighter i had a replica R tank on. Because i also had the USD forks i had less space so ik had to drag the tank a bit backwards. Because i ad the side panels on the bike too i had to modify the tank a bit.
Later when i started the single sided arm i decided to go radical and turned it into what she is now. See the pic i added
Wed Oct 29, 2014 11:46 pm |
| CB1100RR wrote: |
Got ur message Wim
Could you post a photo of the bike you're discussing? |
CT110 Hyper Sport |
Thu Oct 30, 2014 12:35 am |
I think 6 or 7 years ago both Fasterspider and Powerroy used R tanks on their F.
Probably info in the archives. |
Thu Oct 30, 2014 12:39 am |
| smurdoch wrote: |
I saw a pic of Roy's looking through old threads but none of fasterspider's pics will come up. |
Sly_G
Thu Oct 30, 2014 12:58 am |
Thu Oct 30, 2014 1:12 am |
| smurdoch wrote: |
Yes, both did ...... cbxdog owns the one Roy built. ANDY also fitted an R tank to an F ..... so did Tdem ...... but these were all accompanied with an R tail.
It can be done easily. I believe you can use the same rear mount, but you must change the location of the front rubber mounts (move them back). |
CB1100RR
Thu Oct 30, 2014 6:12 am |
I'll be digging in my pictures this evening and post some witrh the R tank here  |
Thu Oct 30, 2014 9:49 am |
| CB1100RR wrote: |
Rene that would be awesome! Especially pics of the tank mounts. Did you move the front mounts back or the rear hole forward? Also the petcock (fuel tap) placement and how you
routed the fuel line. Can't be that hard (famous last words ) but it would be nice to have some ideas. Nice ride by the way.........  |
Andylarkin
Thu Oct 30, 2014 10:58 am |
| 1100russ wrote: |
| CB1100RR wrote: |
I took a load of pictures years back (I think for Ray when he was doing this) which showed the R tank on an F frame. This is the only one I can find now. God knows where they've gone?
But it clearly shows the difference of the rear mounting points!
Thu Oct 30, 2014 12:08 pm |
| Andylarkin wrote: |
| 1100russ wrote: |
| CB1100RR wrote: |
Thanks Andy. Darren's link (and the links I found because of it thank you very much Petrat) showed me some of the issues I'm going to run into. Seems if I move the rear mount forward and use the existing front mounts I will have tank to handlebar interference (Not good. You can't counter steer at low speeds ) so any info or pics you guys can share will be a BIG help. |
Thu Oct 30, 2014 12:11 pm |
Another thing is fitting with the side covers. That might be the deciding factor of where I can place the tank? |
Thu Oct 30, 2014 12:39 pm |
Move the front mounts back and use the existing rear mount. All you need to do is drill a hole through the webbing at the front, insert a tube through (the same diameter as the tube that is already there to hold the rubber mounts in position), and weld it in place. The lines of the R tank are wider than those of the side panels so you will never get perfect alignment between them. |
Thu Oct 30, 2014 3:28 pm |
| petrat wrote: |
| JJam wrote: |
| petrat wrote: |
You put dirt bike bars on?
Oh Darren, I have lost all faith in you now. What has the world come to??
There are plenty of opinions out there and I happen to like mine the most. LOL
Keep it in a wheelie, Jim |
Fri Oct 31, 2014 4:16 pm |
| petrat wrote: |
| Move the front mounts back and use the existing rear mount. All you need to do is drill a hole through the webbing at the front, insert a tube through (the same diameter as the tube that is already there to hold the rubber mounts in position), and weld it in place. . |
You can also make pieces out of aluminum to fit into the mounts on the tank, which will effectively move these forward to hold onto the stock tank rubber mounts. |
CB1100RR
Wed Nov 05, 2014 8:06 pm |
Had to dig deep to find some pictures, unfortunately i can't find any close up pics from the mount, that is yet, i must have them, only where ?
CB1100RR
Wed Nov 05, 2014 8:08 pm |
CB1100RR
Wed Nov 05, 2014 8:09 pm |
CB1100RR
Wed Nov 05, 2014 8:11 pm |
The last one is with the rebuild 1100F motor. |
_________________ Honda CB1100RR StreetFighter, Honda GL1500 Aspencade, Suzuki GSXR884W |
Goto page 1, 2 Next
