  • Total: 123,502,823
  • Today: 253,619
  • Nov 24, 2026
  • 09:14 pm PST
CBX1260cc
PostPosted: Sun May 25, 2014 12:10 pm Reply with quote Back to top
I would like to get a NICE set of digital calipers for shim measurement etch
BUT
I also want to measure things like the inside size of bearings / seal so think this would involve a set of Vernier calipers.
Went to local Sears yesterday and all they had was a set of Dial calipers.
Anyone care to suggest a source for an instrument that is Digital and can be used for BOTH??
Thank you
PostPosted: Sun May 25, 2014 12:52 pm Reply with quote Back to top
Best way to measure ID is a bore gauge but if you're not going to be doing this very often then that might not be the best route due to price. With any measuring instruments I've found that the closer you stay to the GOOD brands the beter off you'll be. Look for Starrett, Brown & Sharp, Mitutoyo to name a few.
toonces
PostPosted: Sun May 25, 2014 2:38 pm Reply with quote Back to top
A micrometer's what you need to measure the shim thickness
PostPosted: Sun May 25, 2014 5:28 pm Reply with quote Back to top
I have many of each and calipers of any type or brand just get you close IMO.
I also have this to say about high end digital calipers compared to lets say Harbor Freight ones. I prefer the HF digital calipers (remember I only use the calipers to get me close then I bust out the mic) because they shut them selves off if you forget and leave them on. You can turn them off and they will still remember the setting that you left them at as opposed to my Mitutoyo ones.
I have checked them all for accuracy on my gage blocks and the cheap ones always do as good as the expensive ones.
Plus if I drop them, I don't really care because they were $19.00 as opposed to $165.00 that I have paid for the name brand.
Just remember that calipers are just to get you close and in most cases that is all you will ever need for the garage.
Batteries being in good shape is the key on any of them.
Fowler makes some decent ones that won't break the bank if you just don't trust the HF ones. Also if you get the HF ones or any of them. Be sure to open the box and check to see how smooth they are. Some feel gritty and that bothers me.
Just my 2 cents.
CBX1260cc
PostPosted: Sun May 25, 2014 6:59 pm Reply with quote Back to top
JJam,
Funny you should mention the Harbor Freight one as I received a catalog Yesterday and low and behold on the 2nd page was model you refer to.
I wanted to get one for shim measurement--some have no numbers on them due to wear and tear and also to determine axle sizes for a CalFab swing arm I have at home to determine if it will fit on the proposed application.
So--guess for what I need (just close not 100% accurate) then the Harbor Freight one should work just fine.
THANK YOU
FalldownPhil
PostPosted: Sun May 25, 2014 8:13 pm Reply with quote Back to top
Dial or Digital calipers are commonly referred to as a "Guess Stick" by any machinist.
Phil
Phil
Many CBX's
PostPosted: Mon May 26, 2014 12:30 am Reply with quote Back to top
No way I'm wearing out my $2-300 Mitutoyo mics to measure shims. Too expensive a tool for the job, that much accuracy isn't necessary, and they take far too long to use to read each one. Valve lash has a huge amount tolerance in the spec and you check it with feelers when you're all done to make sure it's within a couple of thousandths. So, I just use a decent dial caliper, because it's accurate enough, and I can see/feel if one shim is just a wee bit thinner than another, but it's also fast and easiest to read quickly. I don't even have a metric dial caliper, I just use a 6" Imperial one for shims, and keep a conversion chart on my shim box, it's been on there for decades. I have a digital one, but the analog dial one is so much quicker and easier to look at and see a tiny bit of difference without actually reading the numbers.
click pics
PostPosted: Mon May 26, 2014 1:39 am Reply with quote Back to top
Phil
That's exactly what I was taught. So I just mainly se mic's for the final cuts.
I also agree with Genesound's dial caliper advise. No batteries to go bad or electronics.
I am use to the HF calipers and have one that will read in mm, in., and fractions for the person without a conversion chart. Its a multi tool that gets you close enough for everything outside of the motor, suspension component's and brake component's.
Keep it in a wheelie, Jim
PostPosted: Mon May 26, 2014 5:58 am Reply with quote Back to top
+1 Very Happy
PostPosted: Mon May 26, 2014 1:07 pm Reply with quote Back to top
click pics
This hits it on the head.....the most important measurement in regard to shims, is the feeler gauge measurement of the new clearance between the shim and the cam base circle.
For the most part, the actual measurement of the shims is just a guide to get you to the proper feeler gauge measurement. In most cases, the ink stamp on the shim is good enough, and after that, you feel loose and tight with the feeler gauge which is the manufacturing tolerances of each stated shim size.
However, at this age, I don't worry about wearing out stuff like good calipers, although I confess to having a large magnifying glass to read stuff like vernier graduations. (No digital measuring instruments)
