  • Total: 118,234,048
  • Today: 7,964
  • Oct 25, 2026
  • 01:53 am PDT
glenda
PostPosted: Thu Apr 17, 2014 5:15 pm Reply with quote Back to top
Hi folks !
Hope this spring 2014 finds you well.
Me, not so much. My bartering mechanic friend got the bike back together a couple weeks ago and he thought she sounded okay with the new jetting / info you all provided, but then she started leaking fuel from the #4 carb, I think he said.
The season is now upon us and he's swamped and I have no ride. I can't go another summer without a bike. I don't know what to do. Still in the position of wanting Clara B to run, but I also understand I cannot maintain her and that she's no one's priority but mine.
Anyway, not to sound too pitiful. I did search for a part 16027-425-671 from local dealer. No luck. So now it's an 0 ring I need, and it means a lot of work going back into the engine, with no guarantees of success. I have been tasked with doing as much of the work to get back in as I can. I want to do this yesterday. Ha.
But really I'm wondering -- how do I do this ? Should I part her out and hope I can get the cash together this summer for a new bike ? Should I bother one of my friends to help me get to the 0 ring ? Does it make any sense to invest in carbs for a bike so old that I cannot maintain myself ? Or should I buy something newer (given I somehow find some funds for another new-to-me bike)?
I know that's a lot of questions. I thank you for whatever advice / thoughts you feel like sharing.
PS Those who don't know my story -- ClaraB is a 1979 CB750. I got her when my mate Matt was still alive. He had a CB1100f and was a member of this forum before his death the summer of 2006 in a motorcycle accident. Knowledgeable guy who's proven irreplaceable. I miss him. He taught me to ride safe, and infected me with this love of motorcycling that is making my life a little crazy now that I don't have a running ride.
Figure a few of you might be able to relate ?
THANKS AGAIN.
Glenda
Thread related to Jetting:
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=72181&highlight=
cbxdog
PostPosted: Thu Apr 17, 2014 5:19 pm Reply with quote Back to top
Welcome back Glenda,,
Looks like the part is a fuel joint o ring which is leaking ? 16027-425-671
May be easier - less labor intensive to find a replacement set of carbs rather than disassembling the carb rack to replace a few o rings.
Let me look in my parts stash, I may have a set of carbs for you
1980 CBX
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed
PostPosted: Thu Apr 17, 2014 9:42 pm Reply with quote Back to top
Ah...the fuel joint O-ring.....sitting makes them shrink and brittle....
Randakk sells a kit that has these O-rings....it is pricey...but it also has all of the other seals that will
potentially go bad on your carbs...
They are made of a better material called Viton. They will last 10X longer than the original equipment.
The O-ring is not horrible to change....from the diagram you can see how it comes apart.....but I don't know
how technical you are as you said you want to do it yourself.
Larry is looking for carbs for you...he has a lot of nice stash....that is one way out.
Myself, The Fox, or Mike Nixon could go through the carbs for you.....I am backed up a bit...PM "The Fox"...he does
good work. Mike is a legend....if you send them to him....they will be perfect. Downside is some waiting.
Why am I saying all of this? If one seal is leaking...eventually they all will.
Should you get a new bike? Nah....I don't believe you would like it as much. Then, how new is new?...10 year old bikes have problems too.
From what I remember it has a new motor...and the recommended maintenance was done at that time so I would fix the carbs and ride Smile
Best,
PostPosted: Fri Apr 18, 2014 2:55 am Reply with quote Back to top
Hi glenda,
Just seeing your name on the site puts a smile on my face. I agree with Jebby. He should maybe have added JJam to the list as well.
I think you'd miss her.
Bill
norm
PostPosted: Fri Apr 18, 2014 5:02 am Reply with quote Back to top
Must be somebody over there who can help Glenda out, at least help/show her how to pull a set of carbs out,we are a big community of members wanting to help.
bobcat7
PostPosted: Fri Apr 18, 2014 7:40 am Reply with quote Back to top
Very Happy there is ! I sent a pm.
bikeboy
PostPosted: Fri Apr 18, 2014 9:18 am Reply with quote Back to top
result Wink
Hang in there Glenda, you're in good hands
TheFox
PostPosted: Fri Apr 18, 2014 11:17 am Reply with quote Back to top
A leaking fuel rail isn't too bad. As Jebby said, if you get the rebuild kit there are several of us who can setup the carbs for you if this isn't something you want to take on. Splitting the carbs isn't too bad. A good set of needle nosed pliers help they synch screw washers get back in place upon assembly.
Want your carbs CLEAN? Go Ultrasonic. Drop me a PM
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=47294&highlight=ultrasonic
PostPosted: Fri Apr 18, 2014 11:32 am Reply with quote Back to top
Hi Glenda. Nice to see you post.
I haven't heard from Rob Tabish in some time, but I think you should probably have his number. Maybe he can help or knows someone local to you that can help you. I'm pretty sure Sean Grier (member sgrier) has those o-rings in stock for cheap, he's in Seattle, but can send them in days. I'm in touch with Sean often on other sites. PM me if you'd like some help.
norm
PostPosted: Fri Apr 18, 2014 9:14 pm Reply with quote Back to top
Good on you Bobcat
bobcat7
PostPosted: Fri Apr 18, 2014 11:00 pm Reply with quote Back to top
norm wrote:
Good on you Bobcat
thanks Norm, but as yet I have had no reply. I was going to do
this at no charge other than shipping just as a sympathetic
gesture. oh well, I offered ! Confused
PostPosted: Fri Apr 18, 2014 11:27 pm Reply with quote Back to top
bobcat7 wrote:
norm wrote:
Good on you Bobcat
Give her a bit more time, Bob, and I'll bet she'll be in touch, sir.
cbxdog
PostPosted: Mon Apr 21, 2014 1:12 pm Reply with quote Back to top
Check your PM's Glenda,, I think we can get you up and riding ..
1980 CBX
1970 HD FLH
1976 HD FX
1983 HD FXRT
1970 AMC Javelin
PostPosted: Mon Apr 21, 2014 1:53 pm Reply with quote Back to top
Hi Glenda
glenda
PostPosted: Mon Apr 28, 2014 8:09 pm Reply with quote Back to top
Hi folks !! I'm back. Sorry for the note and then the disappearing act. I went into a bit of a funk ! Just so overwhelming and this week has a couple of sad anniversaries, including Matt's birthday. But I'm back. I thought the High Speed Wobbles were behind me, but that's the thing about Grief. It sneaks back up on you and kicks you when you're down, and the lack of a bike is a downer.
You guys are definitely an Upper ! I cannot tell you how much it makes my heart smile to think that you all are out there !
I can do this.
Again, sorry for the delay. I'll be back real soon this time.
I can do this !!
bobcat7
PostPosted: Tue Apr 29, 2014 4:28 am Reply with quote Back to top
its Spring and the sun is shining ! the best way to get
beyond the funk is to get back behind the handlebars
looking at the road ahead ! Very Happy Cool
glenda
PostPosted: Tue May 06, 2014 6:01 am Reply with quote Back to top
Yahooooo !! Bobcat has Clara B's carbs. He kindly sent me a photo of the carbs on his work bench surrounded by all the important tools of the job. So happy to have such an expert working on her. Tee Hee (see picture below). Isn't this wonderful ('Smile')
Now I gotta figure out how to upload the photo.
Seriously, thank you so much Bob !
PostPosted: Tue May 06, 2014 3:25 pm Reply with quote Back to top
Always use an impact on carbs Bob? Shocked
bobcat7
PostPosted: Tue May 06, 2014 5:38 pm Reply with quote Back to top
no, usually just the hatchet and hacksaw Laughing
retcol
PostPosted: Tue May 06, 2014 5:45 pm Reply with quote Back to top
if anybody can rebuild a set of carbs to perfection, Bob can. I know, he has done it for me. Glenda, you'll get better than new carbs back from Bob. Good luck with your bike.
PostPosted: Tue May 06, 2014 5:56 pm Reply with quote Back to top
I have been tempted to use a hatchet on carbs before..... I understood the other tools! Twisted Evil
PostPosted: Tue May 06, 2014 8:14 pm Reply with quote Back to top
You are in good hands with Bob.....
norm
PostPosted: Tue May 06, 2014 10:22 pm Reply with quote Back to top
Tool I thought was missing is a chainsaw, you must have a chainsaw if you want to get it right Very Happy
bobcat7
PostPosted: Tue May 06, 2014 10:55 pm Reply with quote Back to top
Laughing I thought about putting that in the pic too, but I thought I would
keep the absurdity simple ! work is properly underway ! Cool
glenda
PostPosted: Wed May 07, 2014 5:04 am Reply with quote Back to top
A chainsaw, you must have a chainsaw !! I think I might have clued in then ! Thank you all for your supportive comments !!
djhurayt
PostPosted: Wed May 07, 2014 11:53 am Reply with quote Back to top
I particularly like the use of a propane torch when working around gasoline Laughing
cbxdog
PostPosted: Wed May 07, 2014 12:45 pm Reply with quote Back to top
Now here's a guy who knows his tools Wink
1980 CBX
1970 HD FLH
1976 HD FX
1983 HD FXRT
1970 AMC Javelin
bobcat7
PostPosted: Wed May 07, 2014 6:02 pm Reply with quote Back to top
cbxdog wrote:
djhurayt wrote:
I particularly like the use of a propane torch when working around gasoline Twisted Evil Laughing
I use it to find fuel leaks ! Twisted Evil
djhurayt
PostPosted: Thu May 08, 2014 11:36 am Reply with quote Back to top
that will do it
good on you Bob for helping out Glenda and/or anybody for that matter beerchug
djhurayt
PostPosted: Thu May 08, 2014 11:37 am Reply with quote Back to top
that will do it
Page Generation: 0.10 Seconds
