  • Total: 118,364,487
  • Today: 38,863
  • Oct 26, 2026
  • 08:09 am PDT
jacksondee
PostPosted: Fri Mar 28, 2014 11:25 pm Reply with quote Back to top
I've been trying to search for this, excuse me if I missed it:
What's everyone's preferred oil?
Winter is coming to an end here in Chicago. We've had one of the worst on record... I am ready to ride and would like to have some fresh oil and based on things I've read on other forums, I am starting to wonder if I don't need to spend the extra $ for GN4?
1981 CB750F
2003 GSX-R750 (track bike)
PostPosted: Fri Mar 28, 2014 11:34 pm Reply with quote Back to top
Amsoil is really good stuff but Quite Expensive. I have been using Lucas synthetic blend 10w-40 for a few years now and it is good stuff for half the price of Amsoil. I like using synthetic blend because the synthetic oil molecules while much slicker and robust are much larger than natural oil molecules. Not all manufacturers recommend synthetic oil for their engines for this fact, especially when they are new and the tolerances are nice and tight. Just my humble opinion.
jacksondee
PostPosted: Fri Mar 28, 2014 11:39 pm Reply with quote Back to top
Thanks. I had just read a bunch about Shell Rotella. Its only my second season riding. When I bought the bike I didn't know any better and put in Honda GN4 and it was also quite expensive. I thought it was the best but came across the Rotella thread on another forum and its much cheaper than GN4..
I did notice that on the hottest days last summer, I'm talking about 100 degree F, it was hard to shift the bike into neutral, sometimes it would even stick between the first few gears.. I was lead to believe this is an oil thing..
1981 CB750F
ZGrand
PostPosted: Sat Mar 29, 2014 1:26 am Reply with quote Back to top
Honda GN4 (10w-40) for me. I run Rotella synthetic in the modern bikes, but the Honda conventional oil in the older ones. I put Rotella in my CBX once and (in my opinion) it caused the clutch to start slipping. I buy it in the gallon container -- it costs about the same as the Rotella that way.
82 CB900F
79 CBX
90 Honda Hawk GT
00 Kawasaki W650
04 Yamaha FZ1
06 Suzuki DR650
redstedman
PostPosted: Sat Mar 29, 2014 1:57 am Reply with quote Back to top
Murderer. Killed another kitten.
Dead Horse
79 CBX
82 CB 900F
82 GS 1100E
83 CB 1123F
83 SP 100
Yamaha Razz
PostPosted: Sat Mar 29, 2014 9:00 am Reply with quote Back to top
As long as we went down this road again, I think there actually is a new development in oil.
Saw on another bike site that Rotella T6 5w-40 synthetic is JASO certified..I'm not sure how those particular JASO designations translate backwards to our bikes requirements. The specs do mention increased resistance to shear which would seem important for oil that lubricates cylinder walls and a gearbox. Does that mean it may be an option for our bikes now?? Still doesn't show MC's as an application in specs though
Available cheap at the evil empire.....
Quote:
Shell Rotella T6 5w40 (API CJ-4, CI-4+, CI-4, CH-4, CG-4/SM), ACEA E9, Cat ECF-3, ECF-2, Cummins CES 20081, Mack EO-O Premium Plus, DC 93K218, MAN 3275, MB 228.31, Volvo VDS-4, JASO DH-2, JASO MA.
indison
PostPosted: Sat Mar 29, 2014 9:27 am Reply with quote Back to top
Penrite...
AGDT
PostPosted: Sat Mar 29, 2014 11:04 am Reply with quote Back to top
Castrol GPS
1980 CB750FZ with 1123 engine
PostPosted: Sat Mar 29, 2014 11:29 am Reply with quote Back to top
But I love kitties......... Twisted Evil
PostPosted: Sat Mar 29, 2014 12:27 pm Reply with quote Back to top
Valvoline 20-50 motorcycle oil in all my bikes. JASO certified, fairly priced and usually goes on sale at Autozone in the spring.
psychodad
PostPosted: Sat Mar 29, 2014 12:46 pm Reply with quote Back to top
I cleaned out the Auotzone shelf here last spring. Gotta look for that sale again this year.
Thanks for the reminder Tom.
PostPosted: Sat Mar 29, 2014 1:50 pm Reply with quote Back to top
5W is way too thin. 10W acceptable, 20W preferred. I only use 20W50 Casrtol non-synthetic motorcycle oil. This oil does not kill kittens!
PostPosted: Sat Mar 29, 2014 1:56 pm Reply with quote Back to top
cbxdog
PostPosted: Sat Mar 29, 2014 2:25 pm Reply with quote Back to top
+1,, good quality oil at a reasonable price.
1980 CBX
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed
Psychotron
PostPosted: Sat Mar 29, 2014 2:39 pm Reply with quote Back to top
I just use what Honda recommends. 10W-40 motorcycle oil. As long as you change the oil regularly it does not matter, and I would never put synthetic oil in these old bikes since they have a wet clutch system.
82 silver and blue 750 F, the F is for Fuckers but it's silent.
rapidfire1
PostPosted: Sat Mar 29, 2014 2:57 pm Reply with quote Back to top
I used to use Amsoil in all my bikes dirt and street but once it hit $14 a quart I switched to lucas and am very pleased with its performance.
PostPosted: Sat Mar 29, 2014 8:52 pm Reply with quote Back to top
My experience is that synthetic oil does not cause clutch problems. I use synthetic oil in all my bikes (3 of them older than 30 years) and have have never had a clutch problem.
PostPosted: Sat Mar 29, 2014 9:19 pm Reply with quote Back to top
My understanding was that the JASO rating is supposed to correlate to wet clutch compatibility.
I've had problems with Mobil 1 synthetic in these bikes because of the fuel saver additives that aren't wet clutch compatible.
I think that Rotella T6 has promise as a superior choice of oil. And it's fairly cheap as far as synthetics go
The 5w rating is just the cold flow rating, and lower is always better for cold start wear with the same 40w hot rating that Honda recommended in the day.
And a wet clutch compatible synthetic should be a better oil in many respects to the traditional plain MC specific oils we have been using.
The only weakness I see with the Rotella is that since it is designed for diesels, it may not have enough Zinc in it for wear, as most new diesels (since 2006) have catalytic converters, and zinc shortens cat life..so they keep the levels low.
PostPosted: Sun Mar 30, 2014 12:36 am Reply with quote Back to top
Been using this for 2 years in 2 bikes, a combined total of 30k miles with zero problems.
PostPosted: Sun Mar 30, 2014 12:55 am Reply with quote Back to top
Might be worth a shot at 21 bux a gallon.
Wulph
PostPosted: Sun Mar 30, 2014 1:12 am Reply with quote Back to top
I tried Amsoil in the 1100 and the starter clutch caused a bunch of problems - wouldn't catch so it was a real bitch to start. Finally after pulling the starter clutch a couple of times with short term results I dropped the Amsoil, went back to the old stuff and haven't had a problem since. There, no kittens sacrificed. That being said I still use Amsoil in the Wing with absolutely no problems.
PostPosted: Sun Mar 30, 2014 3:47 am Reply with quote Back to top
I prefer some form of scented massage oil. If it works for me, it will work for the bikes.
psychodad
PostPosted: Sun Mar 30, 2014 1:27 pm Reply with quote Back to top
+1 on Mobil 1 and clutch problems, maybe a coincidence on a thirty year old clutch, but why take a chance.
PostPosted: Sun Mar 30, 2014 4:51 pm Reply with quote Back to top
Mobil 1 is shit. If you haven't figured that out yet good for you. You just failed the advertiser
test. You make shit and put it in pretty bottle.
The goal is ZINK and Mobil 1 has none.
PostPosted: Sun Mar 30, 2014 8:11 pm Reply with quote Back to top
Mobile 1 15/50 has 1300 ppm of Zinc.
The V Twin oil has 1850 and 1750 of Phosphorus.
http://www.mobiloil.com/USA-English/MotorOil/Files/Mobil_1_Product_Guide.pdf
If you're looking at oil, the easiest way to avoid oils without zinc is to look for the "energy conserving" symbol. Its a trick. The symbol indicates the lack of zinc that clogs up catalytic converters.
Anything that is listed against use in engines with catalytic converters is usually pretty good stuff, sadly enough. Hell, its the whole reason we've got roller cams in modern cars now days. The oil cant protect a flat tappet cam, which is exactly what we've got in the DOCH engines, which is another reason to seek out a decent oil. Used to be Rotella had a huge zinc content, but since they started mandating converters in diesels now, they've cut that back too.
Personally I still run 15-40 Rotella conventional oil in everything I own. Truck, car, bikes, power washer etc.
PostPosted: Mon Mar 31, 2014 11:53 am Reply with quote Back to top
Now that the info regarding Zinc levels is universally recognized, and zinc additives are available all over.....
What is the down side of using Rotella T6 to get the superior characteristics of the synthetic, with a small amount of additive, to up the zinc levels?
Summit Racing sells a bunch of different zinc additives that could get you there. So hot rod guys appear to be using it in just this way.
The Rotella T6 is very reasonably priced and I use it for my diesel truck oil changes (10qts), I would love to use it in the bikes as well.
Synthetic MC specific oil is twice the price of the Rotella T6..
It seems that synthetics have much better wear and temperature characteristics than regular oil. If the zinc levels are there, it appears certain that they would be much better for an motor like the DOHC Honda that hits oil temps of 260 degrees.
Thoughts?
PostPosted: Mon Mar 31, 2014 12:01 pm Reply with quote Back to top
I like the idea of a zinc additive. Never thought of that.
PostPosted: Mon Mar 31, 2014 12:13 pm Reply with quote Back to top
I worked for a Toyota fork lift dealer and we used mobil delvac 15w-40 in everything because of the elevated zinc and phos levels.
PostPosted: Mon Mar 31, 2014 1:03 pm Reply with quote Back to top
For those who like to use the motorcycle specific Castrol or Valvoline 20/50 or 10/40 from Autozone, it is on sale right now for $2.00 off per quart. Only $3.99 instead of $5.99. Ends April 7.
I will be stopping there today!!
http://www.autozone.com/autozone/deals/dealMaker/dealMaker.jsp?catId=102088&dealId=51041&systemCode=10&showDealMaker=true
Steve
PostPosted: Mon Mar 31, 2014 1:16 pm Reply with quote Back to top
Steve
Thanks for the heads up on the oil at Autozone, I remember a few years ago when the regular price was 3.99, then there was $2 off!
I may make a run for the border this weekend, too bad the CDN/US exchange rate sucks right now.
CHeers!
Page Generation: 0.10 Seconds
