  • Total: 122,969,748
  • Today: 102,777
  • 07:18 pm PST
Flapjack
PostPosted: Tue Nov 16, 2004 12:14 pm Reply with quote Back to top
I am about to start the valve shim job on my bike
My Clymers guide says to check the valve shims at room temperature and then says (95 degrees F).
What the hell kind of room is that?
Anyway my garage is unheated and hovers around 40 degrees.
Does the measurement of the shim thickness depend greatly on temperature? Are the temperature correcting tables for super cold readings of the shim thickness?
Second- Whats the absolute best way to align the rear tire. Sight down the chain? The reason I ask this is that when I examine the hash marks on the chain tensioner stops I see a bit of a varience. 1/2 a hash I went for a cold weather ride last night to see how she ran. I guess I am paranoid but since I replaced the chain I think that ever imperfection in the road is actually my tire being misaligned. Did I say I was paranoid?
Sorry, just being a rookie again.
PostPosted: Tue Nov 16, 2004 1:21 pm Reply with quote Back to top
Good news, you won't need a cooler for the Corona!
I would keep gaps around .005" and all should be fine..
fasterspider
PostPosted: Tue Nov 16, 2004 1:45 pm Reply with quote Back to top
What stout said about the valves.
On the rear tire alignment, the "hash marks" should be set evenly.
You can count the threads on the inside portion of the adjuster to get an accurate alignment. The length of the adjuster bolt cannot be counted on to be of equal lengths unless you put them on and are sure of the length. So count threads or use a ruler, but even out the axle.
toobalicious
PostPosted: Tue Nov 16, 2004 2:42 pm Reply with quote Back to top
roger that... she will almost inevitably pull one way or the other (at speed, with your hands off of the bars) if the alignment is off even a little...
a
Nanuq
PostPosted: Tue Nov 16, 2004 4:21 pm Reply with quote Back to top
Flapjack, regarding the temperature reading... what it's telling you is make sure your bike is *completely* cooled down before you do the shims. If it's still warm from a ride, everything in the engine room is expanded just a little bit from the heat ... and you'll get too-close readings for the gaps. Let it cool overnight and then do it. Simple rule of thumb.
Or move to Alaska and leave it sitting outside for 3 minutes before you start. Wink
Matt at PSB
PostPosted: Tue Nov 16, 2004 4:33 pm Reply with quote Back to top
What the Clymer Manual is saying is the MAXIMUM temperature should not exceed 95 degrees F. Smile
Do yourself a favor. Get one of those round catalytic propane heater that attach to the top of the 20-LBS. propane (barbeque) cylinders. Set this up 10 feet away so that it radiates onto your backside while you work. Make sure there is an air source for you & the heater. You will get a better impression of a valve adjustment job if you do this. Idea
The heaters are not expensive & you can rent a full 20-LBS. cylinder from your local gas station. Suffering is not required to be one with your bike. Exclamation
Matt at PSB
Nanuq
PostPosted: Tue Nov 16, 2004 4:59 pm Reply with quote Back to top
(using the feeler gauge)
L-l-l-let-t-tssss s-s-s-s-seeee... (shiver) Its, uh, 3 th-th-thou. N-no, m-m-m-make th-that 5 thou. (shiver) Wait... 3 thou. Dang, n-n-n-now it's 7 thou...
noiseguy
PostPosted: Tue Nov 16, 2004 5:01 pm Reply with quote Back to top
Regarding alignment and the hash marks...
I tried using the hash marks to align the rear wheel. I rechecked this by shooting a laser level up to the front. It was 1/2 degree off, which reads out as about a 1" variation from side to side at the front tire. Now my rear wheel is aligned per the laser, and I'm off by 1/2 hash mark at the rear wheel. Go figure. I trust the laser more than the hash marks.
Not sure if 1/2 degree is worth much, but it only took a few minutes and a $15 laser level to do right.
PostPosted: Tue Nov 16, 2004 6:12 pm Reply with quote Back to top
Same story here.
Bought a "laser level" from Harbor Freight. Looks like a regular bubble level with a laser in the end and cost $10 on sale. Lay it on its side with the edge against the tire. The level will shoot a line on the floor. Makes it really easy to get it true,even better than my old way of "sighting" the tire. The marks on my 1100F are about 1/2 line off.
Same true on the shims. Do the job "cold" but the temperature is unimportant. If you can work there it will be fine. The adjustment is not that critical as long as there is sufficient clearance. My guess of the specification going down to .002" is purely for noise(EPA regs). The correct clearance will be about .005",in other words the .004" should go through easy.
Flapjack
PostPosted: Tue Nov 16, 2004 7:40 pm Reply with quote Back to top
Thanks guys
You are all great. Very Happy
79cb750f
PostPosted: Tue Nov 16, 2004 9:17 pm Reply with quote Back to top
I don't think you'll have a problem, but pm me for my cell phone number if you need it.
Larry
PostPosted: Wed Nov 17, 2004 1:46 am Reply with quote Back to top
The Harbor Freight Laser level for 10 bucks was a sweet deal. I have set up 5 bikes with it. The only "problem" is that now everyone seems to think I am very thorouh when working on their bikes. Kind of reminds me of the dazzle with BS, but it actually works very well.
Flapjack
PostPosted: Thu Nov 18, 2004 12:10 pm Reply with quote Back to top
Well thank you all.
I did all the tricks that were listed for rear tire alignment.
The neatest trick is the laser level. I already had one in the cellar. So there was one tool I didn't need to buy. (BTW laser levels are really cool)
The laser level confirmed my suspision about being out of wack. The rear tire was pointing to the right. Before I corrected the error, I noticed the bike liked to hop, dip, dive , pull to the right at the least provocation. Does the evidence from the level support my impression of the handling? (Tire pointing right exhibits right hand dive) The reason I ask is I believe I noticed this on my first test ride after the new chain. So I am looking for confirmation the I am reading the signals right.
The hash marks on the tension adjusters are almost the same. maybe 1/4 off, or less.
I went for a ride last night after I aligned the tire. No dive. I can't get over how much more immediate the acceleration is on the throttle twist now that I have changed out the chain and sprockets; and more importantly correctly tensioned the chain. It really seems to have made a difference. Its also very quiet. Now it just makes a sweet rolling noise. Its is a pretty unique noise...chain on sprocket.
The guy at the Honda Shop said not to worry about greasing the new chain since it came pregreased (White Lithium???). Is this correct. Any one got a preferred chain oil to recommend?
A HD buddy of mine said what are you screwing around with a chain for? Convert it to a belt. Rolling Eyes
Whats the point of a belt anyway? Sound reduction on a Harley??
toobalicious
PostPosted: Thu Nov 18, 2004 12:20 pm Reply with quote Back to top
director Laughing
you know, practically *all* of those noisy-assed hogs came with quite reasonable exhaust systems when they were new...
a
Jax750F
roflmao roflmao roflmao
beerchug
sfhess
PostPosted: Thu Nov 18, 2004 4:50 pm Reply with quote Back to top
Don't shim the valves down to .002. Keep them around .005 or so or you will burn valves. Engine out to fix. I went through this about 15 years ago........
Blainethemono
PostPosted: Thu Nov 18, 2004 9:27 pm Reply with quote Back to top
"Now my rear wheel is aligned per the laser, and I'm off by 1/2 hash mark at the rear wheel. Go figure. I trust the laser more than the hash marks. "
and if your swingarm bushings or the frame isnt shot, this will work just fine.... Twisted Evil Shocked
Page Generation: 0.10 Seconds
