  • Total: 123,352,818
  • Today: 103,614
  • Nov 24, 2026
  • 07:58 am PST
Wulph
PostPosted: Tue Jan 15, 2013 7:39 pm Reply with quote Back to top
After seeing the pictures of Nick's swingarm on his 1100R resto, I feel the need to do the same. Question is, if I leave the needle bearings and lower shock bushings in place will they get fackacked? They're all in great shape so I'd rather not remove them if it's not necessary. Thanks.
Gabe
swiftnick
PostPosted: Tue Jan 15, 2013 7:47 pm Reply with quote Back to top
I have heard of leaving the bearings in just make sure you flush every spot of grease. The shock mount rubbers wont survive the oven though. I just replaced both, it's simpler.
1975 CB400 four
2012 ST1300
1982 CX500 Turbo
1976 CB750 Super Sport
1987 VFR700F
1985 VF1000R
1984 GPZ900R
1978 BMW R100RS
1991 FJ1200
PostPosted: Tue Jan 15, 2013 8:19 pm Reply with quote Back to top
I have had 2 swinging arms powdercoated with the bearings left in, i use a long length of 10mm threaded bar with a large OD washer on each end with a thin smear of silicon sealer between the washer and the end of the swinging arm, and remove the rubber shock mount bushes
PostPosted: Tue Jan 15, 2013 11:22 pm Reply with quote Back to top
That's is what i did but i made aluminium plugs in the ends to work with the threaded rod. Also check the grease fitting if there is one. I would try to put a pipe plug or something in there while out for coating, high heat can make them weep grease while in the coaters oven which screws the coating. Ask me how i know!
PostPosted: Wed Jan 16, 2013 2:45 am Reply with quote Back to top
I have personally powdercoated numerous 750F, 900F, and 1100F swingarms with the bearings AND busings left in place. The bushings hold up just fine and as long as the bearings and tube are thoroughly degreased, your powder coater won't throw a fit.
I'd be happy to do yours for you, but I think the shipping would be a killer from Canada to MA.
sbparks
PostPosted: Wed Jan 16, 2013 1:03 pm Reply with quote Back to top
Guys,
I was able to leave both the bearings and the rear shock rubber bushings in place when TomK powder coated my 1100F swingarm. I've also had him do a few other bits and pieces that have rubber moulded to the base metal part... my seat hold down brackets and just recently a set of rear foot pegs from an 1100F sportkit rearset. These are the footpegs that have the rubber wear surface moulded in as a part of the footpeg.
Tom usually warns me that the rubber could get soft and he'll test it to be sure, but so far, none of my rubber bits have been harmed.
Just my experience.
Scott
Wulph
PostPosted: Wed Jan 16, 2013 4:43 pm Reply with quote Back to top
Hey guys, thanks for the replys. It looks like I'll leave the bushings and bearing in place pending the feedback of the coater. Any wisdom on removing the thrust bushings at the bearings? They're NLA so if I have to remove them I really don't want to mess them up. Do the shock bushing just press out?
Gabe
swiftnick
PostPosted: Wed Jan 16, 2013 5:47 pm Reply with quote Back to top
Gabe
The thrust bearings are pushed out by the inner needle rollers as you knock them out. I am not sure you will be able to get them out any other way without possible damage. And as they are NLA you really do not want to risk hurting them.
IMHO if you are going the trouble and cost of taking out the swing arm to PC it, why not go one step further and put in new bearings? And then if you are really keen, fit the center shaft to the correct width and tighten the handling right up.
1975 CB400 four
2012 ST1300
1982 CX500 Turbo
1987 VFR700F
1985 VF1000R
1984 GPZ900R
1978 BMW R100RS
1991 FJ1200
