  • Total: 112,450,815
  • Today: 38,003
  • Jul 26, 2026
  • 08:29 pm PDT
kodo
PostPosted: Tue Jan 01, 2013 4:12 pm Reply with quote Back to top
Can i have a little input please regarding my exhaust i have put together for my 900f winter project.
photo 1 side angle
Front View
rear view
I have 2 motad systems ,one which is ready for the bin ,so i chopped it at the junction box ,then fiddled about with 2 collector pipes from my Two Brothers oval can i removed from a previous bike .
At the moment i have used the rear grab handle to hold the can in position ,which i may keep as it holds the can at the correct angle to allow enough clearance from the shock and the swinging arm .
I know i will have to cut the rear peg mounts off the allow the pipe to be fitted (not the end of the world )as i have a modern bike to take passangers.
Once im happy with it i will weld the collector pipes together then split the good motad junction box and weld them together to make a full system.
if this doesn't go to plan ,all is not lost as i have 2 marshall systems which i can decide on what one to use .
PostPosted: Wed Jan 02, 2013 1:31 am Reply with quote Back to top
kodo, since you asked for input...to my eye it i a bit too upswept.
I think the muffler would look good matching the same upward sweep of the tailpiece.
orion
PostPosted: Wed Jan 02, 2013 3:08 am Reply with quote Back to top
looks good to me ! needs a wider rear rim and tire.
love the seat and Honda skull and cross wrenches !
rapidfire1
PostPosted: Wed Jan 02, 2013 3:37 am Reply with quote Back to top
I think it looks good
bobcat7
PostPosted: Wed Jan 02, 2013 7:25 am Reply with quote Back to top
looks alright to me, except the grab rail !
kodo
PostPosted: Wed Jan 02, 2013 4:35 pm Reply with quote Back to top
Take 2
Thank you for you opinion guys.
I fiddled about with the exhaust again today .and mounted it to the original baffle mount
still not 100%
rear view
