  • Total: 112,603,272
  • Today: 19,363
  • Jul 30, 2026
  • 12:54 pm PDT
mxsaunders
PostPosted: Sun Jan 04, 2009 6:37 am Reply with quote Back to top
Does anyone know a source for the rubber wire cover that goes over the oil presure sensor? Fiche only shows it as part of the wiring harness for the ignition pickups.
bamaf
PostPosted: Sun Jan 04, 2009 11:18 am Reply with quote Back to top
I used one from a Kaw mule with the 620 twin engine.Exact match in every way.
mxsaunders
PostPosted: Sun Jan 04, 2009 8:57 pm Reply with quote Back to top
Many thanks! You don't happen to have a part number or model number do you?
I've looked through the fiche for the 4000 series and can't find a pressure sensor on it.
I'm also curios how you came across this little gem of info. Luck?
bamaf
PostPosted: Sun Jan 04, 2009 10:00 pm Reply with quote Back to top
I have rebuilt several of the 620 series liquid cooled engines as used on the Mules,Gators and I am sure other applications.I also was looking for a correct /any cover and compared the two.Exact match Laughing Check anything that uses that engine and it should be the same.Mine was ordered for a 08 Mule and if I can find the # I will post it
