  • Total: 122,916,952
  • Today: 49,981
  • 09:22 am PST
PostPosted: Sun Jul 20, 2008 4:22 pm Reply with quote Back to top
I will be ready to start on a 750F project bike (thanks Wamkap) and would like advice on cleaning polishing a ratty silver motor. First let me say that spending a month at my buffer wheel with each piece is not an option. What about scrubbing the motor (out of the frame) with CLR / muratic acid? How about taping up all the openings and having it professionally bead or plastic media blasted then clear coating? What have others tried or done and what worked best? Thanks, DrOlds
PostPosted: Sun Jul 20, 2008 9:18 pm Reply with quote Back to top
Doc,
A couple of comments regarding motor clean up and re-finishing.
The polished alum. covers on all the F bikes I've ever seen or owned were covered with a clear coat from the factory. Over time this clear coat wears and allows the weather to creep in underneath it and do damage to the alum. I've removed the covers, used paint striper to remove the weathered clear coat and then used a bit of polish and elbow grease to buff the covers back to a nice presentable shine. Depending on the amount of damage of course will set the pace for how much rub and buff you'll need to regain a nice finish to the covers. With a bit of a start on the rubb and buffing you may be able to re-install the covers and then do a couple of lighter buffing sessions as you ride the bike and do your normal wash and polish routine.
If your not willing to go that route you may not be to bad off to simply score a second set of covers of better condition and install them. You might also contract out the polishing to a chrome shop that does this type of work on a normal basis. I've got no idea about the cost here. If you had two sets of covers one could be in the shop while the other pulls duty on the bike. The old set might also be used as part of the paint masking set that you cover over spray without fear while the motor interior parts are protected.
The other option is to paint the covers as many have done, more so those that have the motors finished in the factory semi-gloss black finish. I have seen one motor done in a over-all silver paint scheme that came up very nice and mimic's the factory fresh finish of the silver motor bikes. This may or may not fit with your color scheme of your bike or your intended plans...black covers that is, but painting is an option.
The silver color of your motor is in fact a factory paint. This gives an overall common color tone to the motor in total (other then the polished covers). You may find that you can simply wash/de-grease/mask and re-spray in a silver tone of your choice that comes closest to matching the factory paint color. Engine enamel or high temp engine paint would be the paint type of choice I should think. I myself would be less likely to want to blast and paint the motor simply because in my experiance with blasting mediums it is extremely difficult to keep the media out of all the possible places that you do not want it to go. If your using an agressive media you may also do more damage then you'd like to. I think some have used baking soda as a blasting media and it is less agressive then glass beads, sand or alumina oxide media's. That said I have used blasting media to do parts clean up in prep for re-finishing...but only on component parts that I could deep clean after the blasting session,...never on a complete assembly that I expect to put back into service with out a internal/extrenal cleaning first. (Caution: War Story in coming) I glass bead blasted a Harley oil tank on my Lowrider restroration project back in 1991. I was so affraid that I could not get the inside of the tank cleaned of media that I bought another tank rather then risk the motors destruction to a contaminated oil system. Trust me..the media gets into everything!
You may be surprised at what a general scrub and re-paint will do for the looks of the motor. Removing it from the frame and going at it will not be the easy way...but it will give you the best access to the motor area's and it will also protect the frame from overspray and reduce your masking requirements.
HTH.
Tony
PostPosted: Mon Jul 21, 2008 4:17 pm Reply with quote Back to top
DrOlds,
Three weeks before the NE spring ride I decided drop the motor and restore my 750F. Figured I might as well since I had a snapped cam holder bolt. But that's another thread...
Here is what I did. I made a "creeper" with wheels so that I could drop the motor and work on it.
I pulled side covers and painted them separately. When installing use new gaskets.
Clutch cover, valve cover and end caps were replaced with covers in better condition.
Motor in frame:
Ready to go!
AND then of course, it rained the next day on the ride. I used a ceramic based engine enamel paint by Duplicolor. They have silver, aluminum and cast aluminum. I choose cast aluminum as I like the look better, as opposed to silver. I did use the aluminum color for other parts. Paint was readily available at Pep Boys.
PostPosted: Wed Jul 23, 2008 12:42 am Reply with quote Back to top
Thank you for the 2 informative posts, I guess I didn't realize the main motor cases were painted, that is an easy fix. I suspected the covers were polished then clear coated (like the alum automotive wheels, I never considered stripper but that may be an option. Taking the engine out is no big deal and I may be able to find a set of better covers on e-bone (oops I mean e-bay) and blue thanks for the tip on the paint. Isn't it funny that this is the beginning of the project bike you had second dibs on from Wamkap!!! By the way to bad about the jet coming loose good thing it was only that, C Ya in Oneonta? DrOlds
Marcus Aurelius
stewross
PostPosted: Fri Jul 25, 2008 8:21 am Reply with quote Back to top
Here's the stock silver motor on my 900 for your reference...they look great I feel...
Out of interest, does anyone know the history behind why the US market ran with the pegs a few inches further forward...
SR Very Happy
PostPosted: Fri Jul 25, 2008 10:35 am Reply with quote Back to top
So, with the high handlebars, the US riders could lean back onto the Hondaline backrests and avoid staying within the triangle of stability. Just a thought.
wharfie
PostPosted: Fri Jul 25, 2008 11:38 am Reply with quote Back to top
I'd definitely stay away from muriatic with any of the aluminum parts. It can react badly with the aluminum leaving pits with oxidation that will be impossible to remove short of grinding. I'm not sure of the contents of CLR.
Irimajiri
PostPosted: Fri Jul 25, 2008 11:53 am Reply with quote Back to top
Crankcasing, valve cover and barrells is a painting finish that is application of Honda code NH192M with description "Gently Silver". Previous to this message another posting of US located member has compare with T178 Silver of Duplicolor brand and comparison is very close. I don't see this T178 but NH192M is from Honda delivery for small repair applications.
stewross
PostPosted: Fri Jul 25, 2008 12:06 pm Reply with quote Back to top
The silver colour seems to be a light silver...a fairly bright colour.
SR
