Sat Feb 18, 2023 2:09 am |
In the interest of sharing and/or showing off, show us a tool that you have made for working on F bikes.
I have made several, but here is my latest. It's a bearing puller for the clutch housing bearings.
Heres' the setup for the outer bearing.
Voila!
And the difficult inner bearing.
Your turn  |
_________________ Cary
rl750
Sun Feb 19, 2023 11:08 pm |
A deep 10mm socket welded into an old box end wrench is perfect for putting a screwdriver through to
hold the clutch adjuster screw on a 900 or 750 while tightening the locknut. Honda most likely makes such
a tool but this one was free. |
_________________ Russ
\'82 cb 900f
\"06 cb 900f 919
\'78 cb750k-Asian Orange
\'76 KZ 750B Twin |
Mon Feb 20, 2023 12:25 am |
Nice one! |
_________________ Cary |
Mon Feb 20, 2023 2:20 am |
I made this shock spring compressor out of some bar stock and a 2 ton hydraulic jack.
It has removable inserts so it can be adapted to most any motorcycle shock.
