  • Total: 58,384,419
  • Today: 23,652
  • May 16, 2022
  • 05:56 pm PDT
JSGrimm
PostPosted: Sat May 07, 2022 1:56 pm Reply with quote Back to top
Hey all! Getting ready to strip some clear coat off some parts, and wondering what everyone's preferred stripper is currently? I used to use the Klean-strip aircraft remover but I've heard they changed the formula to remove all the nasty stuff (you know, the stuff that works) and the reviews on it are pretty bad now. What's good?
And parallel question, what do you use to remove paint from plastic parts (i.e. side panels and cowls)? I think there was an aircraft remover aerosol that used to be good for plastics but I can't find it anymore.
Thanks!
JS
PostPosted: Sat May 07, 2022 3:18 pm Reply with quote Back to top
Glass bead blast..especially for plastic. Aircraft stripper doesnt remove primer very good. A rubber wheel for decals can work
PostPosted: Sat May 07, 2022 4:48 pm Reply with quote Back to top
Methyl chloride has been removed from all consumer-available strippers and what's out there now is very slow acting. Fortunately, I can get the real deal through my business for stripping old powder coatings, but I wouldn't use it on plastic. You can probably use the stuff available at the big box stores or your local hardware store. I would test a little on the backside of anything plastic, just to make sure it doesn't eat into it. The stuff is so weak now that I doubt it will attack it.
www.tomscyclerecycling.com
CB1100F's - multiple flavors
PostPosted: Sat May 07, 2022 6:42 pm Reply with quote Back to top
+1 on glass bead. Here's a tail cowl completely stripped of paint. It will not damage the plastic and leaves a suede like finish that is perfect for paint adhesion.
Cary
PostPosted: Sat May 07, 2022 7:09 pm Reply with quote Back to top
I always had my plastic blasted with aluminum oxide but at lower pressure and feathered in with the gun. It is rougher than a cob when done but can be sanded and painted to perfection. I stole the glass bead from Headless and that is much much better. I tried different strippers on the side covers and they melted in seconds.That was years ago..maybe different now?
JSGrimm
PostPosted: Sat May 07, 2022 10:39 pm Reply with quote Back to top
I agree that glass blasting is the best option, I used to work somewhere that had a sand blasting box and glass bead that we used to finish some raw aluminum parts, and I was able to use it whenever I wanted. Unfortunately that's a long time ago and I don't have access to it anymore.
I did use some variation of aircraft stripper on plastic side panels for a CB400T in the past and it actually worked well, just had to be careful how long I left it on. It left the surface a bit tacky but was easily sanded smooth.
I found a can of the non-MEK aircraft stripper today... I'll give it a shot and report back.
JS
dannewman
PostPosted: Tue May 10, 2022 10:06 pm Reply with quote Back to top
Baking soda blasters are quite something. But, expensive. Ice blasting is fairly new, but don't know how it works on plastic parts. I've used it on boats and it removes zero metal.
900F 82'
Lindy
PostPosted: Tue May 10, 2022 11:48 pm Reply with quote Back to top
Dry Ice blasting has been around awhile, is/was used in the aircraft industry. I never thought of blasting plastics, wonder how vapor blasting works on them
PostPosted: Wed May 11, 2022 5:53 am Reply with quote Back to top
We never had dry ice blasting at work but we did have a plastic bead blaster specifically for removing paint from composite and plastic aircraft parts. I imagine such machines would be thin on the ground outside of aircraft maintenance facilities.
Page Generation: 0.28 Seconds
