Sun Mar 08, 2020 2:36 am |
Does anyone know anything about large capacity oil pumps? I found this pump in my stash of parts and the oil cooler stage is quite a bit larger than the standard pump. I thought it might be from an 1100R but according the parts fische it uses the same pump and the F bikes.
The larger pump is one the right.
_________________ Cary |
Sun Mar 08, 2020 3:00 am |
Maybe a CBX? Don't know what those pumps look like but was thinking with the extra cylinders they might change the oiling as well. |
Sun Mar 08, 2020 4:01 am |
Nope, the CBX uses a chain driven pump. |
hogwild113
Sun Mar 08, 2020 5:28 am |
Could you have been working on this type of oil pump? I want to run this setup on my next project.. |
_________________ B/W CB1100F Resto-mod
R/W CB1100F Original 13K miles |
Sun Mar 08, 2020 7:38 am |
It's a wet sump pump. I'll post a picture of it assembled tomorrow. |
Sun Mar 08, 2020 11:01 am |
See, I told you I never saw a CBX pump before  |
TCRacing
Sat Mar 14, 2020 3:00 am |
Sat Mar 14, 2020 5:57 pm |
no, I still haven't figured out which bike it's from. |
Sat Mar 14, 2020 9:48 pm |
| headless wrote: |
I have come across a couple of them, quite rare and not sure which F they were from, but not a CB1100R as they use the 15100 438 003 part
As far as i can work out there are only 2 pumps, the 15100 438 000 was used on the first CB900F models up to engine number 2105104, the pump with part number 15100 438 003 was the second revision and used on all CB900F models from engine number 2105105, the CB1100F and the CB1100R models
Keith |
_________________ 1982 CB1100RC
1983 CB1100F |
Sat Mar 14, 2020 10:24 pm |
TCRacing
