  • Total: 79,350,579
  • Today: 14,668
  • Oct 05, 2024
  • 08:34 pm PDT
PostPosted: Fri Nov 09, 2018 5:45 pm Reply with quote Back to top
So there is a 20mm thread size petcock and also another side correct? What is that size?
PostPosted: Fri Nov 09, 2018 6:28 pm Reply with quote Back to top
There is also a 18 and 16mm Nathan
Here is a link to Genes petcock guide
http://www.cb750c.com/Genesound/Petcocks_79-83_DOHC.html
1978 Honda CBX1000
PostPosted: Fri Nov 09, 2018 9:38 pm Reply with quote Back to top
That's a great help to sort out what part numbers came on which bikes. I'm looking for thread sizes for all the different petcocks to see which one may be easily available. I need to make an aluminum weld in bung for the petcock. I'm hoping to either make or find one that's already made but I need to know the specifics of the threads.
PostPosted: Sat Nov 10, 2018 11:33 am Reply with quote Back to top
Nathan
When I got my replica 1100R alloy tank it had a 16mm bung with a Tap with a 6mm outlet on
It was also slighty out of position so i had a new M20 X 1mm pitch bung made and used a late CB900/1100F tap which you can get a repair kit for from a forum member
I made a couple of flats on the bung to reduce the size before welding
[img]Image[/img]
[img]Image[/img]
1978 Honda CBX1000
PostPosted: Sat Nov 10, 2018 12:14 pm Reply with quote Back to top
Nice! Thanks Keith!
