hondacliff
Mon Nov 25, 2024 10:57 pm |
I think I have done a good search without finding a good fork bushing kit,including O-rings. for a CB1100F.
Anyone here know of a good kit available please and thanks,
Cliff. |
Tue Nov 26, 2024 12:10 am |
Good to have new bushings on hand when you have the forks apart, but if the oils been changed regularly, you may find you don't need them. Last time I checked, admittedly some time ago, they were still available from Honda.
Edit: Partzilla shows them as still available.
Outer Fork Bushing
Inner Fork Bushing |
hondacliff
Tue Nov 26, 2024 6:05 pm |
Thanks, I have ordered the bushings at the local Honda dealer. The O-rings for the air suspension are back ordered to February next year. I was hoping to get a kit with everything including the O-rings. I emailed All Balls but no luck there. The manual says to replace them every time the forks are removed but I'll try the old ones when I reassemble everything.
On a side note, the fork that was leaking fluid, the fluid was like new. The other one that was not leaking, the fluid was jet black. |
Tue Nov 26, 2024 8:39 pm |
I've never had to replace the O rings. In any case, you can measure them and find replacement from any industrial supply. |
Wed Nov 27, 2024 1:27 pm |
Bucko wrote: |
Same here - I've rebuilt quite a few sets and never had to replace those. |
hondacliff
Wed Nov 27, 2024 4:45 pm |
Thanks guys! I won't worry about the o-rings then. Cliff. |
