  • Total: 112,192,216
  • Today: 28,327
  • Jul 21, 2026
  • 12:56 pm PDT
PostPosted: Sun Jan 30, 2022 4:43 pm Reply with quote Back to top
When starting the 1100 after it sits for a few days, I always crank it with the kill switch off until the light goes out. May not be necessary, but it gives me some piece of mind that oil is everywhere and I won't starve any internals. It can take about 5-7 seconds of cranking before the light goes out. How long should it take for it to go out?
2006 H-D Fatboy
PostPosted: Sun Jan 30, 2022 5:23 pm Reply with quote Back to top
Sounds about right. Does your 1100 start up quickly after sitting for days or weeks.? Usually I’ll need to start my 900 over and over for at least 20 seconds before it will even fire.
PostPosted: Sun Jan 30, 2022 5:36 pm Reply with quote Back to top
It takes a while if it's been a week or longer. I always do the kill switch deal if it's been a few days. If it's one day I don't bother and it starts right up. I have the stock fuel diaphragm in there and the gas can only get to the bowls while cranking.
2006 H-D Fatboy
PostPosted: Sun Jan 30, 2022 7:13 pm Reply with quote Back to top
Aren’t there pockets of oil in the cylinder head around the cams that sit there and don’t drain after shutoff?
So as you turn over, isn’t some oil splashing around the top end that was already up there? Unless it’s cold, of course. Then I doubt cranking moves much cold 15-40 or 20-50 anyway.
My 1100 always started immediately after sitting and my 750 always needed time as it runs on what sounds like 1 then 2 then
3 and 4 start firing.
I save wear and tear on started clutches by preemptively removing the air cleaner cover and pulling out the filter and squirting some ether into the air box..starts right up …then runs on 1 then 2 then 3 and 4 cylinders
Point is, like Hondo says…never starts instantly after two weeks anyway……..
If cold start lubrication is a concern, I think running thin oil 10-30 is the most important factor.
PostPosted: Sun Jan 30, 2022 7:51 pm Reply with quote Back to top
I am more concerned with the main bearings not getting pressure at initial startup when cold. By cranking it over "killed" the oil gets up to pressure with no bearing load.
2006 H-D Fatboy
PostPosted: Sun Jan 30, 2022 8:26 pm Reply with quote Back to top
Don’t you also have to consider the stock oil filter housing?
Doesn’t that housing trap an air pocket that compromises oil to the bearings as well?
Wasn’t there a specific mod to the housing to purge that air pocket?
Isn’t that air pocket a problem for oil supply to the bearings as well? Frothy bubbles in oil supply?
Not sure cranking fixes that…..
I’m just throwing some additional thoughts toward your premise….oil supply to bearings on cold startups.
PostPosted: Sun Jan 30, 2022 10:07 pm Reply with quote Back to top
If there is an air pocket I don't see how it would affect anything. Air would be forced out by incoming oil.
2006 H-D Fatboy
PostPosted: Mon Jan 31, 2022 1:56 pm Reply with quote Back to top
The upper third of the oil filter housing is always an air pocket but it doesn't effect the oil pressure at startup.
There are a couple of ways to eliminate this air if you want to prevent oil foaming (which isn't good).
My favorite way is to drill and tap a 5mm hole at the top of that cavity and insert a carb jet, no larger than 1mm (100 on the jet).
As oil is pressurized into that cavity, it will push the air out and after it's all gone, will squirt oil into the case, at the primary and A cam chain.
This method works for any Honda with the canister style filter, with or without the stock filter or spin-on. Without any welding or external plumbing.
PostPosted: Mon Jan 31, 2022 4:00 pm Reply with quote Back to top
I'm going to go with... you'd have to literally wipe dry the skirts, which are not, remove the cam/crank/rod caps and clean those of the oil film, which btw, just draining down the battery is about the only good thing is save the battery to last a little longer, but to waste that kind of starter motor parts spinning the carbon off those touch points, one way roller springs adding more collapse so as not to hold, hours of cranking, are seconds added not starting the bike right off. Want me to go on?
We on the same page yet?
Signed,
NOLTT (no one listens to turtle)
PostPosted: Mon Jan 31, 2022 5:00 pm Reply with quote Back to top
Thanks cntrhub for that info. I may try to nstall that jet at the next oil change if I can figure out a way to keep the metal bits on the drill bit. Maybe a vacuum running alongside or heavy grease on the bit?
2006 H-D Fatboy
PostPosted: Mon Jan 31, 2022 5:46 pm Reply with quote Back to top
This all seems to be unnecessary worrying. If there was a real problem, Honda would have issued a service bulletin
or recall.
PostPosted: Mon Jan 31, 2022 5:58 pm Reply with quote Back to top
[quote="CBX-tras"]The upper third of the oil filter housing is always an air pocket but it doesn't effect the oil pressure at startup.
This method works for any Honda with the canister style filter, with or without the stock filter or spin-on. Without any welding or external plumbing.[/quote]
How do you know how much, if any, air is trapped in the cannister ? is there a way to measure it ?
PostPosted: Mon Jan 31, 2022 6:22 pm Reply with quote Back to top
Interesting discussion this. I wonder has anyone ever made a transparent filter housing to see if an air bubble is actually trapped there? I would think this same ‘issue’ should apply to every motor (car, bike, truck etc) that has an oil filter mounted on its side. I would also suspect there are many other areas in a motor where an air bubble could theoretically sit, oil cooler for example. However I also think that oil is quite thick and would quickly pick up any air and carry it through the system when the motor is first run following an oil change. Thereafter the oil system is relatively well sealed assuming the motor is not clapped out an air shouldn’t reenter the galleries etc. after shut down. Unless you start drilling holes that is, in which case it would seem your inviting air back in every time you stop the motor.
PostPosted: Mon Jan 31, 2022 6:27 pm Reply with quote Back to top
I think you guys are over thinking this. Just push the button and ride!
AGDT
PostPosted: Mon Jan 31, 2022 6:39 pm Reply with quote Back to top
You will give yourself an ulcer......just ride it
1980 CB750FZ with 1123 engine
PostPosted: Mon Jan 31, 2022 6:55 pm Reply with quote Back to top
Cant ride with the weather like it is at the moment, so have to enjoy other aspects of motor cycles.
PostPosted: Tue Feb 01, 2022 1:59 pm Reply with quote Back to top
My method should be done when the cases are apart and you can see what you're doing and clean any debris/shavings.
The upper third of the filter housing will have trapped air with no way to escape under normal operation.
Modification not necessary for daily drivers.
PostPosted: Tue Feb 01, 2022 5:43 pm Reply with quote Back to top
I suggest you do not reengineer whatever oil problem you think you have. Since 1969, till this day, you need to show me a bike failed changing a dry filter into a dry cartridge, and not one bike I know has failed due to an oil change.
Like you said, why contaminate a drill hole short of splitting the cases to grab those chips, it will eventually find one tiny one going past the screen, indent the gear surface/tip with the chip going thru both blades of the pump gears, fly out of the pump and up into the crank, out into some hole and hopefully it is thin enough to remain flat, slide out the side of the bearing insert, if not upright and score a groove in the bearing insert.
Oil is going to displace that air pocket into the filter, be coated with oil are the bubbles... and like the engineers did not think this out bubble wise?
Not only that, you can't shut that hole down so dirty [unfiltered] oil is being sent thru that hole and that's constant pressure times an hour.
So here is an hour's worth of oil out that jet hole and add the pressure behind it. How much unfiltered oil is that worth vs an air pocket that leaves within seconds thru the filter pleats.
PostPosted: Tue Feb 01, 2022 6:01 pm Reply with quote Back to top
This is what cold unrideable weather does. It makes you think too much and then you start worrying
about the monster under the bed.
Prove that there's air trapped in the filter cannister and then I will start drilling holes. Maybe.
PostPosted: Tue Feb 01, 2022 6:45 pm Reply with quote Back to top
Sometimes these discussions become so esoteric that it borders on the innate. Not that I don't enjoy them, they become hyper-theoretical without resolution or purpose. Cool
PostPosted: Tue Feb 01, 2022 6:50 pm Reply with quote Back to top
Weird, I thought they were inane but maybe there is some inbreeding going on here.
PostPosted: Tue Feb 01, 2022 7:58 pm Reply with quote Back to top
If I have understood all you have written correctly, then I agree. 😁
PostPosted: Tue Feb 01, 2022 8:11 pm Reply with quote Back to top
Not gonna do it. There is no way the air won't get pushed out of there.
2006 H-D Fatboy
