  • Total: 85,548,172
  • Today: 2,958
  • Apr 27, 2025
  • 04:08 am PDT
ItalianFan
PostPosted: Fri Nov 24, 2017 2:34 pm Reply with quote Back to top
Here's the first part of the story;
https://youtu.be/dTCefFm0Biw
Lots more to come.
PostPosted: Sat Nov 25, 2017 12:33 am Reply with quote Back to top
Show us more
ItalianFan
PostPosted: Sat Dec 02, 2017 6:47 pm Reply with quote Back to top
https://www.youtube.com/playlist?list=PLJx6UQas4jz_EICbPNjJHSS79yjzm_ok6
ItalianFan
PostPosted: Mon Dec 04, 2017 1:34 pm Reply with quote Back to top
Here's the link to the video clips of the rebuild.
Carbs almost done !
G
Gareth
CB900F 1981 - conversion to Production Racer
CB1100RD 1983 - Road bike
VFR750R RC30 - Race bike
PostPosted: Mon Dec 04, 2017 2:40 pm Reply with quote Back to top
Carbs almost done !
G
Hi
Nice to see you preparing a bike for production racing in the UK next year, you will have to post the calendar of race events when you have it
Just watched you valve clearance video and would like to make a suggestion
As you found negative clearance on one you checked and set to 004'' i would suggest you try and increase to .006'' as this may close up again as carbon builds up on the valve when running tight then when the proper clearance is restored it will tend to hammer the carbon of and close the clearance
Alough the Honda manual does state the clearance to be 0.002 - 0.005'' over the years members here have found its best to run at a mininum of 0.005'' and even 006''-0.008'' especially on a race engine
1978 Honda CBX1000
PostPosted: Mon Dec 04, 2017 3:35 pm Reply with quote Back to top
Carbs almost done !
G
Hi
Well stated, Keith, and a big +1!
Rick
ItalianFan
PostPosted: Sun Dec 10, 2017 4:47 pm Reply with quote Back to top
Hi Keith,
Thanks for the guidance - always professional advice from you.
You are 100% correct that a zero valve clearance doesn't mean that a -5 on the shim size will get you back to proper running.
What I did earlier was to check the compression on each cylinder before messing with the bike and they were all 160psi+. Armed with that information I knew that there wasn't much passing the valves and so I could assume the "negative clearance" was minimal. I should have stated that in the video, but was just trying to show how to remove and replace shims.
Your comment about carbon build up is totally valid and what I'll show later is that I'll run the engine a bit (to set up the carbs) and let it get up to temperature and cool back down twice, and will then recheck the valve clearances. I'm sure there will be "bedding in" and that a few minor adjustments will be required.
And I will also make sure I have a bigger range of shims so I can get exactly the clearances I'm looking for !!
G
ItalianFan
PostPosted: Sun Dec 10, 2017 4:48 pm Reply with quote Back to top
Here's a link to the video of the carb rebuild;
https://youtu.be/qmFHa6JC_GU
I'd stripped and ultrasonically cleaned each and every component and then rebuilt the carb with a new kit. Let's hope it works with the new needle profile.
PostPosted: Sun Dec 10, 2017 5:23 pm Reply with quote Back to top
Wemoto are doing many of the Shim sizes very cheaply at the moment..£2.56 each..worth stocking up at that price
http://www.wemoto.com/bikes/honda/cb_900_f2c_sc09/82/picture/valve_shim_2.60_mm/
1978 Honda CBX1000
ItalianFan
PostPosted: Tue Dec 12, 2017 6:04 pm Reply with quote Back to top
Thanks Keith, definitely worth stocking up on shims at that price.
On with the rebuild. Here's the video of the loose carbs being assembled into a bank ;
https://youtu.be/MgryOhGOsl4
ItalianFan
PostPosted: Mon Dec 18, 2017 9:43 am Reply with quote Back to top
Here's the video of the carbs being synchronised on the bench (or on the dining room table!)
https://youtu.be/GFEmm1jSFUc
ItalianFan
PostPosted: Wed Dec 27, 2017 9:46 am Reply with quote Back to top
Here's the bench check of the carb float height :
https://youtu.be/b9c0K0f0jvM
And the rotor rebuild ;
https://youtu.be/CwswWr1_od8
More to come this week!
ItalianFan
PostPosted: Tue Jan 02, 2018 2:43 pm Reply with quote Back to top
Here we are just before Christmas :
https://youtu.be/ISRTg9Hrd8g
Still lots to do !!
Happy New Year to you all.
ItalianFan
PostPosted: Sun Jan 14, 2018 11:15 pm Reply with quote Back to top
The next instalment
https://youtu.be/HNiB22AnqEk
Gareth
ItalianFan
PostPosted: Sat Mar 17, 2018 12:22 pm Reply with quote Back to top
Here's her being started for the first time since having the carbs rebuilt.
https://youtu.be/-2ces1pMrN0
Running a bit fast (carbs aren't balanced and pilot screws well out) but at least it runs. Off to the dyno man to tweak her.
A few more details here : https://youtu.be/0KhYMeR7gJo
Gareth
ItalianFan
PostPosted: Thu Jul 29, 2021 6:58 pm Reply with quote Back to top
Well it's been a while since I posted on here but we've had a bit of an up and down couple of years. We finished 4th in the British Historic Racing club "pre-1986 Japanese Air cooled class" in 2019 despite being hopelessly under powered (84 HP compared to the 120+ of the GS Suzukis). We had new shocks (YTT) and a higher ride height due to continual grounding of the belly pan, but everything else is still bog standard.
2020 was a wash out but I did manage a track day at Mallory park in September but I got punted off at the super fast Gerrards corner and it wrecked the bike, but luckily I was unscathed.
https://youtu.be/EO6ZDawL33g
We got her back together for early 2021 and had a couple of parades with the CRMC at Darley Moor and she was flying, albeit a bit loose.
https://youtu.be/UB5gogcfF0o
https://youtu.be/wb-5sawVcGI
I then entered the first race of the BHR season at Darley Moor, and it was cold and wet. Whilst overtaking a back marker in race 2 I went in too hard into the only left hander on the circuit and found myself on the deck - rookie error, but we got the bike rebuilt for race 4 on the Sunday but I had no confidence in the tyres and drove round like Mary Poppins.
We then went to the BHR meeting at Pembrey in Wales last weekend and despite the thunderstorms forecast, it was glorious and we had three good races before the carbs started pouring petrol out of the overflows. The over 50s race was the most fun and here is the link.
https://youtu.be/Z64RUgJaPgA
Only one more race for the 900 this year, and then the job over winter is to get more HP for the 2022 season.
Gareth
PostPosted: Fri Jul 30, 2021 1:18 am Reply with quote Back to top
The track in the last clip looks like it would be fun to race on.
Wide, lots of run-off.
Well done getting the F out there, Gareth.
ItalianFan
PostPosted: Wed Sep 01, 2021 10:32 am Reply with quote Back to top
Here's a slow lap of Donington Park on my 1981 CB900F
https://youtu.be/SrF4VS-vJiI
The instructor who followed me said we are grounding out the exhaust collector, the silencer and the belly pan. Need to hang off the bike more and get more power from somewhere !
Gareth
ivan_the_terrible
PostPosted: Thu Sep 02, 2021 7:15 pm Reply with quote Back to top
Hi Gareth
You may need some rear shock mounts, some 40 mm higher than stock, with no mods or welding needed
__________________________________________
IVAN
