chachee
Sat Jan 28, 2006 8:47 pm |
What kind of grips do you like? What kind do you hate? Why? Looking for opinions.  |
Sat Jan 28, 2006 9:33 pm |
I've always like the factory Honda piece myself. Perfect fit. Long lasting, I've yet to have had to change a set of grips (of course this may be due to a rather protracted riding schedule and low kilometers per yer I guess). The Canadian spec 1100F grips are set up for bar end weights as used on the clip-on bars installed on this model, ergo there is a factory cut hole in the end of the grip which makes bar end mirrors and/or weights a very simple install job. Nice factory clean hole in the end of the grip. There is a RH and LH grip of course to make the throttle sleeve size isssue no problem also.
1100 CBF/1983 53165-422-000 Grip (handle bar) 9.16cnd
1100 CBF/1983 53166-422-000 Grip (handle bar) 9.16cnd
Tony
A rather poor photo, but it may give ya a bit of an idea what there like incase you forgot. CRG 2" Blindsite mirror installed here. (There kinda small hey Blaine )
edit: Also of note: The Sport Cable switch block allows for a rather nice install of the Vista Cruise Control unit. The locationg tab which would normally be between the cables on the standard switch block(at least I think that's where it would normally be?) is now of courser rotated up to the Sport Cable position with only a slight mod to the Vista Cruise unit. I shaved the locator tab down to fit between the Sport Cable switch block cables. This (IMHO) puts the Vista Cruise thumb lever in a much nicer position (down low) which both works extremely well and does not make the piece look like an after-thought sticking up on the bar.
Streblerm
Sun Jan 29, 2006 12:22 am |
I really like the OURY block grips, but I haven't seen them lately. They are kind of soft and grippy. |
Da_Hose
Sun Jan 29, 2006 12:51 am |
79cb750f
Sun Jan 29, 2006 12:55 am |
On my Continental Sport Control Kit I use Grab-On touting grips (with Chrome endcaps) My cruise control is as described. Carpal Tunnel is a Bitch. |
Sun Jan 29, 2006 12:56 am |
I like foam grips.
_________________ 1981 CB900F (silver) |
chachee
Sun Jan 29, 2006 4:48 am |
| Streblerm wrote: |
I like these too. I found them for $9.99. I also like the foam grips... I just don't think they would last long. |
razor02097
Sun Jan 29, 2006 6:13 am |
when I switched to GSXR1300 handlebars I used the grips that came with the bars. |
